Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
119 registered members (AandPDan, 1978elcamino, ABerns, 2015_PSD, 17 invisible), 2,388 guests, and 64 spiders.
Topics286,019
Posts4,900,954
Members67,548
Most Online2,967
Mar 10th, 2019
AC line freezing on truck #4544411
10/15/17 08:38 PM
10/15/17 08:38 PM
Houston, Texas
motor_oil_madman Online content OP
motor_oil_madman  Online Content OP
Houston, Texas
So I asked a question about the ac blowing hot and cold randomly on my truck and I looked at it today and put my hand on the accumulator/drier and it was about as cold as a can of coke, maybe a little warmer. the two lines coming out of it were even colder like 40 degrees. Now their was another long line that went from the firewall over to the fender well and it looked like it was painted white, but it turned out it was actually ice!
Any ideas on what's going on? Is it low on Freon? I did have them replace everything but the condenser and the evaporator core.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: AC line freezing on truck [Re: motor_oil_madman] #4544417
10/15/17 08:47 PM
10/15/17 08:47 PM
USA
mk378 Offline
mk378  Offline
USA
I'm assuming this is like most American trucks and a CCOT system. The accumulator and large line leaving the evaporator should be slightly colder than the small line going in after the orifice tube. If you look closely, that line on the fender should come from the condenser. Somewhere between there and the cabin there will be a connection and at that point it changes from warm to cold. Inside that connection is the orifice tube.
What you have (plenty cold after the OT, but only moderate at the evaporator outlet) is a sign of undercharging. Put an accurate thermometer (not an IR gun) in one of the vents and observe the air temperature inside. It should be close to 40 F.
A tendency for the whole system to ice up means that the pressure switch is not working, or the refrigerant is contaminated with air (from improper servicing.)
Re: AC line freezing on truck [Re: motor_oil_madman] #4544423
10/15/17 08:50 PM
10/15/17 08:50 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
What mk378 said. Its not cycling out for some reason. Your orifice is behind the passenger side battery on that truck and should be cold from that point on.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
