Brad Penn 10w40 UOA ( New bottle)
TX
hello,
finally got chance to have my Brad Penn 10w40 UOA. Car only ran 1200 mmiles & estimate 2 months. Short oci because most of times was street tuning.
Ton of road pulls, rev up to 7800 rpms.
Normal driving.
E85/93 Flex fuel
Avg temp around 70 degree to 100 degree
OEM filter
car makes 450 AWHP/360 tq
This was with their new bottle, some says additives changed also some says not. So i figured get this test done before i order another case.
Current oil has 700 miles and will do another one at 2500~3000 miles.
Originally Posted By: Virtus_Probi
Man, Brad likes ZDDP!
Must be encouraging to see low wear metals (even for a short run) in a built engine like that.
It's stock block with 16000 miles
Originally Posted By: s2krunner
Is this one of the insanely powerful Evos from the UK?
I wish!!! But there are ton of guys pushing 500 stock block. Im little kid compare to others haha
Boy do i miss my EVO VIII.
Wow 1767 ppm Zinc and a TBN of 8.9 is a decent add pack.
Good low iron wear at 4 ppm,
The KV100 is 12.1 cSt, looks a bit low for a 10W40, I would expect something like 14 cSt or more. Probably fuel dilution.
Originally Posted By: KL31
Plan to go longer miles next time? Even 3000 seems low. Just a sample at 2500-3000?
Yes.
Im planning to do 2500~3000 miles this time and see. It will be good to see for me since Its now tap colder and running only E85 with this oil.
