Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
Food Safety - If You Have Children
by Zee09
06/23/18 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
06/23/18 05:02 PM
Chain cleaning and lube
by dadinfo
06/23/18 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
82 registered (AndyB, 2004tdigls, AP9, 2009Edge, 10WSmuckers, 10 invisible), 1503 Guests and 49 Spiders online.
65303 Members
67 Forums
285870 Topics
Page 1 of 2 1 2 >
#4548019 - 10/19/17 08:48 AM Oil Grade and OCI- My two identical Ford Explorers
spj Offline
Loc: north east
I happen to have two 2015 Ford Explorers in my garage. One is my wife's grocery getter and gets PUP 5w20, Fl500 filter usually around 8,000 miles or so prior to the oil life monitor going off. It runs great. Once out of warranty it will probably get 5w30.
My other Explorer is a police interceptor that is company serviced. It gets Delvac 1 5w40 with an OCI of 24,000 miles and a Wix filter every 8,000. This vehicle is beat on terribly. Not uncommon to get called out in the middle of the night in the winter, start it up and mat it for 60 or 70 miles. Idles for hours on end. I have used up 9 vehicles with this same regimen. Fords, Chevys, doesn't matter, NEVER an engine blown for me or anyone else with over 1,500 plus cars in my time.
What is my point? With the exception of DI, I think we worry too much about grades, sometimes OCI's and so forth. Use a good synthetic and filter, have a reasonable oci, and check your oil level between changes.
#4548034 - 10/19/17 09:04 AM Re: Oil Grade and OCI- My two identical Ford Explorers [Re: spj]
JustN89 Offline
Loc: DFW
But this is BITOG.. If we don't worry about this stuff, then who will??
In all seriousness, grades, base stocks, add packs, OCIs, they are all important. However, we probably do give them more consideration than really needed.
Most people don't know what their OCI is, they just go until the minder light comes on or see an ad on TV for oil which gets them thinking and they realize that they don't remember when the last got their oil changed, so it must be time to do it
One thing I've noticed is that most people I know who consider themselves "car people" aren't very well rounded. They will spend tons of money on performance parts or aesthetic parts while they can't even remember the last time an oil change was done, or the last time they did any real preventative medicine. Or they will fret over what oil to put in or what fuel additive they should use while driving around with a CEL on that they don't know what it's for or tires that by this point closely resemble racing slicks.
Point is, take care of your car and it will take care of you.
#4548041 - 10/19/17 09:07 AM Re: Oil Grade and OCI- My two identical Ford Explorers [Re: spj]
DdDd Offline
Loc: NY
If you pop a motor early, Ford will replace since you have fleet contract. Most will survive, some will not. Nature of manufacturing.
But if I mic the tolerances, I'll bet your engine has been spread wider than the employee of a Vegas cathouse.
#4548045 - 10/19/17 09:11 AM Re: Oil Grade and OCI- My two identical Ford Explorers [Re: spj]
spj Offline
Loc: north east
How about all the motors with 125,000 or 150,000? None of them blowing. Most of my career Ford covered to 75,000. I know very well as Ford builds better motors than transmissions.
#4548093 - 10/19/17 10:02 AM Re: Oil Grade and OCI- My two identical Ford Explorers [Re: spj]
Alex_V Offline
Loc: Campbellsville, KY
How many miles on either? Staying in one piece for 125K is different than the 200-300K game some of us are playing.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 112K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 167K
'67 Suburban, 350, 331K
#4548102 - 10/19/17 10:14 AM Re: Oil Grade and OCI- My two identical Ford Explorers [Re: spj]
CT8 Offline
Loc: Idaho
Delvac 1 is probably as good as oil gets.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4548103 - 10/19/17 10:15 AM Re: Oil Grade and OCI- My two identical Ford Explorers [Re: DdDd]
CT8 Offline
Loc: Idaho
Tolerances are the allowed variation of the blue print clearances.
#4548137 - 10/19/17 10:56 AM Re: Oil Grade and OCI- My two identical Ford Explorers [Re: spj]
Nick1994 Online   content
Loc: Phoenix, AZ
Oil changed at 24,000 miles and the filter changed at 8,000 miles? Sounds completely backwards to me.
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4548203 - 10/19/17 11:46 AM Re: Oil Grade and OCI- My two identical Ford Explorers [Re: spj]
jimbrewer Offline
Loc: New Mexico, USA
Ain't that the truth? I don't see any percentage in trying to go to the ragged edge on an oil change especially for a Ford which has long oci anyway.
Those occasional hard shifts give me the Willies. Change the transmission fluid extra early maybe it will help long term.
#4548213 - 10/19/17 11:54 AM Re: Oil Grade and OCI- My two identical Ford Explorers [Re: spj]
spj Offline
Loc: north east
My last car was an Impala, it went away to auction at 154,000 trouble free engine miles. I see the old cruisers all over the place being used as taxis.
Edited by spj (10/19/17 11:55 AM)
#4548222 - 10/19/17 11:59 AM Re: Oil Grade and OCI- My two identical Ford Explorers [Re: jimbrewer]
spj Offline
Loc: north east
Jim, I used to call it the green light of death on the crown vics, the od light would start flashing as a warning. Time to put it into 2nd and limp in to a ford garage. Had back to back Impalas three years apart, first one lost the transmission at 94,000 and the second at 88,000.
#4548225 - 10/19/17 12:04 PM Re: Oil Grade and OCI- My two identical Ford Explorers [Re: spj]
Onug Offline
Loc: Washington, USA
What engine does your wifeís Explorer have? And please tell if youíve had any problems with the Interceptor motor at all. A buddy of mine is a local LEO and their initial set of Explorer Interceptors are apparently having issues due to the excessive idling...but he didnít know any details.
2016 F-150 3.5L Ecoboost
Current Oil: Mobil 1 5W-30 and Fram Ultra filter
#4548241 - 10/19/17 12:14 PM Re: Oil Grade and OCI- My two identical Ford Explorers [Re: Onug]
spj Offline
Loc: north east
3.5 standard in the wifes. The only issue im aware of are some cracked exhaust manifolds, mostly in the interceptor sedans. I cracked one in my last impala.
#4548245 - 10/19/17 12:17 PM Re: Oil Grade and OCI- My two identical Ford Explorers [Re: Onug]
spj Offline
Loc: north east
The big issue for them right now is carbon monoxide in the cabin. Ford is doing a huge recall on all of the police interceptor suvs. The cause isn't really known but Ford has stated they feel police mods, ie drilling holes, is a contributing factors.
#4548277 - 10/19/17 12:40 PM Re: Oil Grade and OCI- My two identical Ford Explorers [Re: spj]
i_hate_autofraud Offline
Loc: Canada
" check your oil level between changes"
Yup! checking the oil is something too many ordinary pple just don't do and act surprised
when the engine blows with no oil left in the pan!
Page 1 of 2 1 2 >
