1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
47 registered members (c502cid, anndel, billpace1956, Brad_C, Ammofirst, BikeWhisperer, 5 invisible), 1,043 guests, and 31 spiders.
Topics296,903
Posts4,961,302
Members66,997
Most Online2,688
Jan 19th, 2019
Harbor Freight Type Generator Carb Adjust #4547510
10/18/17 06:22 PM
10/18/17 06:22 PM
Texas
picman Offline OP
picman  Offline OP
Texas
I got 2 curb rescue generators. One Chicago Electric 800 watt and a nearly identical ETQ TG1200. Got them both running after some major cleaning. The. Chicago one has one screw on the carb for idle adjustment. The other port is sealed. On the ETQ has 2 screws, idle and another (same location as blocked port on Chicago) that I'm assuming is mixture. My question is how to adjust this possible mixture screw. Running it in and out seems to have no effect on running.
Re: Harbor Freight Type Generator Carb Adjust [Re: picman] #4547536
10/18/17 06:43 PM
10/18/17 06:43 PM
MI
HorseThief Offline
HorseThief  Offline
MI
Idk if there IS a hi/lo setup - the motor is designed to maintain a single speed (3600rpm/60hz) Most lawn mower engines are the same setup.
Lucky you - I never find cool stuff at the curb anymore. There's too many scrappers. Yesterday someone stopped and pulled all the metal handles and hinges off a dresser I threw out... Must have been a whopping $0.06 there
I saw a brown dog
Re: Harbor Freight Type Generator Carb Adjust [Re: picman] #4547544
10/18/17 06:47 PM
10/18/17 06:47 PM
USA
mk378 Offline
mk378  Offline
USA
For idle, override the governor by holding the throttle plate closed down to the idle stop and adjust the mixture for highest rpm, then richen it slightly. Running mixture, if it really is adjustable, you should set with the engine under load. Again lean out as far as it will go before misfiring, then richen slightly.
Re: Harbor Freight Type Generator Carb Adjust [Re: picman] #4547597
10/18/17 07:08 PM
10/18/17 07:08 PM
Texas
picman Offline OP
picman  Offline OP
Texas
Re: Harbor Freight Type Generator Carb Adjust [Re: picman] #4547625
10/18/17 07:28 PM
10/18/17 07:28 PM
USA
mk378 Offline
mk378  Offline
USA
The two screws on the top are the idle mixture and idle speed stop. The high-speed mixture is not adjustable.
The speed stop prevents the engine from completely cutting out if the governor pulls the throttle all the way down. If it is set too low, the speed may "surge" with no load. If too high, the engine will run faster than the intended governed speed with no load.
Re: Harbor Freight Type Generator Carb Adjust [Re: picman] #4547634
10/18/17 07:35 PM
10/18/17 07:35 PM
Texas
picman Offline OP
picman  Offline OP
Texas
Thanks!
Re: Harbor Freight Type Generator Carb Adjust [Re: picman] #4547646
10/18/17 07:46 PM
10/18/17 07:46 PM
Flaherty, KY
92saturnsl2 Offline
92saturnsl2  Offline
Flaherty, KY
Are these the cheapie 2-stroke generators?
1985 F-250HD 7.5L 4x4 135k- Castrol GTX 15w-40 HDEO
04 Odyssey EX 184k Valv. Durablend 5w-30
96 Maxima GLE 255k Castrol Edge EP 5w-20
07 Chrysler Pacifica Limited 4.0L 134k Chevron Supreme 5w-20
Re: Harbor Freight Type Generator Carb Adjust [Re: picman] #4547656
10/18/17 07:55 PM
10/18/17 07:55 PM
Texas
picman Offline OP
picman  Offline OP
Texas
That's them.
Re: Harbor Freight Type Generator Carb Adjust [Re: picman] #4547662
10/18/17 08:00 PM
10/18/17 08:00 PM
Flaherty, KY
92saturnsl2 Offline
92saturnsl2  Offline
Flaherty, KY
I have an 800w unit I bought from Menards or someplace for $89.00. It's served me well. I bring it camping with us in the colder months and attach it to a electric heater that probably sucks every watt out of that little thing. It's 7-8 years old now and still purrs like a kitten. Nice to know there are parts available for it. Mine is a single speed, simply 3600rpm. It has an idle speed screw, but I haven't looked closely for others.
Re: Harbor Freight Type Generator Carb Adjust [Re: picman] #4547757
10/18/17 10:20 PM
10/18/17 10:20 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Originally Posted By: picman
That one screw going straight down (without the spring under its head) is a pilot jet. It goes into an air bleed passageway. Pull it all the way out and you'll see a hole drilled through its tip. It meters air instead of fuel. It's not adjustable.
Re: Harbor Freight Type Generator Carb Adjust [Re: picman] #4548230
10/19/17 11:06 AM
10/19/17 11:06 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
New replacement carbs for these are ~$14 shipped to your door, with gaskets, fuel line and hose clamps. I typically just replace them an see if I can rehab the OEM for a spare.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
