Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
58 registered members (Astro14, BAJA_05, Benzadmiral, Bailes1992, advocate, alarmguy, 6 invisible), 931 guests, and 44 spiders.
Topics290,699
Posts4,848,516
Members66,021
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
The great Oil problem that plagues turbo disi #4543468
10/14/17 06:52 PM
10/14/17 06:52 PM
Las Vegas, NV
Haxir Offline OP
Haxir  Offline OP
Las Vegas, NV
I drive a 2008 Mazdaspeed 3, a turbo charged 2.3L direct injected gasoline car. I have since heavily modified the car, but the point of this post is very simple: What is the BEST syn oil for this platform??
To give a little back story, these cars from the factory had a big problem with the turbo (K04) seals always going bad and eventually burning oil and dumping clouds of smoke. As people began to figure out the issue of why the smoke was happening (the turbo), cheap fixes were then implemented like oil restrictor bolts for the turbo, or just as popular, changing from the 5w30 to a 5w40 oil. That then became the norm for this platform. If you spend any time reading what oil to run on these cars, you will always find people telling you Rotella T6 as it's "great for this car because of the turbo and it's thicker which helps prevent the oil seeping past the seals in the turbo" etc etc. Well, that was years ago, today however still perpetuate the idea that T6 is the go-to oil for this car/platform. But I want to really get to the bottom of the ACTUAL best oil for this car excluding that turbo problem, because like many others, I have/will replace the turbo and go much bigger and indirectly not have to worry about bad seals on a good performance aftermarket turbo. I've been looking at some "lists of the best synthetic oils", on one particular list T6 ranked as low as the 130's, where as a mobil 1 5w30 ranked within the top 5-10!!! Yet people that have claimed to used this oil said their car ran worse using it. Everyone has their opinions, which makes it so [censored] hard to determine a great oil for this platform. Being disi+turbo throws a bit of a monkey wrench in it due to have limited this setup is used compared to so many others. So what works for others, may not and some literally don't work well for the disi+turbo motor.
I figured I'd come to "THE" place for oil questions and insight. So I ask the educated community of this forum, to please assist me in my quest to find a great oil for my car, especially since I've built the block and really want this motor to last (I wpc treated the block, pistons, rings, bearings). It will be high boost with Meth inject. so I want a good oil, just incase I'm making a mistake continuing to use Shell Rotella T6.
Thank you!
Re: The great Oil problem that plagues turbo disi [Re: Haxir] #4543488
10/14/17 07:09 PM
10/14/17 07:09 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
I'd be looking at an A3/B4 oil... Something like M1 or Castrol 0W-40.
All the OE approvals they carry are relevant to long OCIs on small displacement turbocharged direct injected engines with variable valve timing.
You could pour one of those two oils in just about any engine and they'd perform admirably.
I'm not sure why Rotella T6 gets put on a pedestal as some catch all miracle product; it's really not.
"Zed's dead baby, Zed's dead."
Re: The great Oil problem that plagues turbo disi [Re: Haxir] #4543493
10/14/17 07:14 PM
10/14/17 07:14 PM
Ontario, Canada
GSCJR Offline
GSCJR  Offline
Ontario, Canada
Is this the engine that also suffers from the the timing chain rattle at start up and sludge issues?
03 3.0L 1MZ-FE QSGB 5w-30 ProSelect 21348 255KM
10 3.5L 2GR-FE CEB 5w-20 Defense DL9972 156KM
Re: The great Oil problem that plagues turbo disi [Re: GSCJR] #4543494
10/14/17 07:16 PM
10/14/17 07:16 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
See! It may as well be a euro engine!
Re: The great Oil problem that plagues turbo disi [Re: Haxir] #4543497
10/14/17 07:19 PM
10/14/17 07:19 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
M1 0w-40. Or the M1 HM 10w-30
Or the castrol 0w-40
If you're really beating on it consider something like M1 15w50 or the 5w-50
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
Re: The great Oil problem that plagues turbo disi [Re: Haxir] #4543504
10/14/17 07:30 PM
10/14/17 07:30 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Any W something 30 something that is on sale. This week the winner maybe NAPA at $18.99 a Jug.
