Canadian Tire Lucas Synthetic Motorcycle Oil 20w50
by Snagglefoot. 09/18/18 07:58 AM
Blast from my past
by 53' Stude. 09/18/18 07:25 AM
Happy Birthday USAF!
by Astro14. 09/18/18 06:35 AM
Ever had a total engine failure?
by Exhaustgases. 09/18/18 02:58 AM
What is the take rate for AWD in small crossovers?
by slacktide_bitog. 09/17/18 11:12 PM
W10 driver for laptop HD4500 graphics
by asand1. 09/17/18 10:03 PM
Horizontal bladder type water tank freezing?
by WobblyElvis. 09/17/18 10:01 PM
Looking for a new carburetor for 2002 honda 90cc
by KeithCoates. 09/17/18 09:57 PM
2013 Passat fluid change
by Chuckh. 09/17/18 09:25 PM
Android Auto Recommendation
by JeffKeryk. 09/17/18 08:57 PM
Prestone Full Synthetic Power Steering Fluid
by TheLawnRanger. 09/17/18 08:55 PM
MAG1 website is excellent
by wemay. 09/17/18 08:46 PM
Does anyone know of a good free 2D cad program
by JimPghPA. 09/17/18 07:42 PM
AC DELCO PF 63E CUT OPEN
by 53' Stude. 09/17/18 06:36 PM
Last time you purchased new vehicle.
by littleant. 09/17/18 05:31 PM
$100 USD Of Gasoline
by GrtArtiste. 09/17/18 03:30 PM
Odd matchbook cover
by skyactiv. 09/17/18 03:29 PM
What are these on my snowblower?
by LeakySeals. 09/17/18 03:12 PM
Which chain lube is the best - Project Farm
by StevieC. 09/17/18 02:53 PM
tomkat22, tabar2004, SierraMan, Rennmeister, KeithCoates
66004 Registered Users
75 registered members (Ablebody, Bear, Black, 2K2AcuraTL, askani79705, 2009Edge, 5 invisible), 1,055 guests, and 36 spiders.
Topics290,581
Posts4,846,845
Members66,004
Most Online3,590
Jan 24th, 2017
The story of multiple codes on my Mazda today #4544467
10/15/17 09:43 PM
10/15/17 09:43 PM
GA
miden851 Offline OP
miden851  Offline OP
GA
The good thing is I fixed it as of right now; Iíll check on it again tomorrow...
So out of nowhere today, while I went to a shopping center about 20 miles away of my place of living, the car started to act strangely; sudden vibration of engine; at first I thought about someone messed my car while I was away but nothing unusual I noticed; meanwhile the sky opened, rain; I moved inside the car and Iíve noticed the engine light was on; I have the OBD scanner but it was at my home 20 miles away; the car was experiencing vibration and was shaking significantly and while it runs right at low speeds, once you reach up to speed it sounds much better; on my way home via interstate I've noticed inconsistency of the check light, while flashing one time, others time is solid; on my way back I stopped to the Advance and they scanned it for the codes; there were three codes P0304, P0171, P2274 so that 4th cylinder was misfiring; from that point I was suggested to step by step elimination process; and thatís what I did;
I swap the coils between the spark plug and no improvement; I want back to the Advance while they were still open, this was at 7:30pm and I got me Denso spark plugs; I replaced them; then there was a change, the car went back to normal; however I found of traces
So tomorrow Iíll watch for the check engine light, and I hope Iíll go back to work in my Mazda; I need my Mazda not gave up on me also if anyone knows more about spark plugs I wanted to see your opinion and what do you say the condition my engine in Mazda
2008 Mazda6i GT; @202K miles
2016 Honda CR-V EX-L; @33K miles
Re: The story of multiple codes on my Mazda today [Re: miden851] #4544469
10/15/17 09:45 PM
10/15/17 09:45 PM
GA
miden851 Offline OP
miden851  Offline OP
GA
Re: The story of multiple codes on my Mazda today [Re: miden851] #4544472
10/15/17 09:47 PM
10/15/17 09:47 PM
GA
miden851 Offline OP
miden851  Offline OP
GA
Re: The story of multiple codes on my Mazda today [Re: miden851] #4544476
10/15/17 09:54 PM
10/15/17 09:54 PM
GA
miden851 Offline OP
miden851  Offline OP
GA
I hope you can see it, this was a last minute change on Sunday!
Re: The story of multiple codes on my Mazda today [Re: miden851] #4544479
10/15/17 09:55 PM
10/15/17 09:55 PM
North Carolina
spasm3 Offline
spasm3  Offline
North Carolina
How many miles on the plugs?
