Yes, that is a quality Dexron VI ATF. It will give you many miles with no problems, since it is licensed Dexron VI and formally approved by GM
Walmart's ST Synthetic multi ATF is probably rebranded Mag1 (in regions that get their ATF from WPP). They make a lot of the house brands and also Peak.
Originally Posted By: slacktide_bitog
...Walmart's ST Synthetic multi ATF is probably rebranded Mag1 (in regions that get their ATF from WPP).
That caveat seems to be the key. STMVLV (low viscosity) made by WPP as noted very likely identical and carries GM licenses for GM Dex VI and Mercon LV. Guessing it's less expensive and more readily available than Mag 1. If one wants the Licensed product need to make sure it's the WPP made STMVLV though.
Actually , I was shopping for full synthetic . However , I have read a couple of guys have recommended it in Chevy Cruze , which use the same transmission as our Sonic .
