New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
Door Hinges
by Scrum67
06/23/18 11:59 AM
PBS, TV channels in different countries
by onetwoothreee
06/23/18 11:29 AM
Break in filter cut open/ Filtermag
by UncleDave
06/23/18 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
06/23/18 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
06/23/18 10:33 AM
Windows 10 Update, version 1803
by Sayjac
06/23/18 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
06/23/18 09:48 AM
Super Tech Conventional 15w40 HDEO. CK-4/SN
by Snagglefoot
06/23/18 09:38 AM
1 gallon jug of Sta-bil for $7 at Rural King
by classic70
06/23/18 09:34 AM
Anger on BITOG
by Gebo
06/23/18 08:55 AM
2010 Acura MDX w/ 3.7 lire oil consumption issue
by Varbill
06/23/18 08:45 AM
Surprising oil filter service interval.
by jakewells
06/23/18 08:12 AM
World Population
by CourierDriver
06/23/18 08:11 AM
SBC Finned Aluminum Dress Up Kit $32
by hatt
06/23/18 07:35 AM
Meguiars
by dslofti
06/23/18 07:20 AM
Roller Bearing Setup For Dillon Shellplate
by billt460
06/23/18 05:59 AM
Omnia - the band
by Shannow
06/23/18 02:58 AM
Guest's devices cannot connect to my WiFi
by boulderdentist
06/23/18 12:54 AM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
87 registered (andyd, 4WD, ArrestMeRedZ, BAJA_05, Astro14, 8 invisible), 1683 Guests and 47 Spiders online.
65299 Members
67 Forums
285849 Topics
Page 1 of 2 1 2 >
#4544887 - 10/16/17 09:09 AM Good, inexpensive oil filter cutter?
Oldtom Offline
Loc: Cecil County Maryland
I want to start cutting oil filters. Can anyone suggest a good cutter priced under $75?
Can sizes are ph 3614 and ph 16
Thanks in advance for any advice.
#4544891 - 10/16/17 09:11 AM Re: Good, inexpensive oil filter cutter? [Re: Oldtom]
StevieC Offline
Loc: Ontario, Canada
'15 Dodge Journey - 90,000 KM's - SSO 5w20
'06 Hyundai Santa Fe - 535,000km - SSO 0w30 (R.I.P)
#4544895 - 10/16/17 09:16 AM Re: Good, inexpensive oil filter cutter? [Re: Oldtom]
JohnnyJohnson Offline
Loc: Wet side WA
You've seen this before but here its cheaper.
https://www.amazon.com/Longacre-77750-Oi...H3HF6PQBZMW4H28
2004 Toyota Corolla 121758
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4544898 - 10/16/17 09:16 AM Re: Good, inexpensive oil filter cutter? [Re: Oldtom]
OneEyeJack Offline
Loc: S California
Hacksaw and sheet metal shears.
#4544901 - 10/16/17 09:19 AM Re: Good, inexpensive oil filter cutter? [Re: Oldtom]
ZZman Offline
Loc: Michigan
2003 Mercury Grand Marquis. Rotella T6 Multi-Vehicle oil
2008 Sebring Hardtop convertible. Rotella T6 Multi-Vehicle oil
2006 Kawasaki Vulcan 900 LT. Amsoil Metric 10w-40
#4544907 - 10/16/17 09:21 AM Re: Good, inexpensive oil filter cutter? [Re: ZZman]
4WD Online   confused
Loc: Texas
Got this one from eBay almost a year ago … looks well made and cuts clean
#4544913 - 10/16/17 09:26 AM Re: Good, inexpensive oil filter cutter? [Re: Oldtom]
SHOZ Offline
Loc: Illinois
Mine is made of a block of aluminum, a steel pipe cutter wheel and a thumb screw. Could be made at home cheap enough.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#4544928 - 10/16/17 09:35 AM Re: Good, inexpensive oil filter cutter? [Re: Oldtom]
Yah-Tah-Hey Offline
Loc: Columbus,Nebraska
I like the Longacre I purchased about three years ago. Believe it was under $75 at the time. smile
#4545008 - 10/16/17 10:41 AM Re: Good, inexpensive oil filter cutter? [Re: 4WD]
motor_oil_madman Offline
Loc: Houston, Texas
that's the one I got. only used it once. I doubt I spent 50 bucks on it though.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#4545023 - 10/16/17 10:56 AM Re: Good, inexpensive oil filter cutter? [Re: motor_oil_madman]
4WD Online   confused
Loc: Texas
Think it was $44 when I got it …
#4545111 - 10/16/17 12:19 PM Re: Good, inexpensive oil filter cutter? [Re: Oldtom]
Lasthope05 Offline
Loc: PA
I just use tin snips to cut the rolled lip. Works well for me and it doesn't cost me a thing
#4545112 - 10/16/17 12:20 PM Re: Good, inexpensive oil filter cutter? [Re: Lasthope05]
JeepWJ19 Offline
Loc: PENNSYLVANIA
This ^
Tin snips are your cheapest option and aren't hard to use. Probably takes me 5 minutes. Could probably be had less than $10 at harbor freight
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
#4545125 - 10/16/17 12:34 PM Re: Good, inexpensive oil filter cutter? [Re: JohnnyJohnson]
Sayjac Offline
Loc: The Old North State
With $75 budget, I consider the Longacre to be the crème de la crème of filter cutters. The Summit/Jegs/ebay less expensive, however I've found on smaller diameter filters, the filter doesn't reach the guide wheels. Yeah it still works, filter edge hits guide bar, but not smoothly. At least one member modified wheels on the guide bar, bigger, closer together.
Me, I'm still using my made in Taiwan HF exhaust cut off tool I bought in 2010 for $15. The later model made in China were junk. Now discontinued.
#4545257 - 10/16/17 04:01 PM Re: Good, inexpensive oil filter cutter? [Re: Oldtom]
earlyre Offline
Loc: Lima, Ohio, USA
i've just used a manual crank food type can opener. pull the gasket, and crank it around the rim a couple rounds...
Mine:
09 Mercury Sable : 6qts AutoQuest(Meijer/Warren) 0w20, WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts VWB 5w30,WIX 51394
#4545337 - 10/16/17 05:14 PM Re: Good, inexpensive oil filter cutter? [Re: earlyre]
Loc: Wet side WA
Hmmm $12.95 sounds a lot better that forty to seventy dollars.
2006 Duramax 74047
Page 1 of 2 1 2 >
