Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
29 registered members (Brad_C, bbhero, c502cid, 5 invisible), 531 guests, and 59 spiders.
Topics286,442
Posts4,908,263
Members67,622
Most Online2,967
Mar 10th, 2019
Warren Distributing #4546499
10/17/17 06:34 PM
10/17/17 06:34 PM
Texas
WyrTwister Offline OP
Texas
Would this be a good Dexron 6 ?
Thanks , :-)
https://jet.com/product/Warren-Distribut...5bc95faa1463f81
Wyr
God bless
Re: Warren Distributing [Re: WyrTwister] #4546519
10/17/17 06:55 PM
10/17/17 06:55 PM
USA
slacktide_bitog Offline
USA
Yes, that is a quality Dexron VI ATF. It will give you many miles with no problems, since it is licensed Dexron VI and formally approved by GM smile
Walmart's ST Synthetic multi ATF is probably rebranded Mag1 (in regions that get their ATF from WPP). They make a lot of the house brands and also Peak.
Re: Warren Distributing [Re: WyrTwister] #4546735
10/17/17 11:04 PM
10/17/17 11:04 PM
Texas
Texas
Thanks
Wyr
God bless
Wyr
God bless
Re: Warren Distributing [Re: WyrTwister] #4547214
10/18/17 01:17 PM
10/18/17 01:17 PM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
Supertech Dex VI is the same if not very similar and is cheaper. As long as it is certified for Dex VI you can be assured it is a good quality.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: Warren Distributing [Re: slacktide_bitog] #4547993
10/19/17 08:33 AM
10/19/17 08:33 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Originally Posted By: slacktide_bitog
...Walmart's ST Synthetic multi ATF is probably rebranded Mag1 (in regions that get their ATF from WPP).
That caveat seems to be the key. STMVLV (low viscosity) made by WPP as noted very likely identical and carries GM licenses for GM Dex VI and Mercon LV. Guessing it's less expensive and more readily available than Mag 1. If one wants the Licensed product need to make sure it's the WPP made STMVLV though.
Topic covered well HERE.
Re: Warren Distributing [Re: WyrTwister] #4550690
10/22/17 02:29 AM
10/22/17 02:29 AM
Texas
Texas
Ended up ordering 12 quarts of this ;
https://shop.advanceautoparts.com/p/cast...ipped-_-General
Actually , I was shopping for full synthetic . However , I have read a couple of guys have recommended it in Chevy Cruze , which use the same transmission as our Sonic .
Thanks for the help , ;-)
Wyr
God bless
Re: Warren Distributing [Re: WyrTwister] #4554651
10/25/17 10:01 PM
10/25/17 10:01 PM
pa
benjy Offline
benjy  Offline
pa
many lubricants use synthetics in the formulation to meet a spec or certification DEX VI is one of them, so the brand matters little $$$$
