2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
106 registered members (240_Ed, 1foxracing, Bailes1992, bandito, Astro14, 11 invisible), 1,701 guests, and 38 spiders.
Topics295,211
Posts4,930,031
Members66,711
Most Online2,553
Oct 27th, 2018
Is Valvoline pushing Maxlife ATF too far? #4546215
10/17/17 11:35 AM
10/17/17 11:35 AM
Illinois, U.S.A
RamFan Offline OP
RamFan  Offline OP
Illinois, U.S.A
It has been entirely too long since I've been active on this site! It's certainly changed since I first joined. But I digress...
For those of you that don't know, Mazda requires the use of FZ tansmission fluid. Not a lot is known about this fluid (from what I gather) other than it being an ultra-low viscosity fluid and that it's blue. According to the manual, our units are filled for life and don't need service. Seeing as how there is a fill hole, drain plug and a dipstick, I certainly plan on changing it out. For nothing more than purely simplistic reasons, I've decided to change the fluid in the trans, transfer case and rear diff at 60k miles. While mine is a little over half way there, my mom's '14 CX-5 is about 10k miles shy.
I decided to explore and see if anyone had started producing FZ fluid yet. Nope, no one really has. I did find one product that's in Europe but the site was crudely translated and I was unable to find purchasing/shipping information. From what I can find, purchasing the Mazda OE fluid is the only option. For giggles I decided to check out Maxlife as that's what I run in the Monte with great results. I'm not really a fan of "one size fits all" when it comes to automotive products, but the specs of Dex-VI and Maxlife are nearly identical which is why I decided to try it out. I've done two fluid changes in the Monte with it and it's been working beautifully. Much to my surprise, Valvoline is recommending Maxlife in FZ applications. I was also surprised to see that since the last time I viewed their PDS, it seems as though they've added quite a few specs that are now recommended.
I remember Valvoline's rebuttal when PQIA questioned them on their label claims, it was fairly straightforward and seemingly genuine. However, I find it a little hard to believe that this product can genuinely be recommended for all of these applications, is it truly that good, or is Valvoline playing a game of chance on possible payouts from failed transmissions? They still don't recommend the product for ATF +4 applications, so clearly there are some boundaries that they're not willing to push. The question still remains though.
For those curious, the newest PDS can be found here.
18 Giulia Ti Sport Q4
+2.0l turbo - 4k - PP Euro LX 0w30 - Mopar - 10k/1yr
16.5 CX-5 Touring AWD
+2.5l - 50k - SynPower w/ Maxlife 0w20 - PureOne - 8k/1yr
Re: Is Valvoline pushing Maxlife ATF too far? [Re: RamFan] #4546240
10/17/17 11:58 AM
10/17/17 11:58 AM
NC
fenixguy Offline
fenixguy  Offline
NC
popcorn
I too would like to know some more about Maxlife ATF. I've been searching for a suitable replacement for the Hondas and eventually the Frontier (when out of warranty). It seems that Valvoline markets this stuff as suitable for everything.
It's strange to me that Nissan recommends Matic D in the T-case and Matic S for the transmission but Maxlife claims to meet the requirements for both...
BTW, I've never heard of a blue ATF. I'd stick with OEM just for that! grin
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
Re: Is Valvoline pushing Maxlife ATF too far? [Re: RamFan] #4546250
10/17/17 12:17 PM
10/17/17 12:17 PM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
Manufacturer test a lot of corner cases (i.e. extreme heat, humidity, altitude, fuel trim, load, wear condition, fuel economy) that rarely happens in practice for most people.
Aftermarket usually are good enough for the non corner cases (i.e. moderate temperature, humidity, altitude, load, don't care for fuel economy) that they will work for 999/1000 customers, and if the 1/1000 fail, 1/10000 will ask for a warranty claim and the other 9/10000 just didn't know it was bad and keep driving until the car retires. Valvoline probably bought a couple Mazda with FZ ATF and use as their company car for 3 years, then tear it down to check for wear and tear, then "recommend" it if it wears about the same as the OEM fluid.
The usual problem I see is that if you have something else went bad the OEM will try to weasel out of a warranty claim. For the first 120k I'd stick with OEM to avoid this trouble.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Is Valvoline pushing Maxlife ATF too far? [Re: RamFan] #4546303
10/17/17 01:25 PM
10/17/17 01:25 PM
On your screen
OhOMG Offline
OhOMG  Offline
On your screen
So, the question here is as to the certification of Maxlife as a Mazda FZ replacement fluid?
The Maxlife that meets Mercon LV is a low viscosity fluid; unsure about ultra-low viscosity, but it does seem to do exceptionally well where the range of it is about the same.
