I have a snapper 21" self propelled mower. It has the Briggs 190cc engine. After of about 1 year of using it,for the past couple of months it is having a hard time starting. It used to start on the first pull every time,whether if the engine was hot or cold. It now takes approx 3 -7 pulls before it will start. It's usually around 4-5 hard pulls to typically start.
I have done all the required maint.,so If anyone can share some wisdom regarding this issue please advise.
Thanks!
Thanks!
