need brake job but ...
by Bluebonnet. 04/25/19 05:12 PM
UOA on BMW 0w-30 on BMW F10 M5 with S63 TVDI V8
by AirBull. 04/25/19 05:08 PM
What to drink with trail mix?
by das_peikko. 04/25/19 04:55 PM
And This Folks, Is How You Buy Guns
by billt460. 04/25/19 04:43 PM
Tire leak with new wheels. What would YOU do?
by Lolvoguy. 04/25/19 04:20 PM
Red battery light came on, Ford E150.
by laserred96gt. 04/25/19 03:34 PM
2019 NFL Draft
by JustN89. 04/25/19 03:10 PM
Crabgrass!!!!
by gregk24. 04/25/19 03:06 PM
Drain and fill 08 Kia Rio.
by Jetsfan421. 04/25/19 02:59 PM
Cut Open - Mazda OEM @ 7,000kms
by mcwilly. 04/25/19 02:50 PM
Fender bender...headache!
by gregk24. 04/25/19 02:44 PM
Cerwin Vega 10" Subwoofers - $14.37 Each
by Greg L. 04/25/19 01:53 PM
Blain's Farm & Fleet synthetic oil $2.19/qt.
by BrewCityR. 04/25/19 01:24 PM
F1 - 2019 Azerbaijan Grand Prix
by gofast182. 04/25/19 12:00 PM
Installing an additional fuel filter?
by Ed_Flecko. 04/25/19 11:46 AM
Honda self propel only spining left wheel
by Tundragod. 04/25/19 11:38 AM
Cabin Filter Pics (15k miles)
by DoubleWasp. 04/25/19 11:30 AM
LiquiMoly Jectron Fuel Injection Cleaner
by Ddub. 04/25/19 11:12 AM
servicing a 2018 GM 6speed transmission
by gotnogunk. 04/25/19 10:23 AM
Wood9913, Lydia, jdar805866, PreludeDenarius, Ayodejidj
67902 Registered Users
103 registered members (ammolab, 53' Stude, Anduril, 28oz, Andygold, 240_Ed, 12 invisible), 2,072 guests, and 22 spiders.
Topics288,046
Posts4,939,831
Members67,902
Most Online2,967
Mar 10th, 2019
Vertical vs Horizontal Mounting? #4544483
10/15/17 10:07 PM
10/15/17 10:07 PM
Southeast United States
TheLoneRanger Offline OP
I've seen spin-on filters mounted both ways. Which
way is best or does it matter?
Some days you eat the bear, some days the bear eats you.....
Re: Vertical vs Horizontal Mounting? [Re: TheLoneRanger] #4544487
10/15/17 10:19 PM
10/15/17 10:19 PM
Pennsylvania
Reggaemon Offline
Reggaemon  Offline
Pennsylvania
Vertical is a lot easier and cleaner to change.
No oil filter is easier to change than the one on a Subaru FB engine.
Re: Vertical vs Horizontal Mounting? [Re: TheLoneRanger] #4544508
10/15/17 10:34 PM
10/15/17 10:34 PM
Jupiter, FL
thescreensavers Offline
Jupiter, FL
Vertical sucks on my 13 WRX and now 17' SS 1LE both have vertical oil filters that screw from the bottom so once you loosen it it spills oil all over the filter.
My G35 had one at an angle to horizontal that was easy as heck to change without making a mess.
2017 Camaro SS 1LE (Motul 8100 X-clean 5W40)
1997 Jeep XJ 4x4 (15W40 HDEO Maxlife)
Re: Vertical vs Horizontal Mounting? [Re: TheLoneRanger] #4544522
10/15/17 11:00 PM
10/15/17 11:00 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I've had good and bad horizontal ones. Some of my Ford examples would drip all over me no matter what I did. Like thescreensavers's G35, the G37 is canted just so it doesn't make a mess at all. The small block Chevy engines had vertical filters, dome down, but they were fairly well behaved, with a little caution. I'm not too concerned about orientation, provided it's not totally stupid, just as long as the filter is easily accessible without contorting oneself and without putting oneself in the path of spills, and keeping most hardware out of the path of oil spills.
Plain, simple Garak.
Re: Vertical vs Horizontal Mounting? [Re: TheLoneRanger] #4544580
10/16/17 01:41 AM
10/16/17 01:41 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Mine goes on between horizontal and vertical. laugh
Re: Vertical vs Horizontal Mounting? [Re: TheLoneRanger] #4544619
10/16/17 04:47 AM
10/16/17 04:47 AM
Margate England
Claud Offline
Claud  Offline
Margate England
If one way was best they would all be the same. Filters are where they are on any given engine because of design, servicing access, and production costs and considerations.
Claud.
Re: Vertical vs Horizontal Mounting? [Re: Reggaemon] #4544623
10/16/17 05:00 AM
10/16/17 05:00 AM
NE Ohio
knerml Offline
knerml  Offline
NE Ohio
Check out 1980's Mazda RX7s, simular access on top of the engine.
How do you manage oil spilling out of the filter?
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W30 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport AWD 2.0T Castrol Edge 5W40 & OEM/Mann W811/80 Filter
Re: Vertical vs Horizontal Mounting? [Re: TheLoneRanger] #4544633
10/16/17 05:28 AM
10/16/17 05:28 AM
Boonton USA
74DartSport Offline
74DartSport  Offline
Boonton USA
Horizontal that screws from the bottom gets a hole from an awl to drain before I spin it off.
Upholding the 74DartSport™ brand everywhere.
Re: Vertical vs Horizontal Mounting? [Re: TheLoneRanger] #4551538
10/22/17 11:00 PM
10/22/17 11:00 PM
Thanks for the responses. I was mainly referring to spin-on
transmission filters where space won't allow for upright mounting.
If the filter is mounted sideways, then the magnet should be
placed on the downward 'side' of the filter...?
Re: Vertical vs Horizontal Mounting? [Re: TheLoneRanger] #4561427
11/01/17 05:34 PM
11/01/17 05:34 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
That's where I'd put it. Let gravity and magnetism work together.
Re: Vertical vs Horizontal Mounting? [Re: TheLoneRanger] #4569317
11/09/17 10:32 PM
11/09/17 10:32 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Well my thinking is if your filters ADBV is in the up position and it would leak it isn't going to leak up. If its like a Subaru with the ADBV down it drains the whole filter. Mounted side ways it could still drain most of the filter.
2004 Corolla 131000
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
