The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
2015 Acura TLX 3.5L V6
by blackdiamond. 03/23/19 06:20 PM
Group 3 oil with best heat stability?
by LSXHitman. 03/23/19 05:24 PM
FixItDad28, RandomJoe, Sciascia, sosp197, peppercorn
67597 Registered Users
25 registered members (c502cid, dishdude, carlprop, csandste, Blkstanger, 3 invisible), 740 guests, and 56 spiders.
Topics286,320
Posts4,906,408
Members67,597
Most Online2,967
Mar 10th, 2019
Firewood - educate me #4548297
10/19/17 01:04 PM
10/19/17 01:04 PM
Michigan
stockrex Offline OP
stockrex  Offline OP
Michigan
If you guys remember I had a tree that was dying due to ivy in my back yard.
Well early summer, I had that taken down and the tree guys sawed it to 18 inch lengths.
Some of the lower sections are 20 inch wide, I need to split them.
I want to burn them in my wood fire place, the wood is maple.
I have very limited access the backyard, the tree guys had to use a crane to cut the tree.
How do I go about splitting the logs?
Do I just split and stack them raised off the ground?
Cover them with tarp (my neighbor already hates me, I don't think she will like me covering the logs)
The logs are sitting somewhat stacked against my fence.
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: Firewood - educate me [Re: stockrex] #4548312
10/19/17 01:15 PM
10/19/17 01:15 PM
TX
fields Offline
fields  Offline
TX
Buy an axe. Swing it.
Re: Firewood - educate me [Re: stockrex] #4548325
10/19/17 01:28 PM
10/19/17 01:28 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
leave a few pieces for ends (big ones)
then stack the splits between them.
The cheap method is sledgehammer and wedge(s)
You obviously havent split much firewood by hand....
You wont be splitting 18"x20" maple logs with an axe.
Re: Firewood - educate me [Re: stockrex] #4548345
10/19/17 01:50 PM
10/19/17 01:50 PM
N.C.
gman2304 Offline
gman2304  Offline
N.C.
Rent a splitter from Home Depot, unless you are like the guy on the Brawny paper towel rolls. wink
Re: Firewood - educate me [Re: Rand] #4548359
10/19/17 02:05 PM
10/19/17 02:05 PM
MA
Wolf359 Online content
Wolf359  Online Content
MA
Yeah, if you keep chopping wood, you might get injured like this NFL player did.
http://www.espn.com/espn/wire/_/id/1635118
Re: Firewood - educate me [Re: stockrex] #4548377
10/19/17 02:25 PM
10/19/17 02:25 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
You need a splitting maul and a 8 plus pound sledge and some wedges you should be able to pick them us at a chainsaw shop or an Ace or other Hardware store.
https://www.stihlusa.com/products/hand-tools/axes/prosplitmaul/
https://www.google.com/search?q=wood+splitting+wedge&tbm=isch&source=iu&pf=m&ictx=1&fir=7v8CJprah4TwhM%253A%252CCG8GjDD7Sjt1IM%252C_&usg=__e7PfFW5xiQ49ATjc714n6Jx3AYU%3D&sa=X&ved=0ahUKEwjQ5p-Jtv3WAhULwFQKHcN7Dm0Q9QEIkQEwBg#imgrc=7v8CJprah4TwhM:
2004 Corolla 130035
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Firewood - educate me [Re: stockrex] #4548397
10/19/17 02:51 PM
10/19/17 02:51 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Do you have chainsaw? Straight grained sections of maple of any size is easy to split with a maul. Just start at the edges and pop pieces off.
The knotty stuff I just cut through the with a saw parallel to the grain, and split off the straight grain sections with the maul. It makes the saw work a bit but with a sharp chain and functional oiler its not a big deal.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: Firewood - educate me [Re: gman2304] #4548407
10/19/17 03:05 PM
10/19/17 03:05 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
+1. You're not going to split logs of that size with just an axe.
Maybe with an axe and wedges and a sledge, but you'll need at least 4 wedges and it'll be a very long grueling workout.
