125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
22 registered members (2015Corolla, bernau, 08z06, CharlieBauer, bmod305, avi1777, 3 invisible), 726 guests, and 35 spiders.
Topics290,617
Posts4,847,573
Members66,011
Most Online3,590
Jan 24th, 2017
Jacking/ramping a car on a gravel driveway? #4546006
10/17/17 09:20 AM
10/17/17 09:20 AM
Rochester, MI, US, World
Klutch9 Offline OP
Klutch9  Offline OP
Our new house has a gravel driveway. The good is that any leaks/spills will be disguised. The not so good is that it'll make working on a vehicle a little trickier. Since I've always had pavement to work on previously, I'm wondering what you all do. I thinking that for using jack stands, a chunk of 2x6 under the stand will suffice, no? As far as using ramps, that seems a bit more tricky. The gravel/stone isn't completely level, and my plastic Rhino ramps may not agree with being twisted while carrying the weight of a vehicle. Thoughts?
'11 Fusion SE 2.5L - 79k miles - HK 0w20 syn, Wix XP filter
'08 Sedona LX LWB 3.8L - 126k miles - Havoline HM 5w20, Auto7 filter
Re: Jacking/ramping a car on a gravel driveway? [Re: Klutch9] #4546008
10/17/17 09:24 AM
10/17/17 09:24 AM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
Put a good sized piece of plywood down where you need to put your jack / stands to distribute the weight properly. Make sure it's good and seated as level as possible.
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: Jacking/ramping a car on a gravel driveway? [Re: Klutch9] #4546011
10/17/17 09:30 AM
10/17/17 09:30 AM
NC
BigD1 Offline
BigD1  Offline
NC
Exterior grade 3/4 inch plywood is what I use. Gravel does not dig in your back side either.
1992 Toyota Pickup--Formula Shell 10W-30--Fram PH3614
Re: Jacking/ramping a car on a gravel driveway? [Re: Klutch9] #4546023
10/17/17 09:42 AM
10/17/17 09:42 AM
NC
fenixguy Offline
fenixguy  Offline
NC
I use Rhino ramps on gravel and grass all the time. hide I've used the old metal ramps before, but they sink into the ground and don't really inspire a lot of confidence when under a car. I don't have any pavement or concrete to work on. When I have to jack the car up, I put a floor jack on a 3/4 inch think piece of plywood so the jack can roll under the car the way it's supposed to. For using stands (always, always, always when lifting the car), I found a set of front brake rotors off of a '99 Subaru Outback make the perfect base to set my jack stands on. I always give the car a little shake before getting under it.
My personal opinion, I would use something a little wider than a 2x6 for the jack stands. You want a very solid base that won't move at all in any direction. I've even thought of making some custom ramps out of 2x10s but they would be extremely heavy for what I have in mind.
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
Re: Jacking/ramping a car on a gravel driveway? [Re: Klutch9] #4546053
10/17/17 10:14 AM
10/17/17 10:14 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
If the gravel is dry then I just use my metal ramps directly on it. If its soft at all I'll throw a board under the weight bearing ends of the ramps.
I have a 1x10 8' white oak board that I use for that and also I slide it under the car to let a regular jack roll. Keep some cardboard from a large appliance box to lay down and you can slide under the car pretty comfortably and acts as a clean "floor" to put parts and tools on.
07 Focus ZXW, 5spd manual, 210km M1 5W30
18 Outback 2.5 CVT 10km 0W20 "bulk subaru" whatever that is
Re: Jacking/ramping a car on a gravel driveway? [Re: Klutch9] #4546056
10/17/17 10:20 AM
10/17/17 10:20 AM
Texas
4WD Offline
4WD  Offline
Texas
replaced
Re: Jacking/ramping a car on a gravel driveway? [Re: 4WD] #4546060
10/17/17 10:22 AM
10/17/17 10:22 AM
Texas
4WD Offline
4WD  Offline
Texas
Originally Posted By: 4WD
They are indeed heavy a little exercise never hurts
Re: Jacking/ramping a car on a gravel driveway? [Re: Klutch9] #4546127
10/17/17 11:10 AM
10/17/17 11:10 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
For metal ramps, just weld a piece of angle iron across the front (vertical) leg. More footing area ...
For plastic ramps, I'd try them and shake the car pretty hard before I got under them.
Gravel is what is used as road base. It will hold quite a load if done properly smile
Re: Jacking/ramping a car on a gravel driveway? [Re: 4WD] #4546136
10/17/17 11:17 AM
10/17/17 11:17 AM
NC
fenixguy Offline
fenixguy  Offline
NC
[quote=4WD]They are indeed heavy a little exercise never hurts
So true! That's about what I've had in mind if I ever need anything more heavy duty than the Rhino ramps. In my case, I'd put a wider board on the bottom to give me a little more footprint when working on softer ground.
Re: Jacking/ramping a car on a gravel driveway? [Re: Klutch9] #4546169
10/17/17 11:48 AM
10/17/17 11:48 AM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
I use something similar to what 4WD shows in his pictures. With mine I can use them not only for the front and rear of the car, but I can use them on one side of the car. This helps for things like fuel filters and muffler work.
Re: Jacking/ramping a car on a gravel driveway? [Re: Klutch9] #4546204
10/17/17 12:22 PM
10/17/17 12:22 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
I use 2 X 8, 2 X 10
2019 Cherokee, 2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1984 F150, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Jacking/ramping a car on a gravel driveway? [Re: Klutch9] #4546264
10/17/17 01:39 PM
10/17/17 01:39 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Dont use rhino ramps on gravel if they skid at allor arent supported well... they may self destruct
