'15 6.7 Powerstroke UOA
by roadrunner1. 01/18/19 10:18 AM
Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
110 registered members (Astro14, anndel, 69GTX, atikovi, AndyB, 9 invisible), 2,113 guests, and 52 spiders.
Topics296,780
Posts4,958,739
Members66,969
Most Online2,577
Jan 14th, 2019
Page 1 of 3 1 2 3
Sulfated ash and carbon deposits... #4547404
10/18/17 04:43 PM
10/18/17 04:43 PM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
Had a long convo with Amsoil tech support earlier today about using a low-ash engine oil in my RX-8. BIG kudos to them for spending as much time with me as they did.
They gave me a lot of good advice, but they also said one thing that I'm struggling with: they told me there's no reason to expect a lower-ash oil to leave this engine any cleaner than a higher-ash oil. The reason they gave is that most of the carbon deposits will be coming from fuel, and even at 1 qt/1000 miles, not much oil is getting burned.
This seems to make sense in isolation. But everything I've read elsewhere -- including in one of Amsoil's own TSBs on the RX-8 -- suggests that sulfated ash correlates significantly with deposit formation. I've also seen many suggestions that low ash content is extremely helpful if not mandatory for rotary engines.
Any thoughts? Am I missing something that'd reconcile all of this?
2008 BMW M3
Re: Sulfated ash and carbon deposits... [Re: d00df00d] #4547418
10/18/17 04:52 PM
10/18/17 04:52 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Covering their fundament? I thought sulfate ash was more about catalytic converters than carbon deposits.
When in doubt I'd listen to the TSB which was probably written by an engineer
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Sulfated ash and carbon deposits... [Re: d00df00d] #4547571
10/18/17 06:55 PM
10/18/17 06:55 PM
Ont Canada
Koz1 Offline
Koz1  Offline
Ont Canada
TSBs over phone Techs every day of the week.
Currently using, Fuchs TITAN GT1 PRO FLEX 5W-30, M1 5W-20 and Castrol Edge 0W-20 Gold B.
Re: Sulfated ash and carbon deposits... [Re: d00df00d] #4547803
10/19/17 12:17 AM
10/19/17 12:17 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
For what it's worth, from my experience, Sulphated Ash categorically does NOT correlate with carbon deposit formation. In fact these days, particularly in the US, it's probably incorrect to even refer to Ash as being 'sulphated' as there's bugger all sulphur in engine oil and even less in gasoline.
Re: Sulfated ash and carbon deposits... [Re: d00df00d] #4547846
10/19/17 03:41 AM
10/19/17 03:41 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
I thought that sulfated ash was the residue that was left after burning all the oil off it, after reacting the metallic additive pack with sulfuric acid (making a sulfate solid ash after heating).
Re: Sulfated ash and carbon deposits... [Re: Koz1] #4547864
10/19/17 04:54 AM
10/19/17 04:54 AM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
To be fair, the TSB doesn't literally say "you should use low-ash oils in the RX-8 to prevent carbon deposits". Here's the relevant passage:
Quote:
Carbon deposit formation may not be due to the type of base oil, but can also be related to the ash content of the oil additive package. Higher ash content oils can form more carbon deposits than lower ash content oils.
...but then it goes on to say this, which (as discussed in another thread) seems to indicate the document wasn't written solely by engineers:
Quote:
In recent years, API and ILSAC have reduced the ash content in engine oil to below 0.80% (max) by weight to meet API SM, ILSAC GF-4 specifications.
Ash is literally nowhere in the API SM or ILSAC GF-4 specs. What those specs limit to 0.80% is the phosphorus level -- related, but not the same (someone correct me if I'm wrong).
2008 BMW M3
Re: Sulfated ash and carbon deposits... [Re: Shannow] #4547871
10/19/17 05:03 AM
10/19/17 05:03 AM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
My understanding is that the sulfated ash test uses sulfuric acid as part of a process to approximate the ash that might be produced in normal engine operation. So, yes, the resulting ash is sulfated whereas the ash from an engine wouldn't necessarily be -- but the result of the test is a mass % figure that is still considered useful as a rough indication of an oil's ash-forming tendencies in an engine. I.e., an oil with a lower sulfated ash number will tend to form less ash in an engine than an oil with a higher sulfated ash number, even though the ash formed in the engine wouldn't be sulfated. And ash, in turn, is one cause of carbon deposits (albeit usually not the main one).
Is that not correct?
2008 BMW M3
Re: Sulfated ash and carbon deposits... [Re: d00df00d] #4547886
10/19/17 05:16 AM
10/19/17 05:16 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Amsoil's interpretation of a TSB is undoubtedly biased.
I don't see S.A. creating "carbon" deposits...but certainly "deposits"....which was why S.A. became an issue in the first place.
It's pretty funny that Amsoil use the fact that their flash point "isn't that much different to dino, so therefore isn't a problem", when their other advertorials include statements that their "superior" flashpoint" differentiates synthetics from regular oils.
Early wankel issues from NSU days demonstrate that deposits building up on apex seal leading to seals jumping and chatter marks...S.A. can do that.
Re: Sulfated ash and carbon deposits... [Re: Shannow] #4548367
10/19/17 01:15 PM
10/19/17 01:15 PM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
Got it. Could you explain, or point me to where I could read about, the difference between "carbon deposits" as you used the term and the kinds of deposits that would form from ash?
Yep, noticed that as well.
So assuming I understand correctly, a lower-ash oil WILL reduce deposit formation -- BUT, if ash isn't the most troublesome kind of deposit in the engine, I might be better off with an oil that maybe has a slightly higher SA number BUT has better detergency to control other kinds of deposits. Does that sound about right?