Cleanup after using a chainsaw for that much wood will be....horrible.
Thick vs Thin test: 15k / 43k miles complete
Re: Firewood - educate me [Re: stockrex] #4548410
10/19/17 03:06 PM
10/19/17 03:06 PM
new jersey
hemitruck Offline
hemitruck  Offline
new jersey
Stack it on wood pallets. I like to leave my sit for about six months to let it dry out then cover.
Re: Firewood - educate me [Re: stockrex] #4548464
10/19/17 04:14 PM
10/19/17 04:14 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
I prefer to tarp the top of the pile (and the sides in extended rainy weather) with a green tarp. Looks a little less obnoxious than with a blue tarp. You could be a really nice neighbor and go with a "camo" design. Don't stack it too wide or the chipmunks will move in. I don't know how long maple takes to cure but I would think it would take at least until the following year sometime if you're just cutting it now. Once stacked on a pallet it can sit there for many years until you use it.
Fwiw, I had some 14-16" diameter oak logs a few years back and a guy offered to split it for me by hand. He only used a single wedge, wood axe, and a sledge. In 2 days he cut about 2-3 cords. I tried it for "fun" and my back was done on the 6th swing. Renting a log splitter is the way to go.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Firewood - educate me [Re: stockrex] #4548482
10/19/17 04:32 PM
10/19/17 04:32 PM
Michigan
slug_bug Offline
slug_bug  Offline
Michigan
In my community we are not allowed to stack firewood on the ground. They say it attracts rats. Home Depot has some cheap brackets to make an inexpensive firewood rack out of 2x4's.
http://www.homedepot.com/p/Pleasant-Hearth-4-Piece-Log-Brackets-LS-B4/204597265?cm_mmc=Shopping|THD|DigitalDecor|google|D28I+Fireplaces|_pkw__pmt__product_204597265&mid=smj4xTB92|dc_mtid_8903yuu57254_pcrid_50236715022_pkw__pmt__product_204597265_slid_&gclid=CjwKCAjwmqHPBRBQEiwAOvbR86TkBZErUbE7MlrW4fx8mB4Eal_Dnj46M1NPZfRymmTupc4L6ndNQRoCVPMQAvD_BwE
HD also sells these galvanized brackets that make it easy to build a quick rack:
http://www.homedepot.com/p/Simpson-Stron...RTC2Z/204834336
2016 Miata 2.0l (15k)
2013 Fusion 2.5l(91k)
2013 Focus(64K)
2010 Linc MKX 3.5l(96k)
2007 Dodge Caravan 3.8l(186k)
2003 Merc. Mountaineer 4.6l(121k)
Re: Firewood - educate me [Re: fields] #4548581
10/19/17 06:38 PM
10/19/17 06:38 PM
out there
spasm3 Offline
spasm3  Offline
out there
LoL.
If its green, a maul and wedge. If its dry maple, you need a splitter.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Firewood - educate me [Re: stockrex] #4548609
10/19/17 07:23 PM
10/19/17 07:23 PM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
Depends on the type of maple tree as well. We have some around here called water maples that are a little like sycamore soft light wood that burns fast and splinters badly when splitting. This makes splitting a challenge as logs stick together with splinters all over clinging together.
96 Grand Marquis
01 Sable LS
02 Montero
Re: Firewood - educate me [Re: stockrex] #4548619
10/19/17 07:39 PM
10/19/17 07:39 PM
ME
eljefino Offline
eljefino  Offline
ME
Find the biggest nastiest stumpy log and make that your base. Haul other logs up onto it. Aim your axe/maul at a spot about three inches from the edge. Work around it, reducing its diameter, until you wind up in the middle.
Turn on AM radio for political talk when you do it so you get good n' angry. laugh
Re: Firewood - educate me [Re: eljefino] #4548659
10/19/17 08:11 PM
10/19/17 08:11 PM
MA
MA
And don't chop your foot off like punter Chris Hanson almost did.
