Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
Crane EE 5301 Humidifier
by maverickfhs. 12/15/18 02:38 PM
I have sinned
by 901Memphis. 12/15/18 01:57 PM
Milwaukee m12 in vanhaus ratchet
by pda1122. 12/15/18 01:19 PM
Klein dikes
by Donald. 12/15/18 01:03 PM
Help Soldering 3.5mm mono microphone plug
by Brybo86. 12/15/18 01:02 PM
Small Trolling Motors
by wings&wheels. 12/15/18 12:49 PM
Toyota Corolla, good and bad?
by jongies3. 12/15/18 12:35 PM
Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
73 registered members (AZjeff, andyd, Berny, BeerCan, 64bawagon, 53' Stude, 8 invisible), 1,939 guests, and 41 spiders.
Topics295,122
Posts4,928,094
Members66,688
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
My car has been sitting for a year #4547265
10/18/17 01:07 PM
10/18/17 01:07 PM
ny
llmercll Offline OP
llmercll  Offline OP
ny
How can I get it started?
If I put a battery tender on the battery is there any chance of bringing it back?
What about the gas? Should I funnel it out?
Is the oil ok?
Thank you
Re: My car has been sitting for a year [Re: llmercll] #4547266
10/18/17 01:09 PM
10/18/17 01:09 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Leave a battery charger on it for day to give it the best shot.
Gas should run it ok.
The oil is probably fine.
"Zed's dead baby, Zed's dead."
Re: My car has been sitting for a year [Re: llmercll] #4547267
10/18/17 01:10 PM
10/18/17 01:10 PM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
Has it been sitting outside?
Re: My car has been sitting for a year [Re: rooflessVW] #4547270
10/18/17 01:13 PM
10/18/17 01:13 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
I agree with rooflessVW.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: My car has been sitting for a year [Re: Kestas] #4547272
10/18/17 01:15 PM
10/18/17 01:15 PM
New England
Virtus_Probi Offline
New England
Depending upon the environment it was left in, might want to pop the hood and look for things like acorn hulls, nests made from insulation, etc.
2014 Forester XT, 90000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
Re: My car has been sitting for a year [Re: llmercll] #4547276
10/18/17 01:22 PM
10/18/17 01:22 PM
ny
llmercll Offline OP
llmercll  Offline OP
ny
It was in a garage. You really think the gas is ok? How long would it take for the gas to not be ok, out of curiousity? 2 years?
Re: My car has been sitting for a year [Re: llmercll] #4547279
10/18/17 01:30 PM
10/18/17 01:30 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
I personally would put in some seafoam or some other type of fuel stabilizer and let it sit in the tank while your battery is being charged back up. Your oil is just fine, but check the level to be sure before you start her up.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: My car has been sitting for a year [Re: llmercll] #4547281
10/18/17 01:33 PM
10/18/17 01:33 PM
New England
555 Offline
555  Offline
New England
What type of car? Turbo? High compression engine? Did you store it with full tank of premium?
84 XJ6 M1
92 Mustang 5.0 Redline
99 Tahoe 2 door Castrol Edge
99 MX5 Miata Anniversary Edition M1
04 Subaru STi Motul
Re: My car has been sitting for a year [Re: llmercll] #4547288
10/18/17 01:42 PM
10/18/17 01:42 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Gas can go bad after only months. Stored my car for a winter and tried Seafoam as a fuel stabiliser, ran like [censored] until I got a fresh tank of fuel into it. If you used gas with ethanol in it, and no stabiliser, I would drain the tank.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: My car has been sitting for a year [Re: llmercll] #4547294
10/18/17 01:46 PM
10/18/17 01:46 PM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
Keep the charger on for a day or so as mentioned. I would throw in a can of seafoam and try a few gallons of fresh gas in the tank to top off. After that give it heck. If it cranks and doesn't click over try a quick shot of starter fluid.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: My car has been sitting for a year [Re: llmercll] #4547315
10/18/17 02:15 PM
10/18/17 02:15 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
Is the oil ok?
Thank you
Well how was it running before you stopped using it?
How full is your gas tank?
The oil should be just fine for now but check the level.
The battery tender is probably only 1.5 to 3 amps. After having it on the tender for a few hours I'd put it on a regular 10 or 12 amp charger. Oh and check the water level in the battery before it goes on the tender.
2004 Corolla 126813
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: My car has been sitting for a year [Re: llmercll] #4547325
10/18/17 02:29 PM
10/18/17 02:29 PM
Texas
Tdog02 Offline
Tdog02  Offline
Texas
The gas is the limiting factor. After a year my generator would not run. Drained fuel and put fresh gas in and she started right up no issue. I would not run 1 year old gas thru any engine even if it was pure gas. Add ethanol and it can go bad in 4-6 weeks at the earliest. Best case on ethanol blended is maybe 5-6 months tops.
09 Venza 2.7 100k 5w-30 Magnatec
16 F150 2.7TT 40k 5w-30 Magnatec
Re: My car has been sitting for a year [Re: llmercll] #4547341
10/18/17 02:44 PM
10/18/17 02:44 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
It's crazy... Everyone here scoffed at me when I said I was going to add Stabil before storing my car for 90 days at a time.
Now it seems that gas will go bad in much less time.
OP, charge the battery and fire it up. You can mess around with changing the gas out or just see how it runs. If it doesn't run well, then drain the gas and and some fresh stuff. You won't lose anything just trying what's in it.
I bet you'll be fine.
Re: My car has been sitting for a year [Re: mightymousetech] #4547346
10/18/17 02:48 PM
10/18/17 02:48 PM
Utah
CKN Offline
CKN  Offline
Utah
Exactly. If the gas is Ethanol there is a chance it could be bad.
Re: My car has been sitting for a year [Re: llmercll] #4547363
10/18/17 03:21 PM
10/18/17 03:21 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Siphon out what you can, add a bottle of Startron to the rest, refill with fresh gas-BEFORE you try to start it!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Page 1 of 3 1 2 3
