- Joined
- Sep 23, 2017
- Messages
- 433
I got my transfer case(borgwarner 4485) fluid changed by a buddy, he over torqued the drain plug and i noticed that i can see metal shavings in the corner of the bolt where its threaded into the transfer case. the fill plug was torqued properly. i also see that the drain plug is further into the threads then the fill plug.
its not leaking atm, and i dont think ill ever have to change the fluid again. is this something to worry about? there seemed to be some type of thread sealent/teflon tape that was reused.
