Anyone signing up for the Space Force
by Shannow
27 seconds ago
Pennzoil Platinum at Walmart
by TheLawnRanger
Yesterday at 11:21 PM
Mopar OEM and Fram Ultra Oil filters, '18 Jeep JL
by IndyFan
Yesterday at 10:45 PM
What’s the odds..
by Eric Smith
Yesterday at 09:51 PM
Who can relate?
by Reddy45
Yesterday at 09:43 PM
No more oil changes
by goodtimes
Yesterday at 09:19 PM
Separating toddlers from their parents?
by fdcg27
Yesterday at 08:50 PM
gm 8.6 truetrac
by Spitter
Yesterday at 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
Yesterday at 08:34 PM
Rockauto 5% off
by Spitter
Yesterday at 08:32 PM
fumoto oil valve
by Santo
Yesterday at 08:19 PM
Grand solar minimum...
by ridgerunner
Yesterday at 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
Yesterday at 07:49 PM
The things you find cleaning Garage 30+ btls slob
by digger327
Yesterday at 07:20 PM
Castrol GTX Magantec 0w20 - 6 pack $21.99 - Amazon
by 04SE
Yesterday at 07:07 PM
Havoline Pro DS 5w20 $3.15/quart - Amazon
by 04SE
Yesterday at 07:06 PM
Needing New Dipstick
by Geauxtiger
Yesterday at 05:11 PM
'98 Mercedes E300TD Rotella T5 10W-30 5k miles
by KenO
Yesterday at 04:35 PM
Premium guard oil filters
by Jaha24k
Yesterday at 04:09 PM
76 super motor oil- synthetic blend 5w-30
by Jaha24k
Yesterday at 04:07 PM
Shassis, Santo, aligoodn, memyself, MichiganKid419
65274 Registered Users
21 registered (FordCapriDriver, bbhero, Char Baby, Astro14, 69Torino, Falcon_LS, 4 invisible), 783 Guests and 29 Spiders online.
65274 Members
67 Forums
285629 Topics
#4543718 - 10/15/17 03:56 AM Volvo 850 2.0 T5 oil recommendation
Dovydas86 Offline
Loc: Lithuania
Hello everyone,
I got Volvo 850 2.0 turbo (155kw) italian T5, and I am planning to change the oil, it has ~450k km on odometer, and as far as I know previous owner used 10W40 semi synthetic oil for quite some time. I read on several forums that it would be better to use fully synthetic oil in turbo engine, so I would like to switch to synthetic, and want to know if it's worth for such pretty high mileage car. It doesn't seem to leak oil now, maybe just a little from oil cooler lines, which I am planning to replace. I replaced all 4 camshaft seals a month ago, when I was replacing timing belt, and turbo drain tube seal, those were leaking. So the only old seals remaining in this engine is RMS one and front crankshaft seal. I live in Lithuania, temperature at summer rises up to around 30 C sometimes and drops to -25 C or little more at winter. So I guess 5w40 oil would be a good choice if I can switch to synthetic, or I should stay with 10W40 oil? What about Total quartz energy 5w40 or Total quartz 5w40 or shell helix ultra 5w40? Castrol gtx 10w40?
#4543744 - 10/15/17 05:36 AM Re: Volvo 850 2.0 T5 oil recommendation [Re: Dovydas86]
OpelFever Offline
Loc: Finland
Mobil 1 FS 0W-40
Shell Helix Ultra 0W-40/5W-40
Can't go wrong with either. Shell Helix Ultra ECT 0W-30 is a rather nice oil for cold climates, MRV @ -40 only 18900cP and 204VI.
2000 Toyota Corolla 1.6 VVT-i (Mobil 1 0w-40)
1984 Honda CRX 1.5 (Shell Helix Ultra 5w-40)
#4543785 - 10/15/17 07:37 AM Re: Volvo 850 2.0 T5 oil recommendation [Re: OpelFever]
Kira Offline
Loc: Champlain/Hudson Valley
Check the crankcase pressure.
Either affix a balloon tightly over the dipstick tube or a rubber glove tightly over the oil filler neck.
Either way, you do not want to see the balloon or glove expand.
If your balloon or glove expands, you have to service the PCV system. It sounds like the car was serviced well but at your mileage anything is possible.
#4543797 - 10/15/17 08:22 AM Re: Volvo 850 2.0 T5 oil recommendation [Re: Dovydas86]
Kamele0N Offline
Loc: Slovenia
Shell helix ultra...it is GTL based in comparison with your other choices...
It must have "pure plus" written on a sticker to be GTL...othervise it is just an old grp. III stock!
Edited by Kamele0N (10/15/17 08:26 AM)
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD various 10w40
#4543807 - 10/15/17 08:35 AM Re: Volvo 850 2.0 T5 oil recommendation [Re: Dovydas86]
Dovydas86 Offline
Loc: Lithuania
Thanks for the replies everyone. I will try to check the crankcase preasure, just want to be sure - I got to test it after I start the car, when the engine is still cold or wait (drive) a little bit till it warms up and then test it? I should test it on idle or the glove/balloon shouldn't expand even when I push the throttle pedal? And it seems that previous owner serviced the pcv system before me, just don't know how well he did it, did he clean all the tubes and holes in the engine block or not. I already did pcv job twice on another volvo, it's my second Volvo 850, just this time it's turbo, and this one is in better shape than previous one.
#4543821 - 10/15/17 09:00 AM Re: Volvo 850 2.0 T5 oil recommendation [Re: Dovydas86]
exShuttlemech Offline
Loc: ST Augustine, FL
I am voting for the Mobil 1 0W40 FS.
Go Sobieski and the current Polish government. Have you thought about re-establishing the Polish-Lithuanian Republic?
2010 Rav4 4cyl 131K QSUD 0W20 Baldwin bypass filter
2003 4Runner 4.0L 219K 0W40 M1 Frantz bypass
2007 F150 4.2L 169K 5W30 QSUD
2016 NV2500
2017 RAV4
#4543833 - 10/15/17 09:17 AM Re: Volvo 850 2.0 T5 oil recommendation [Re: Dovydas86]
Audios Offline
Loc: Lyndhurst NJ
Any quality full or semi syn oil a little on the thicker side will work fine for reasonable intervals. The 10/40 has done well for all those years, Id stick with something similar.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2005 BMW M3 BMW Twin Power 10/60
1998 BMW M3/4/5 Fuchs 5/40
2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
#4543987 - 10/15/17 11:59 AM Re: Volvo 850 2.0 T5 oil recommendation [Re: Dovydas86]
Finn Offline
Loc: Finland
My earlier 850 2.4 litre T5 did very well with Shell Helix Ultra 5W40.
2000 Jaguar XJR | 1978 Corvette 383" | 1986 Corvette 350" | 2003 FLHR | 1991 300 SE | 1993 GTS1000