13 elantra 70k 5w30 QSUD
03 chevy avalanche79k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 5600 miles m1 0w30
Re: The story of multiple codes on my Mazda today [Re: miden851] #4544480
10/15/17 09:56 PM
10/15/17 09:56 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Look for a vacuum leak
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: The story of multiple codes on my Mazda today [Re: miden851] #4544482
10/15/17 10:02 PM
10/15/17 10:02 PM
GA
miden851 Offline OP
miden851  Offline OP
GA
I think i noticed an oil spot or two, like spread at the the cylinder head only on 4th while others were clean; Iíve noticed also there was oil on 2nd and 4th spark plug on the outside indicating leak of the valve cover ring
And yes spark plugs have about 60k miles if not more
Re: The story of multiple codes on my Mazda today [Re: Chris142] #4544496
10/15/17 10:26 PM
10/15/17 10:26 PM
NorCal
Seventh Offline
Seventh  Offline
NorCal
This... and then check fuel pressure if you know for certain there is no vacuum or crankcase/pcv leak.
Lean mixture code diagnosis will lead to the cause of the problem. The misfire is the effect.
Re: The story of multiple codes on my Mazda today [Re: Seventh] #4544502
10/15/17 10:30 PM
10/15/17 10:30 PM
GA
miden851 Offline OP
miden851  Offline OP
GA
So how do I check for vacuum and what would be symptoms of a leak in general please
Re: The story of multiple codes on my Mazda today [Re: miden851] #4544517
10/15/17 10:46 PM
10/15/17 10:46 PM
CA
The Critic Offline
The Critic  Offline
CA
What are your short and long term fuel trims at idle and at 2500rpm?
Generally speaking, lean conditions that are worst at idle but get better at 2500 rpm are vacuum leaks. If the lean condition is ok at idle but worsens at high rpm, most likely have a fuel issue.
Inadequate fueling can cause misfires. If you are not able to perform an injector balance test try swapping injectors with cyl 4.
2011 Toyota Prius - 173k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 131K - Mobil 1 EP HM 5W-30
Re: The story of multiple codes on my Mazda today [Re: miden851] #4544518
10/15/17 10:46 PM
10/15/17 10:46 PM
NorCal
Seventh Offline
Seventh  Offline
NorCal
The symptoms are your lean codes, misfires, and your engine runs poorly. You already know that.
Your air fuel mixture is wonky. Too much air and/or not enough fuel. Your air mass meter calculates the amount of air being sucked into the engine so the computer knows how much fuel to inject in order to keep the air fuel ratio stoich.
If your engine is sucking in air (vacuum leak) that is not being accounted for by the air mass meter, the computer doesn't know how to keep the air fuel ratio stoich, the 02 sensor complains, computer adds fuel, once it adds a certain amount it sets codes and or starts misfiring if it can't add enough.
So you're looking for intake hoses/boots that are torn, clamps loose, vacuum lines loose, crank case hoses/connectors leaking or torn, etc. This is best accomplished with a smoke machine. Pump smoke into the intake and it will leak out at your problem areas.
Basically check all the rubber things and their associated clamps first.
Could also be a bad air mass meter or fuel delivery problem but check the basics first.
Re: The story of multiple codes on my Mazda today [Re: miden851] #4544583
10/16/17 01:50 AM
10/16/17 01:50 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
What's up with the spark plug gaps ? Looks like almost a 1/4 inch gap on all four plugs.
Re: The story of multiple codes on my Mazda today [Re: miden851] #4544603
10/16/17 03:54 AM
10/16/17 03:54 AM
Soviet State of Washington
PimTac Offline
PimTac  Offline
I noticed that as well. Some of plugs looked chewed up around the threads too.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
Re: The story of multiple codes on my Mazda today [Re: miden851] #4544690
10/16/17 06:42 AM
10/16/17 06:42 AM
GA
miden851 Offline OP
miden851  Offline OP
GA
I ran that car this morning for about 15min, no check engine light it works just fine; should I still be concerned, or maybe not, I donít know; the car is 10 years and but still just fine car when cranked up or driven.
The spark plugs have antisizure lubricant last time I had replaced them; they look pretty worn out with carbon build up on them; no oil on them specifically.
My scan tool is 10 year old and it doesnít have live update nor live scanning for a possible problems so I cannot confirm fuel trims up or down; prior to my problem, I drove car hard on interstate yesterday, 4-5000 rpms frequently, also used cheap gas on QT in our area in latest weeks; in addition I changed the fuel pump like a month ago and I put 2000 miles on it; my fuel efficiency is good 22-24 everyday; now that Iím changed the pump and spark plugs car feels livelier than before.
Also no hissing sound in engine bay
Re: The story of multiple codes on my Mazda today [Re: miden851] #4545113
10/16/17 12:20 PM
10/16/17 12:20 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
With engine warmed up and running, try spraying carb cleaner around different parts of the engine. In a really bad case you might see it being sucked in, but probably not. What you are really looking for is a change in engine idle. If that happens when you spray a certain spot, you have a vacuum leak there.
Various musings: http://hangfire.net