2008 BMW M3
Re: Sulfated ash and carbon deposits... [Re: d00df00d] #4548431
10/19/17 02:33 PM
10/19/17 02:33 PM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
Back in the day, when it wasn't uncommon for Group I base oils to contain 1% sulphur and for Diesel fuels to contain maybe 0.8% sulphur, there was a prevailing view that metallic ash going down the exhaust pipe was in the 'sulphated' form. The Sulphated Ash test sort of reflected this bygone reality.
The bulk of the ash in any engine oil originates from the overbased metallic detergent (eg 300 TBN Calcium Sulphonate) with a lesser amount coming from ZDDP. On the basis that both of these additives improve the oxidative stability of oil, you would expect both to reduce deposits.
Re: Sulfated ash and carbon deposits... [Re: SonofJoe] #4548462
10/19/17 03:13 PM
10/19/17 03:13 PM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
Makes sense! Thanks, SonofJoe.
More not-even-half-informed ramblings to follow:
One of the practical questions in all of this is whether I'm barking up the wrong tree by pursuing high-end low-ash synthetic oils. My thought had been that an oil meeting a spec like MB 229.51 or 229.52 would offer the best chance at keeping the engine clean while retaining performance at-or-above the SN/GF-5 level in all other respects (except mpg).
If I'm understanding better now, using a low ash oil would mean the oil itself would contribute minimally to ash formation. Such an oil might also contribute minimally to other kinds of deposit formation IF the finished oil were sufficiently oxidatively stable despite the light additive package (e.g. thanks to highly stable base stocks). Is that correct?
If so, I think I understand where the fellow at Amsoil was coming from. He kept stressing that the vast majority of the deposits will be coming from the fuel. Might a lower-ash oil be less well equipped to control those deposits, all else equal? If so, might I be able to compensate by just keeping my OCI short?
Tangential: I've also read that low-ash oils can reduce intake valve deposits in DI engines quite significantly. Is that mechanism sufficiently unique to DI engines that it's meaningless here? If not, how does it fit?
Really appreciate you guys wading through all this and helping me understand!
2008 BMW M3
Re: Sulfated ash and carbon deposits... [Re: SonofJoe] #4548552
10/19/17 05:02 PM
10/19/17 05:02 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
aaaaaahhhhhh...penny dropped moment here.
Thanks
Re: Sulfated ash and carbon deposits... [Re: SonofJoe] #4548602
10/19/17 06:11 PM
10/19/17 06:11 PM
Sequim, WA
edhackett Offline
edhackett  Offline
Sequim, WA
Forgive me if I'm misunderstanding what you're saying here. ZDDP carries four S atoms for every one Zn. Calcium Sulfonate carries one SO3 for each Ca, just itching to make CaSO4. Add heat and water in the combustion chamber and there's an excess of S needed to convert all of the metals to sulfated ash.
I can't for the life of me draw any connection between these additives' anti-oxidation properties in the oil vs what happens in the combustion chamber. There's a reason ZDDP and sulfonate (TBN) levels are reduced in oils intended for vehicles with particulate filters. It's not because their presence reduces deposits.
Ed
Never attribute to engineers that into which politicians, lawyers, accountants, and marketeers have poked their fingers.
Re: Sulfated ash and carbon deposits... [Re: d00df00d] #4548854
10/20/17 02:41 AM
10/20/17 02:41 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
Okay, first off, you're looking at deposits in a Wankel engine. I, and probably every single senior oil formulator in the entire world, knows precisely naff all about deposit formation in rotary engines because they're so rare & no sane person would every expend the kind of money you need to properly understand them. These engines are very likely a law unto themselves and I'd guess that the only people that have any kind of fix on what impacts on deposits are Mazda themselves.
Taking the more general points you made in no specific order...
Regarding the 'deposits come from fuel' thing. What can I say? It's lifted straight out of the Big Bumper Book Of Business Excuses! When in doubt, blame something you're not responsible for. Does gasoline quality impact on engine deposits? Quite possibly yes but that's not why the excuse is being deployed which is to portray the oil as non-complicit.
Regarding low ash oils and Inlet Valve Deposits, there's an old Lubrizol presentation written by a guy called Mike McCabe that infers that low SAP oils reduce IVDs. Our own Brother Gokhan, in his uncritical naivety, posted this presentation up a few months ago like he'd discovered something of massive importance! Sadly what BG failed to pick up on is the author works in Marketing and the presentation was a 'marketing' presentation in support of Low SAPs oil as a new, and potentially profitable, market segment. The lubes industry absolutely loves market segmentation! It's a way of sucking more money out of the poor saps that buy engine oil. Personally I would totally disregard the 'low SAP oil means less IVDs' conclusion this presentation draws. It's standard practice in these matters to organise test work such that it draws you to a preordained, sleight-of-hand conclusion. Nuff said...
Regarding MB229.51/52 oils, it's been several years since I looked at these in detail but these will be top flight oils made from excellent base oils and loaded up with additives. As such, they will be better than your average GF-5 oil. You won't hurt your RX-8 by using them.
Finally, it maybe stating the obvious but low ash oils DO indeed produce less ash and have a reduced tendency to plug Diesel Particulate Filters (DPFs). I would add my normal health warning here which is that low Ash does not mean NO ash (or even that much lower ash than 'normal' oils!) and that even with low SAPs oil you can typically expect a DPF to be knackered after 80,000 miles. However it's wrong to conflate DPF plugging ash with engine deposits. I'll say why in my next post...
Re: Sulfated ash and carbon deposits... [Re: d00df00d] #4548857
10/20/17 02:51 AM
10/20/17 02:51 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Doesn't look very carbonacious...
Page 1 of 3 1 2 3
