Mobil @ Bomgaars sale
by Duffyjr. 09/23/18 04:45 AM
More California BS!
by dogememe. 09/23/18 04:04 AM
Optimum No Rinse Wash and Wax or Shine?
by anndel. 09/23/18 03:44 AM
Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
23 registered members (Billbert, Bailes1992, BlakeB, bmod305, carviewsonic, 3 invisible), 678 guests, and 57 spiders.
Topics290,870
Posts4,851,596
Members66,044
Most Online3,590
Jan 24th, 2017
2002 Ford F150 with V6 transmittion fluid change #4544819
10/16/17 08:32 AM
10/16/17 08:32 AM
North Carolina
Rat407 Offline OP
Rat407  Offline OP
North Carolina
Going to change out the fluid and filter on a friends 2002 F150 transmission that has the V6 in it.
I was thinking of going with Valvoline Max Life. Good choice? Truck has 179k on it. Fluid is a little brown, kind of, noting major, just not the dark deep red and doesn't smell bad.
Thanks
2002 Silverado 5.3 0w-20 AMSOIL
Re: 2002 Ford F150 with V6 transmittion fluid change [Re: Rat407] #4544827
10/16/17 08:37 AM
10/16/17 08:37 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
I would stick with Mercon V-Valvoline makes a good one (in the blue bottle), I'm using Castrol myself in the MGM's 4R70W.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 2002 Ford F150 with V6 transmittion fluid change [Re: Rat407] #4544843
10/16/17 08:47 AM
10/16/17 08:47 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
What does the owner's manual call for ?
Wyr
God bless
Re: 2002 Ford F150 with V6 transmittion fluid change [Re: Rat407] #4544892
10/16/17 09:14 AM
10/16/17 09:14 AM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
Out in the desert country, a lot of 150 owners use Red Line D4. These people haul stuff and tow horses. The trucks work a bit harder than most and the D4 works well. Just like with my V8 4Runner we drain and refill every 30K or so. In my case, it takes about 4 quarts. I'm somewhere over 165K of hard work and there's no sign of any problems. A couple of the 150 guys are well over 200K with no problems. The D4 is more expensive but I think it's worth the price. We all buy our Red Line stuff from Fallbrook Oil Company in Fallbrook, CA. They carry everything with good discounts.
Re: 2002 Ford F150 with V6 transmittion fluid change [Re: Rat407] #4545021
10/16/17 10:53 AM
10/16/17 10:53 AM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
I have Maxlife ATF in my '02 F150 and my brother in laws '04 F150.
Cleared up the overdrive downshifting "clunk" in mine, my brother in laws truck is shifting smoother now.
I have also used Walmart Supertech Mercon V with no problems either. It is a licensed fluid.
Maxlife no longer says compatible wit Mercon V on the bottle, but their online info still says you can use it in Merc V applications (unless you are in California, then things magically change).
Some complain that Maxlife ATF is too thin for Merc V application, and while the starting viscosity of ML ATF is thinner than Merc V, it is more sheer stable and Merc V has been shown to sheer fast to below what ML ATF starts at.
___________________________
1994 VT1100: Peak 15w-40, TG Filter, 2.5k OCI
2002 F150: Havoline HM 5w-20, Ecogard Filter, 5k OCI
2012 xB: AZ 0w-20 syn, CQ Blue Filter, 5k OCI
Re: 2002 Ford F150 with V6 transmittion fluid change [Re: blupupher] #4545081
10/16/17 11:44 AM
10/16/17 11:44 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
It really depends on the OCI. For 20K-30K miles I doubt a Mercon V in a typical automatic transmission will shear down from 7.4 to 5.8. Literature I've read suggests figure about a 19% shear rate for Mercon V/semi-synthetic fluids per OCI. 19% shear would get you to 5.99. And for much of that OCI you're using a much higher viscosity fluid than a MaxLife Dex VI. Max Life shears too. Even at -3% it would drop to 5.6 cSt. I'd stick with a Merc V viscosity. And if you get a fully synthetic Merc V approved fluid (like Mobil 1 ATF)...then shearing down that far is not an issue. For those that don't change their trans fluids, then a fully synthetic, extremely shear stable Merc V ATF might be a way to go.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: 2002 Ford F150 with V6 transmittion fluid change [Re: Rat407] #4545141
10/16/17 01:00 PM
10/16/17 01:00 PM
North Carolina
Rat407 Offline OP
Rat407  Offline OP
North Carolina
Thanks for the suggestions. Will venture over to the local wally world and see what is on the shelf.
Re: 2002 Ford F150 with V6 transmittion fluid change [Re: 69GTX] #4545479
10/16/17 07:12 PM
10/16/17 07:12 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
+1
Exactly my approach on retaining higher viscosity grade fluid as recommended or selecting oil a grade thicker (at times, at lesser shear stability in the case of ATF like Dexron III) to achieve higher MOFT through higher operating viscosity for components protection ........ and keep a distance away from getting confused and mixed up in 'priorities' with mumbo jumbo marketing terminology like 'fully synthetics', Grp 4/5 oil; 'modern and latest LV oils ' Ilsac GFx, API Sx, etc etc.
Re: 2002 Ford F150 with V6 transmittion fluid change [Re: Rat407] #4549193
10/20/17 11:43 AM
10/20/17 11:43 AM
North Carolina
Rat407 Offline OP
Rat407  Offline OP
North Carolina
Well it turns out the transmission has never been serviced. When I pulled the pan, the dipstick stopper was still in there at 190K. Wish I knew that, I would have taken a sample and sent off to see how the fluid looked. Thanks for all the help.
Re: 2002 Ford F150 with V6 transmittion fluid change [Re: Rat407] #4549852
10/21/17 04:17 AM
10/21/17 04:17 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I remember decades ago finding one of those shipping plugs while doing an ATF change in my Ford. I thought it was a needed part and my tranny was doomed. Anyway, the amount of pan deposits look very good for that mileage. A good example of a well built transmission.
The "thinking" man's friend.
Re: 2002 Ford F150 with V6 transmittion fluid change [Re: Rat407] #4549935
10/21/17 08:12 AM
10/21/17 08:12 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Yes, looks really clean for the age/mileage. That AT will outlive the truck!
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: 2002 Ford F150 with V6 transmittion fluid change [Re: bullwinkle] #4550176
10/21/17 12:46 PM
10/21/17 12:46 PM
Cape Cod, MA
RF Overlord Offline
RF Overlord  Offline
Cape Cod, MA
Just for the sake of complete disclosure, Valvoline's offering is not Ford-approved. Valvoline refuses to buy a license and cannot legally call their offering "Mercon V". They call it "ATF for Mercon V Applications". A few years ago, their product WAS licensed...I don't know exactly when the change occurred. Castrol is licensed, as is SuperTech and (of course) Motorcraft.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
'04 Grand Marquis LS Limited Edition - daily driver
'00 Grand Marquis GS - bad frame/future to be determined
