Corrosion in the garage - salt or humidity?
by Kurtatron
14 minutes 34 seconds ago
Darn dogs
by AZjeff
Today at 10:21 PM
New GC?
by Bullwinkle007
Today at 10:04 PM
The guy with the plexiglass head on you tube
by andyd
Today at 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
Today at 09:10 PM
SAE 90 v 85/140
by Knuckle078
Today at 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
Today at 08:45 PM
what happened to merk
by ernied
Today at 08:34 PM
Schaeffer's oil reviews on Amazon
by zfasts03
Today at 07:41 PM
Decent MP3 player
by Ed_T
Today at 07:08 PM
Letgo
by Donald
Today at 06:52 PM
Tire buying advice
by supton
Today at 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
Today at 06:21 PM
No older cars in New York State?
by Oldtom
Today at 06:19 PM
2009 Taurus strut mount noise
by terry274
Today at 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
Today at 03:36 PM
2003 Honda power steering problem
by hogpops
Today at 03:29 PM
Public Service Announcement: Flush Your HW Heater
by gathermewool
Today at 03:25 PM
Fellow 2AZ-FE toyota owners: what oil are you usin
by car51
Today at 03:21 PM
Castrol 0W40 vs 5W40??
by Realfine69
Today at 03:02 PM
lozpxs, danthemanx07, FunktasticLucky, Knuckle078, penncove
65317 Registered Users
70 registered (154cm, 77GrandPrix, 1JZ_E46, 2015_PSD, 4WD, Aero540T, 8 invisible), 1153 Guests and 56 Spiders online.
65317 Members
67 Forums
285949 Topics
#4546850 - 10/18/17 06:44 AM Whole house filter?
Matagonka Offline
Loc: NC
Any of you guys have whole house filters and a well?
I have a well and I have to change my house filter every 2 weeks or so. It's been a year since I built it and the filters still get pretty muddy after 2-3 weeks.
#4546855 - 10/18/17 06:50 AM Re: Whole house filter? [Re: Matagonka]
benjamming Offline
Loc: northern Alabama
What micron filter is it? It might be too fine & require a two-stage setup.
#4546865 - 10/18/17 06:59 AM Re: Whole house filter? [Re: Matagonka]
Matagonka Offline
Loc: NC
I was using the 5 micron ones that also filtered chlorine, but since I have a well, I didn't really need that. Those would get stuffed and reduce flow pressure.
I since changed to the 30 micron filters. They don't reduce pressure but water becomes smelly if I let them get too dirty. I still replace them every 2-3 weeks.
#4546868 - 10/18/17 07:03 AM Re: Whole house filter? [Re: Matagonka]
LeakySeals Offline
Loc: Hudson, NH
I had one but after 2 years of use it stayed disconnected. WAY too much work. Causes pressure issues, clogs fast, etc. 15 years later, no flow issues around the house. Washer and shower heads ok. Hot water heater meets avg life expectancy. No ring around the toilet bowl but the inside where the float resides is muddy. So I guess it doesn't build up in high flow areas like the pipes as I had feared.
06 Escalade 6.0L AWD 160k. M1 5w30 Fram TG
03 Maxima 3.5L 149k ST HM 10w30
#4546922 - 10/18/17 08:07 AM Re: Whole house filter? [Re: Matagonka]
wormwood1978 Offline
Loc: Maine
I have a well and use a whole house filter system. I use a Big Blue 10 with a Pentek sediment filter followed by a Big Blue 20 with Pentek GAC filter. I change them every six months. No noticeable change in water pressure with a 6 month change interval. My water is great.
#4546927 - 10/18/17 08:16 AM Re: Whole house filter? [Re: Matagonka]
PimTac Online   content
Loc: Soviet State of Washington
In my previous house that had a well, we had a large filter that looked like a oxygen cylinder only it was fiberglass. Inside was a media that the water had to pass through. This media was fine stones. I forget the brand at the moment but I believe Culligan has similar products.
It was on a timer. During the night it performed a blackflush to clean the media. Each year our well driller came out and performed maintenance including dumping and cleaning inside the tank. If necessary, there was some media replenished.
We had high iron in our water that stained everything. This filter took care of that problem. The system pretty much took care of itself.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
#4546961 - 10/18/17 08:47 AM Re: Whole house filter? [Re: Matagonka]
modernmetal Offline
Loc: IN, USA
I use this one from Menards on our well water. It does great with the included carbon wrapped filter:
https://www.menards.com/main/plumbing/wa...154&ipos=30
I get about 6 months between changes but the filters look rusty real quick!
#4547068 - 10/18/17 11:08 AM Re: Whole house filter? [Re: Matagonka]
callbay Offline
Loc: Ozark Mountains
I have a private well at my house and I had a whole house filter. No water problems but just wanted to filter it.
I quit using it as after two weeks of a new filter the water would start to smell. No smell before the filter was installed. Guess it caused the bacteria to build up.
#4547084 - 10/18/17 11:27 AM Re: Whole house filter? [Re: Matagonka]
benjamming Offline
Have you had your water analyzed?
#4547155 - 10/18/17 12:28 PM Re: Whole house filter? [Re: Matagonka]
IndyIan Offline
Loc: Ontario, Canada
Maybe try your water without the filters now? We ran an iron/particle filter for the first couple months using our well, as we were pulling up sand sometimes and we were getting mild iron staining. But after a few months it seemed to clean up and we just removed the filters, as they seemed to be made to smell wether they filter anything or not. The iron also disappeared when we put in our water softener.
We were also running a 3/4" hose right off the pressure tank which makes the well produce fast and perhaps cleaned out most of the sediment that way. Maybe try that, run the well as fast as you can and as low as you dare to clean the sediment out in one go?
07 Focus ZXW, 5spd manual, 206km M1 5W30
18 Outback 2.5 CVT 5km FF
#4548923 - 10/20/17 06:39 AM Re: Whole house filter? [Re: benjamming]
Matagonka Offline
Loc: NC
Yes, here.
