Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
PARTS PLUS PH 2876 CUT OPEN
by 53' Stude. 04/17/19 06:18 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
48 registered members (Billbert, A1O, billt460, bbhero, Bailes1992, 7 invisible), 669 guests, and 27 spiders.
Topics287,673
Posts4,932,031
Members67,838
Most Online2,967
Mar 10th, 2019
Is 229.51 as good as 229.5 #4543714
10/15/17 03:34 AM
10/15/17 03:34 AM
Cheshire, England
barryh Offline OP
barryh  Offline OP
Cheshire, England
Given Mercedes petrol engines have a reputation for premature wear on the timing chain drive would you risk using a low saps oil when you don't need to.
Are the anti wear additives in low saps oil as good as full saps. I suppose they could be even better.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (MB oil 229.5 5W40)
Re: Is 229.51 as good as 229.5 [Re: barryh] #4543727
10/15/17 04:26 AM
10/15/17 04:26 AM
London, England
bigjl Offline
bigjl  Offline
London, England
Going to view this thread with interest.
The oil specs for our Smart are rather vague, just the Merc Spec.
The 0.9 turbo petrol engine is also fitted in the Renault Twingo. I shall have a check and see what they advise as it must relate to what Smart/Mercedes specify
16 S350d LWB 25k Mobil Super 3000 XE 5w30
17 Smart ForFour Auto 6.5k Mobil 1 0w40 FS
Re: Is 229.51 as good as 229.5 [Re: barryh] #4543745
10/15/17 05:38 AM
10/15/17 05:38 AM
USA
ArcticDriver Offline
USA
Why would low saps oils have even better anti-wear additives?
If you have an older vehicle without the modern enissions equipment that low saps was specifically designed for then what would be the advantage to running a low saps?
Lol...I guess you are asking why low saps would be better and I am asking why you assume low saps would be better.
Every bit of research I have done urges to avoid low saps oils in cars that do not require them.
Multiple Diesel and Gasoline vehicles
Re: Is 229.51 as good as 229.5 [Re: barryh] #4543827
10/15/17 09:11 AM
10/15/17 09:11 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
This would require scrutiny form a chemical engineer.
Traditionally, UOA's from low-SAPS oils don't look good at all.
That's why the change interval recommendation is usually less miles.
Re: Is 229.51 as good as 229.5 [Re: barryh] #4543862
10/15/17 09:49 AM
10/15/17 09:49 AM
Cheshire, England
barryh Offline OP
barryh  Offline OP
Cheshire, England
Instinctively I don't think low saps is better, just trying to keep an open mind.
Part of me say 229.51 must meet the same M 271 Wear Test (MB DL, Wear, 250 h) but I just want to know if the low saps anti wear additives are in any way a compromise. It wouldn't matter if MB built engines with sound cam chain drives but they don't and they are not alone in that. I know oil shouldn't be the answer to poor engine design but it is what it is and I want to use the best oil to mitigate any potential problems.
Barry
Re: Is 229.51 as good as 229.5 [Re: barryh] #4543910
10/15/17 10:36 AM
10/15/17 10:36 AM
Indiana
BobFout Offline
BobFout  Offline
Indiana
Typically, the compromise is cost.
2003 VW Jetta TDI (Sold) / 2015 VW GTI 2.0T
Re: Is 229.51 as good as 229.5 [Re: barryh] #4543997
10/15/17 12:15 PM
10/15/17 12:15 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
Yeah, basically for MB, it's 229.5 for gassers and 229.51 or 229.52 for diesel. They don't really seem to have any chain problems on their V6 engines so it's not really a concern. Don't know about their other engines. Lots of people here change their oil at 5k instead of waiting for the recommended 10k.
Re: Is 229.51 as good as 229.5 [Re: Wolf359] #4544070
10/15/17 01:07 PM
10/15/17 01:07 PM
Cheshire, England
barryh Offline OP
barryh  Offline OP
Cheshire, England
Yes I'm also changing the oil at 5K which seems wasteful but may be cheap insurance. It's interesting that when I read about cam chain failures the car always seems to have a full Mercedes service history which would be anything up to 15K intervals.
Barry
Re: Is 229.51 as good as 229.5 [Re: barryh] #4544146
10/15/17 03:08 PM
10/15/17 03:08 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
It may just be a design defect and have nothing to do with the oil. On the 2006-2007 E-350's here, the balance shafts would fail, but that part was updated and had nothing to do with what oil was run. Here the service interval is now every 10k or one year, used to be 13k but I guess people don't like to run their oil that long when they used to change it every 3k on conventional. My E-350 uses 8.5 quarts so the oil isn't really used up even at 10k. Still, I end up changing it around 8-9k but occasionally let it go to almost 10k when I can't get around to it. I just have too much $2/quart oil from Autozone so I'm doing slightly more frequent oil changes.
Re: Is 229.51 as good as 229.5 [Re: barryh] #4544404
10/15/17 08:22 PM
10/15/17 08:22 PM
Illinois USA
IllinoisSparky Offline
Illinois USA
According to this Lubrizol chart, only difference is aftertreament compatability for diesel engines.
Hope that helps.
04 Ford Explorer Total SemiSyn 5W-30/MC filter
99 MB CLK320 Castrol 0W-40/M1 filter
08 MB SL550 M1 0W-40/MB filter
09 BMW X5 3.0i Dealer oil/filter
19 BMW 540i FF
