Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
27 registered members (aleneros, csandste, Bailes1992, BlakeB, 4 invisible), 780 guests, and 37 spiders.
Topics290,867
Posts4,851,566
Members66,044
Most Online3,590
Jan 24th, 2017
adjustable grease coupler? #4546713
10/17/17 10:18 PM
10/17/17 10:18 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
I asked around at two auto parts stores and nobody heard of one. I heard about it on here, but haven't found any. This OEM branded grease gun I bought has a 4 jaw coupler on it and you could put it on the zerk fitting, but you needed to grab it with a pair of pliers and hope you didn't break off the zerk fitting in the process. I just went to oreilys and got a different brand and this one has 3 jaws and it still a little hard to remove, but usually comes off okay if you move it back and forth and rotate at the same time. I've never had this problem before honestly, but then again this is the only grease gun with a flexible hose, so maybe that's why. The other ones I can just grab the entire grease gun and pull it off.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: adjustable grease coupler? [Re: motor_oil_madman] #4546733
10/17/17 10:53 PM
10/17/17 10:53 PM
USA
Reddy45 Offline
Reddy45  Offline
USA
The end of the coupler should be threaded so you can adjust the claw tension. Play around with the tension until you find where it has enough grip to not slip off during injection.
Re: adjustable grease coupler? [Re: motor_oil_madman] #4546998
10/18/17 09:41 AM
10/18/17 09:41 AM
Connecticut, USA
bmwpowere36m3 Offline
Connecticut, USA
Lock 'n Lube.... once you try, you won't go back.
Re: adjustable grease coupler? [Re: Reddy45] #4547193
10/18/17 12:55 PM
10/18/17 12:55 PM
Houston, Texas
Houston, Texas
I think it threads up against an oring. So you can loosen it a little, but it will leak out grease if you loosen it a little too much. Is it supposed to be that way?