Re: Is Valvoline pushing Maxlife ATF too far? [Re: OhOMG] #4546360
10/17/17 02:34 PM
10/17/17 02:34 PM
Illinois, U.S.A
RamFan Offline OP
RamFan  Offline OP
Illinois, U.S.A
I mean, if someone has data on Mazda FZ fluid so that we could do some comparative "analysis", then sure that would be great. That wasn't really the point of my post though. More of just a prompt for what hopefully could become constructive conversation between knowledgeable board members.
Re: Is Valvoline pushing Maxlife ATF too far? [Re: RamFan] #4546371
10/17/17 02:44 PM
10/17/17 02:44 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
It seems that is just dyed ATF (J)WS 3309 fluid...(according to some standards wich are overlaping)... . Pretty common ATF here over the pond....
https://www.mobil.com/english-us/passenger-vehicle-lube/pds/glxxmobil-atf-3309
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Is Valvoline pushing Maxlife ATF too far? [Re: RamFan] #4546375
10/17/17 02:46 PM
10/17/17 02:46 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Re: Is Valvoline pushing Maxlife ATF too far? [Re: RamFan] #4546398
10/17/17 03:17 PM
10/17/17 03:17 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
On an opieoil site above you can get PDS for (almost) all the oils they sell...just click on the individual oil...
You will discover pretty soon that standards from different manufacturers overlap...
And that you dont have to google ilusive Mazda FZ spec. when you have other bigger players here as Toxota... Vw... GM etc smile
Its the same with a car oils....all you have to look at are BMW-MB-VW standards...everything else is not important smile
Use your common sense!
Re: Is Valvoline pushing Maxlife ATF too far? [Re: RamFan] #4546470
10/17/17 04:55 PM
10/17/17 04:55 PM
Texas & Global
4WD Offline
4WD  Offline
Texas & Global
Yes, Maxlife is so close to Dex VI that I run it in the Cruze
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: Is Valvoline pushing Maxlife ATF too far? [Re: RamFan] #4546520
10/17/17 05:56 PM
10/17/17 05:56 PM
USA
slacktide_bitog Offline
USA
Maxlife will work fine in your transmission with no problems smile
Re: Is Valvoline pushing Maxlife ATF too far? [Re: fenixguy] #4546595
10/17/17 06:43 PM
10/17/17 06:43 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Originally Posted By: fenixguy
popcorn
I use it in our 08 CRV. Works just fine. I even use it in my Tacoma.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Is Valvoline pushing Maxlife ATF too far? [Re: RamFan] #4546671
10/17/17 08:05 PM
10/17/17 08:05 PM
Ohio
hallstevenson Offline
Ohio
Go to your Mazda dealer and ask them what ATF they use. Good chance it's not "FZ".
Re: Is Valvoline pushing Maxlife ATF too far? [Re: RamFan] #4546902
10/18/17 06:41 AM
10/18/17 06:41 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
I'll say flat out I don't know about Mazda FZ. I suppose if I didn't believe the ML PDS, I simply wouldn't use it for that application.
And since the PQIA warning/alert for ML Dex/Merc broached, explanation made sense to me. And apparently to PQIA too as they amended the alert. Dex/Merc an old spec and now with synthetic ATFs, lower initial/starting viscosity is the norm. And while Synthetic ATF like ML start lower, they have much greater shear stability than mineral based ATF with higher starting viscosity like older Dex/Merc. MolaKule has thread in technical papers sub forum about the topic.
It's true ML has added some additional 'suitable for' applications, including Honda DW1. Currently using ML in a couple Hondas specing Z1 and a Tacoma specing Dex ll/lll, out of vehicle warranty I'd use it for a DW1 application too if I had one. I say out of warranty as CYA with a nod to potential warranty denial.
Re: Is Valvoline pushing Maxlife ATF too far? [Re: Sayjac] #4546925
10/18/17 07:11 AM
10/18/17 07:11 AM
Texas & Global
4WD Offline
4WD  Offline
Texas & Global
ML ATF just seems like a great value. Im shopping ATF and Castrol was a semi at $8/qt Valvoline Dex syn about that ML $19/gallon and I needed exactly a gallon jug to D&F (jug to collect used oil)
Re: Is Valvoline pushing Maxlife ATF too far? [Re: RamFan] #4547086
10/18/17 10:31 AM
10/18/17 10:31 AM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
...They still don't recommend the product for ATF +4 applications, so clearly there are some boundaries that they're not willing to push. The question still remains though.
What question is that (just trying to understand you core question)? smile
Valvoline doesn't cover the ATF +4 because the ATF +4 spec has a different dynamic coefficient of friction spec than does the DexronIII/Mercon series of dynamic coefficient of friction specs.
The reason Valvoline is recommending the Mazda coverage is because the additive supplier is confident its testing can support that coverage.
If the color is Blue, that simply means they are using a "tag" for warranty purposes.
BTW, I think the Mazda 60k OCI for the tranny is simply a CYA type of thing that gets you up to the warranty period but not beyond. Most driving habits today falls into the Severe Duty category.
Scars remind us of where we have been, but do not have to dictate where we are going.
