Employer Exit Interview.
by JustinH
5 minutes 13 seconds ago
Ceratec vs. Archoil 9100
by Phishin
8 minutes 49 seconds ago
Acclaim radiator ?
by urrlord
11 minutes 3 seconds ago
Understanding Idle Control Circuit
by artbuc
59 minutes 4 seconds ago
Annual drain on Mobil1 5w20 high mileage?
by ryan2022
Today at 07:36 AM
Best Oil For Late Model Toyota V6 Engines ?
by ChrisD46
Today at 06:58 AM
Ford 4.6L Durability?
by Auae85
Yesterday at 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
Yesterday at 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
Yesterday at 10:01 PM
Fireworks Stores
by Warstud
Yesterday at 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
Yesterday at 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
Yesterday at 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
Yesterday at 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
Yesterday at 08:49 PM
My FIL in hospice
by fdcg27
Yesterday at 08:41 PM
Spraying Polyurethane
by Texican
Yesterday at 08:37 PM
Dehumidifier icing
by Kestas
Diesel lube in Petrol Engine
by Ducked
Yesterday at 07:46 PM
New key programming cost
by 92saturnsl2
Yesterday at 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
Yesterday at 07:09 PM
ronw1309, Suth31, yamahaboy125, Turboholic, TrpNY
65284 Registered Users
82 registered (Alex_V, 2004tdigls, ARCOgraphite, andyd, A310, ArrestMeRedZ, 9 invisible), 1336 Guests and 37 Spiders online.
65284 Members
67 Forums
285691 Topics
#4546426 - 10/17/17 04:56 PM BG44K better than Seafoam / MMO?
StevieC Offline
Loc: Ontario, Canada
'15 Dodge Journey - 90,000 KM's - SSO 5w20
'06 Hyundai Santa Fe - 535,000km - SSO 0w30 (R.I.P)
#4546433 - 10/17/17 05:12 PM Re: BG44K better than Seafoam / MMO? [Re: StevieC]
Donald Offline
Loc: Upstate NY
Well anything is better than MMO.
For what use??
Techron is the best for fuel injection cleaning.
2015 Ford F250 w/Powerstroke
#4546447 - 10/17/17 05:34 PM Re: BG44K better than Seafoam / MMO? [Re: StevieC]
SEMI_287 Offline
Loc: Up State NY
Didn't seem to do any better or any worse than Seafoam or MMO.
2005 BMW 325xi- M1 0W40, Mann
2008 Mitsubishi Galant- Parts Master 5w30, Wix
#4546453 - 10/17/17 05:42 PM Re: BG44K better than Seafoam / MMO? [Re: StevieC]
StevieC Offline
I just posed the question in the video... Wasn't suggesting anything.
#4546456 - 10/17/17 05:43 PM Re: BG44K better than Seafoam / MMO? [Re: Donald]
StevieC Offline
For what use??
For injectors yes, for combustion chamber no. wink
#4546483 - 10/17/17 06:11 PM Re: BG44K better than Seafoam / MMO? [Re: StevieC]
tig1 Offline
Loc: Illinois
I have used MMO for years every 3-6 fill ups at the 4 OZ per 10 gals. I guess it works because I have never had a fuel system problem. Who knows.
2007 Ford Fusion 227,000 miles
M1 0-20 EP
2017 Ford Fusion 49K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4546490 - 10/17/17 06:16 PM Re: BG44K better than Seafoam / MMO? [Re: StevieC]
StevieC Offline
I use a high PEA cleaner every oil change just before the oil change. Never had any issues. I used to use Lucas in the Santa Fe as a UCL / mild cleaner but the pricing got stupid.
#4546524 - 10/17/17 07:00 PM Re: BG44K better than Seafoam / MMO? [Re: StevieC]
JLawrence08648 Offline
Loc: NJ
I don't think anything is better than Seafoam.
#4546537 - 10/17/17 07:08 PM Re: BG44K better than Seafoam / MMO? [Re: StevieC]
CT8 Offline
Loc: Idaho
What is in Seafoam that does anything?
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4546659 - 10/17/17 08:46 PM Re: BG44K better than Seafoam / MMO? [Re: CT8]
stevo585 Offline
Loc: Orlando, FL
Look at the MSDS, its mostly Naphtha...a solvent.
I personally use Aces IV. Even my girlfriend noticed a difference in her Camry when I put it in.
2014 Subaru BRZ, Turbo'ed @ 10psi, ~320hp
M1 HM 10w-30, Subaru filter
2014 Toyota Camry - M1 EP 5w-20
#4546665 - 10/17/17 08:53 PM Re: BG44K better than Seafoam / MMO? [Re: StevieC]
StevieC Offline
Honestly sucking up some warm water through a small vacuum line when the engine is at full temperature and revving at 1500rpm seems to do more than any of this dump it in the tank stuff when it comes to valves and chambers.
For injectors yes they work. PEA heavy products or Seafoam (From what I have seen first hand)
Just my experiences ripping engines apart.
You have to be careful with the water not to overdo it or you can pit the pistons. But slowly in small amounts in spurts it works. Does good for carbon in the Cat as well.
Then take it out on the highway and floor it a few times.
I'm sure this is controversial but I have seen the difference on the piston tops / valves with my camera I send down the spark plug tubes and turning the engine over slowly by hand to see the valve conditions.
Edited by StevieC (10/17/17 08:55 PM)
#4546667 - 10/17/17 08:55 PM Re: BG44K better than Seafoam / MMO? [Re: StevieC]
StevieC Offline
Ever see intake valves / combustion chambers where an engine is burning coolant. wink
#4546686 - 10/17/17 09:28 PM Re: BG44K better than Seafoam / MMO? [Re: StevieC]
Pajero Offline
Loc: Rio Rancho, NM
I've read that BG 44K formula changed for the worst years ago. Is this true?
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
#4546903 - 10/18/17 07:41 AM Re: BG44K better than Seafoam / MMO? [Re: StevieC]
LeakySeals Offline
Loc: Hudson, NH
The base oil in a cleaning product is good, because it makes a better coating, better soak. Solvents last longer before evaporation. That same oil base is bad for the catalyst of a modern auto engine for the same reasons. Fouls your catalyst with combusted "pale oil" (the white smoke in a Seafoaming). Hard to burn off. Some of the old school chemicals age the catalyst, making it less effective. Why the trend is toward PEA based solvents with little or no oil base. Less effective in the combustion chamber? Probably because the product flashes off sooner. But PEA products work great in the tank and injectors. So IMO save the old school pale oil based solvents for non cat engines like lawnmowers, tractors, etc. Thats where Seafoam shines. Originally created for a 1932 fishing boat motor, the IPA works well for water in gas issues.
I had a peek at my 06 Escalade piston tops when I was replacing the knock sensors last year. It burns zero oil. Zero at 150k. Nice and clean. I also had a look at my 04 camry DD I4 that was a burner. Filthy piston tops. Filthy valves. So IMO if you really want to battle a dirty combustion chamber, fix the oil burning problems.
06 Escalade 6.0L AWD 160k. M1 5w30 Fram TG
03 Maxima 3.5L 149k ST HM 10w30
#4546987 - 10/18/17 09:21 AM Re: BG44K better than Seafoam / MMO? [Re: tig1]
LeakySeals Offline
Loc: Hudson, NH
Noticed in your sig one of the 10k OCI M1 since new Fusions was replaced with a new one. What happened to it????
