voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Geardaddies, tedonom, 01ws666, ariefnrst, tcoffin014
66658 Registered Users
101 registered members (4WD, 28oz, 2008wrx, 2004tdigls, 14 invisible), 1,871 guests, and 35 spiders.
Topics294,978
Posts4,925,312
Members66,658
Most Online2,553
Oct 27th, 2018
Fram Ultra Query #4547868
10/19/17 04:59 AM
10/19/17 04:59 AM
NSW Australia
peejaycruiser Offline OP
NSW Australia
XG3593A just checking this is the right filter for an 02 Subaru Liberty (Legacy) EJ25 2.5L. I did a search and some companies have up to 13 different filters listed for it, which is confusing to say the least. Can get these relatively cheap from US from same supplier I got filters from before, just don't want to be ordering a part I've got confused over. crazy
Re: Fram Ultra Query [Re: peejaycruiser] #4547873
10/19/17 05:05 AM
10/19/17 05:05 AM
ON, Canada eh?
StevieC Online content
StevieC  Online Content
ON, Canada eh?
According to FRAM's website yes it is.
http://www.fram.com/search-parts/
'18 Dodge Grand Caravan GT - AMSOIL SS 5w20
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF
Re: Fram Ultra Query [Re: peejaycruiser] #4547875
10/19/17 05:05 AM
10/19/17 05:05 AM
MA
PE400 Offline
PE400  Offline
MA
Fram website list that XG3593A for you vehicle so yes..
2000 Jeep Cherokee Sport 121,895 mi (rebuilt @ 114000)
Fram Ultra XG8A
Rotella T5 15-40
Re: Fram Ultra Query [Re: peejaycruiser] #4547881
10/19/17 05:11 AM
10/19/17 05:11 AM
NSW Australia
NSW Australia
Yeah Fram site tells me that just wanted to be certain it was what I was seeing. Would be a little embarrassing to order them and not fit. laugh
Cheers.
02 Subaru Liberty RX 2.5 Synpower 5W-40 OEM Filter
96 Toyota 80 Series 1HZ Sakura C-1112 Nulon High Torque 15w-40
Re: Fram Ultra Query [Re: peejaycruiser] #4547891
10/19/17 05:26 AM
10/19/17 05:26 AM
ON, Canada eh?
ON, Canada eh?
cheers
Re: Fram Ultra Query [Re: StevieC] #4547921
10/19/17 06:11 AM
10/19/17 06:11 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Eye catching thread title
Re: Fram Ultra Query [Re: Kira] #4547929
10/19/17 06:23 AM
10/19/17 06:23 AM
Texas & Global
4WD Online confused
4WD  Online Confused
Texas & Global
Yeah … almost like when there is a “grilling” …
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: Fram Ultra Query [Re: peejaycruiser] #4547937
10/19/17 06:36 AM
10/19/17 06:36 AM
NSW Australia
NSW Australia
Haha just noticed it has changed. Acronyms must only be used in thread body not titles it seems. laugh
Re: Fram Ultra Query [Re: peejaycruiser] #4547959
10/19/17 06:57 AM
10/19/17 06:57 AM
The land of USA-made Subies!
SubieRubyRoo Online happy
SubieRubyRoo  Online Happy
XG3593A is indeed the correct filter; PL14610 and Bosch D+3312 fit as well (with slightly lower BPV settings). The reason why some companies have so many compatible filters listed is that the NA EJ25s have a ton of room both around and under the filter mount. You can take an OEM sized filter (shotglass sized) or get much, much bigger in both diameter and length. The Turbo EJ25s are generally much tighter due to the exhaust routing to the turbo and as such are limited on filter sizes that will fit outside of OEM size.
Re: Fram Ultra Query [Re: peejaycruiser] #4547995
10/19/17 07:36 AM
10/19/17 07:36 AM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
The 3593A and its equivalents are designed for Hondas. They have a more deeply recessed threaded area then what the EJ25 was designed for, they have anti-drainback valves that the EJ25 does not need, and they have bypass valve pressures that are half of what Subaru specs. Fram does not make a Subaru-specific filter. Wix does but it's the smaller 'turbo' size.
The Purolator 14460 and its equivalents like the Bosch 3310 and Motorcraft 1998 are all correct. They have the correct thread depth, no ADBV and the correct high bypass valve setting.
Basically if anything cross-references back to a 3593A it's a Honda filter.
Re: Fram Ultra Query [Re: Bottom_Feeder] #4548031
10/19/17 08:00 AM
10/19/17 08:00 AM
MA
PE400 Offline
PE400  Offline
MA
some good info here.. question other than by pass settings which for this EJ25 is an interesting topic in itself how bout ph6607, ph7317, ph9688?
Fram Ultra XG8A
Rotella T5 15-40
Re: Fram Ultra Query [Re: peejaycruiser] #4548823
10/20/17 12:09 AM
10/20/17 12:09 AM
NSW Australia
NSW Australia
Now ya trying to confuse me. laugh
Re: Fram Ultra Query [Re: peejaycruiser] #4548953
10/20/17 06:31 AM
10/20/17 06:31 AM
MA
PE400 Offline
PE400  Offline
MA
Subaru usually always spins back to use the OEM filter cause bypass is almost double and oddly filter manufactures seem to just recommend something that fits as opposed to match the factory specs.. surprised the "use OEM only" hasn't been posted in this thread yet.. I'm breaking in a rebuilt EJ25 on supertech ST9688 and supertech 5w30 atm. I'm leaning towards runnig a fram XG7317 and M1 syn after break in.
Fram Ultra XG8A
Rotella T5 15-40
Re: Fram Ultra Query [Re: peejaycruiser] #4549210
10/20/17 11:07 AM
10/20/17 11:07 AM
California
nthach Offline
nthach  Offline
California
I would clamor for OE only... but Motorking says Fram's 3593A/7317 filters can be used safely on many Subarus. He said there's enough media to handle the the delta pressure across the element. With the countless examples of non-turbo Imprezas, Foresters, Legacies and Outbacks rolling around Portland/Seattle/Tahoe on bulk oil and Fram/Champ or Puro jobber filters, I think you'll be fine.
Even more confusing is that Fram does make Subaru's service filters.
