I have sinned
by 901Memphis. 12/15/18 01:57 PM
Milwaukee m12 in vanhaus ratchet
by pda1122. 12/15/18 01:19 PM
Klein dikes
by Donald. 12/15/18 01:03 PM
Help Soldering 3.5mm mono microphone plug
by Brybo86. 12/15/18 01:02 PM
Small Trolling Motors
by wings&wheels. 12/15/18 12:49 PM
Toyota Corolla, good and bad?
by jongies3. 12/15/18 12:35 PM
Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
73 registered members (901Memphis, AandPDan, ammowaster, 4WD, Aero540T, 10 invisible), 1,973 guests, and 40 spiders.
Topics295,112
Posts4,927,975
Members66,688
Most Online2,553
Oct 27th, 2018
Engine oil use #4544126
10/15/17 01:18 PM
10/15/17 01:18 PM
New York/USA
Joeescape63 Offline OP
New York/USA
Do certain engine designs use more oil over others?I have a Ford Ecoboost 2.0L which is a inline-4. Would a Subaru boxer(flat 4) use more oil than a inline or a V shaped engine?I always break the engine in as per manufactures recommendation.Thanks Joe
2018 Subaru Forester Touring
2.5L engine/CVT
Subaru Filters/Castrol Edge 0W20
Re: Engine oil use [Re: Joeescape63] #4544143
10/15/17 01:53 PM
10/15/17 01:53 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
I think there are other factors that influence oil use. PCV design, type of piston rings and gap, and cylinder wall finish have more of an impact.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Engine oil use [Re: Joeescape63] #4544145
10/15/17 02:02 PM
10/15/17 02:02 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
I agree with bdcardinal. There are just too many factors to make a general statement. I've had flat 4s & 6s and inline 4s and l6 and v6s and non of them used more than a few ozs in a normal OCI. Ed
CX5 Touring 2.5L :-)
Re: Engine oil use [Re: Joeescape63] #4544215
10/15/17 03:32 PM
10/15/17 03:32 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
Boxer 4's and 6's have been doing well in airplanes for a long time where maintenance is well tracked and most often done with great care, no shortcuts, no quicky lubes.
I had to overhaul an 84 Civic motor at 400K miles when the 4 oil control rings all failed and everything else in the engine was doing just fine. Most people don't go that far and would never see such a failure.
Crankcase ventilation control is a contributor to the problem in engines that would otherwise never see such difficulty.
Re: Engine oil use [Re: Joeescape63] #4544222
10/15/17 03:43 PM
10/15/17 03:43 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Piston orientation or basic design doesn't have much effect on oil consumption. Certain materials or designs used by certain manufacturers (Toyota's ring coking, Dodge's low-tension rings, Chevy's faulty integral PCV valve on the Cruze, etc.) do, but not strictly how many cylinders lay which direction.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Engine oil use [Re: Alex_V] #4544428
10/15/17 07:54 PM
10/15/17 07:54 PM
NM, USA
pkunk Offline
pkunk  Offline
NM, USA
Until you think about oil use in an aircraft radial engine
2008 Mini Cooper Clubman (toad)
2000 Mercedes ML320
1994 Dodge 2500 Cummins
1999 Ford F53 V10 Coachman Motorhome 34ft
Re: Engine oil use [Re: OneEyeJack] #4544964
10/16/17 09:16 AM
10/16/17 09:16 AM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
Did you replace just the oil rings and put it back together? I would have been tempted.
Thick oil is better grin2
