Pennzoil - SN Plus and 0W-16 Q&A
Click here to participate in the Pennzoil Q&A
2018 Subaru Crosstrek 2.0L
by RetiredSux
03/17/18 02:57 PM
by RetiredSux
03/17/18 02:55 PM
Installing Delo 400 SD 15w30 today...
by FlyNavyP3
03/17/18 02:50 PM
Now what never ends
by CourierDriver
03/17/18 02:13 PM
4WD Actuator or Transfer Case Motor?
by iunderpressure
03/17/18 01:54 PM
Do You use a fuel additive ? Why?
by andyd
03/17/18 01:42 PM
Disabling Autoplay on Panasonic TV YouTube App
by john_pifer
03/17/18 12:56 PM
old Mazda V6 timing belt change - photos
by Number_35
03/17/18 12:51 PM
Any amateur (HAM) radio folks here?
by Deltona_Dave
03/17/18 12:42 PM
Cancer in dogs after ACL repair
by Donald
03/17/18 12:38 PM
M1 10W30 2015 Silverado 5.3L
by Realtech214
03/17/18 12:36 PM
How to do a piston soak correctly?
by marantz_fan
03/17/18 11:56 AM
Pennzoil Pure Plus EU 0W-40 question
by mctmatt
03/17/18 11:15 AM
2016 Chrysler Town and country metal specs in oil
by turboaccord1
03/17/18 10:07 AM
Wood boards as a backup for Rhino ramps—how high?
by paulri
03/17/18 10:01 AM
Anyone cringe when someone drives your car?
by BAJA_05
03/17/18 09:47 AM
Servicing TUFF TORQ K61 & K62
by Gebo
03/17/18 09:33 AM
GE 9x first flight
by tom slick
03/17/18 08:15 AM
What kind of vehicle ramps do you use?
by ZZman
03/17/18 08:01 AM
Storing your new truck?
by Char Baby
03/17/18 06:33 AM
3one7, Lubrizol, bdunigan, Sarahw, DejaVue
64484 Registered Users
84 registered (93cruiser, 6x6man, 69Torino, Aero540T, Altima2, 11 invisible), 1828 Guests and 96 Spiders online.
64484 Members
68 Forums
279947 Topics
#4546422 - 10/17/17 04:50 PM Holding Rubber Door Molding in Place?
Gebo Offline
Loc: VA
The black rubber door weather stripping molding is coming loose and dropping down in a couple of places on my 4Runner. What is the best "cement" I can use to hold it in place? I'll stretch in back in place in the corners and a week later it has sagged again.
'98 LEX LS400 280K
'00 LEX GS300 190K
'02 4Runner 225K
'05 Lex LS430 80K
'06 Toyota Highlander 140K
'09 Lex IS350 80K
#4546435 - 10/17/17 05:14 PM Re: Holding Rubber Door Molding in Place? [Re: Gebo]
SilverSnake Offline
Loc: Florida
Permatex Black Silicone Adhesive Sealant
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2014 Ram 1500,5.7L-395 HP (PUP 5W-20)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2008 20KW Generac (Amsoil 10W-30/30)
#4546443 - 10/17/17 05:31 PM Re: Holding Rubber Door Molding in Place? [Re: Gebo]
JHZR2 Offline
Loc: New Jersey
Mercedes uses a product like rubber cement but with more solvent. Lasts >30 years.
#4546449 - 10/17/17 05:35 PM Re: Holding Rubber Door Molding in Place? [Re: Gebo]
StevieC Offline
Loc: Ontario, Canada
Contact cement. (Yellow Stuff, not the clear stuff)
Apply to both pre-cleaned sides. Let sit for 20 minutes apart and then stick together. Should hold forever.
If it's a hallow type tube you could also get thin Neodymium magnets and slip one inside.
Edited by StevieC (10/17/17 05:38 PM)
'15 Dodge Journey - 90,000 KM's - SSO 5w20
'06 Hyundai Santa Fe - 535,000km - SSO 0w30 (R.I.P)
#4546475 - 10/17/17 06:01 PM Re: Holding Rubber Door Molding in Place? [Re: Gebo]
DBMaster Offline
Loc: DFW
Easy to get and cheap.
Weatherstrip Adhesive
#4546549 - 10/17/17 07:15 PM Re: Holding Rubber Door Molding in Place? [Re: Gebo]
Merkava_4 Offline
Loc: Clovis, CA
The answer is right in your opening post: "weather stripping" adhesive.
I'd recommend either 3M or Permatex. Read the instructions carefully because with some of that stuff you're supposed to apply one coat to one surface and then two coats to the other surface before bonding.
#4546601 - 10/17/17 07:46 PM Re: Holding Rubber Door Molding in Place? [Re: Gebo]
HoosierJeeper Offline
Loc: WI
I've used plain clear silicone before, no issues.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
#4546640 - 10/17/17 08:30 PM Re: Holding Rubber Door Molding in Place? [Re: Gebo]
Wheel Offline
Loc: Upstate NY
3M Fast Tack Trim Adhesive gets my vote. It is a contact type cement. Removal may be somewhat difficult. I use it to glue on bicycle tires too.
2009 Subaru Legacy (N/A)
Castrol Edge and Subie (Fram) filter
#4546650 - 10/17/17 08:39 PM Re: Holding Rubber Door Molding in Place? [Re: Gebo]
JamesBond Offline
Loc: midwest
How was it held in place originally?
Many cars have plastic push pins that fit through a hole in the rubber and pop into a hole in the door metal.
I've had an older Toyota where the rubber tears around the hole that the push pin goes into. I've put the pin in the rubber then glued the rubber together with rtv, then once it dries push the pin into the door hole. Then treat with silicone to prevent freezing and tearing in the winter.
#4546706 - 10/17/17 10:05 PM Re: Holding Rubber Door Molding in Place? [Re: Gebo]
BigD1 Offline
Loc: NC
3M black Super Weatherstrip adhesive is what I use. I use a bead in the center of the weatherstrip, and then put another bead on the area that the weatherstrip attaches. It works very good.
1992 Toyota Pickup--Havoline HM 10W-30--Motorcraft FL-910S
#4546740 - 10/17/17 11:13 PM Re: Holding Rubber Door Molding in Place? [Re: Gebo]
ag_ghost Offline
Loc: SF Bay Area, CA
+1 to the above for 3M or Permatex. I used 3M black on my Mustang's trunk lid last January with success (following the directions to let the adhesive 'cure' a few moments before placing the weather strip), preparing the rubber with some brake cleaner to remove any mold release agent that may have emerged. I also used some blue painter tape to hold everything in place until it set. And, of course, the paint surface needs to be as clean as possible; not to mention that some suppliers sell better quality parts than others.
Edited by ag_ghost (10/17/17 11:17 PM)
63 Galaxie 500, 390; dad bought it new...
99 Accord V6
15 CR-V
#4546743 - 10/17/17 11:36 PM Re: Holding Rubber Door Molding in Place? [Re: DBMaster]
Rolla07 Offline
2007 Corolla Red Pearl 151k miles
Castrol Magnatec 0w20 & Napa Proselect
#4548032 - 10/19/17 09:00 AM Re: Holding Rubber Door Molding in Place? [Re: SilverSnake]
Silverado12 Offline
Loc: Central Virginia
This is what I use too.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
16 Challenger R/T Shaker 5.7 manual B5 blue
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