2004 Corolla 124705
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: The great Oil problem that plagues turbo disi [Re: SilverFusion2010] #4543515
10/14/17 07:46 PM
10/14/17 07:46 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
These^^^
'18 KIA Sportage LX AWD: Mobil Super Synthetic 10w30
'13 Hyundai Santa Fe Sport 2.0T: EDGE 5w30
Re: The great Oil problem that plagues turbo disi [Re: Haxir] #4543517
10/14/17 07:47 PM
10/14/17 07:47 PM
Fort Campbell, KY
rummy Offline
rummy  Offline
Fort Campbell, KY
Rotella T4 10W-30 or Rotella T5 Synblend 10W-30 have my vote. You can check out a UOA on T4 10W-30 posted recently. T4 10W-30 Used Oil Analysis
If you're feeling adventurous than Delo 400 Severe Duty 15W-30 has my vote. Nice and stout heavy duty, oil.
SAE Grade 15W-30
Product Number 224615
SDS Number 36110
Density at 15C, kg/L 0.881
Viscosity, Kinematic:
cSt at 40C 89.1
cSt at 100C 12.0
Viscosity, MRV, C/Poise -25/14,900
Viscosity, Cold Crank, C/Poise -20/64.0
Viscosity Index 128
Flash Point, C(F) 233(451)
Pour Point, C(F) -36(-33)
Sulfated Ash, wt % 1.0
Base Number 9
Phosphorus, wt % 0.12 (1200ppm)
Sulfur, wt % 0.31
Zinc, wt % 0.12 (1200ppm)
'08 Highlander Sport 3.5L V6
Pennzoil Euro 0W-40 & Fram Ultra
'15 Corolla LE
PP 0W-20 & Fram Ultra
Re: The great Oil problem that plagues turbo disi [Re: rummy] #4543527
10/14/17 07:57 PM
10/14/17 07:57 PM
Texas
4WD Offline
4WD  Offline
Texas
Re: The great Oil problem that plagues turbo disi [Re: JohnnyJohnson] #4543544
10/14/17 08:18 PM
10/14/17 08:18 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
Please tell us that you intended this as humor.
17 Forester 12K MSS 0W-20
12 Accord LX 92K PP 5W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: The great Oil problem that plagues turbo disi [Re: Haxir] #4543570
10/14/17 08:47 PM
10/14/17 08:47 PM
oklahoma
hyperscion Offline
hyperscion  Offline
oklahoma
REDLINE OIL is what ya need, then run an upper cyn lube like SOY SHEILD by schaeffers. to keep fuel system happy and best oil for the turbo. YOU WILL SEE A DIFF.
Re: The great Oil problem that plagues turbo disi [Re: fdcg27] #4543575
10/14/17 08:53 PM
10/14/17 08:53 PM
Wet side WA
Wet side WA
2004 Corolla 124705
2006 Duramax 74277
Re: The great Oil problem that plagues turbo disi [Re: Haxir] #4543693
10/15/17 01:46 AM
10/15/17 01:46 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
Don't give much credence to the list that gave the 130 ranking to T6. There are many better ways to rank oils (ie mfg certified testing, actual in use performance on driven/raced vehicles, etc.). If I recall correctly, M1 0w-40 is ranked near the very top of that same list....and it carries excellent mfg certs.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: The great Oil problem that plagues turbo disi [Re: Haxir] #4543730
10/15/17 04:37 AM
10/15/17 04:37 AM
Europe
SonofJoe Online content
SonofJoe  Online Content
Europe
Okay. I know a lot about oil but my mechanical skills are bloody awful so you're going to have to help me to help you.
When you're designing an engine oil, you primarily design it for the crankcase; not the turbo. There are a couple of oil tests that notionally focus on turbo fouling (the TEOST MHT-4 for example) which all oils have to pass, but I personally would put zero faith in these to protect your turbo.
I haven't delved too deeply into turbo lubrication but I just had a quick squint at some YouTube videos and presumably the 'seals' that you're referring to are two metal split rings (like small piston rings) that sit in grooves on the turbo shaft. There's one on the outer side of the two shaft bearings (so one on the exhaust side and one on the intake side). If I've understood things correctly, it's the exhaust side split ring seal that's failing such that engine oil leaks into the exhaust and causes a lot of white smoke. If I have this wrong, please let me know.
Okay. So why might the seal be failing. I could see three possible oil related modes of failure.
1. The outer edge of the ring is wearing away. There is no 'ring wiping' in the way the outer edges of standard piston rings get lubricated so they may be inherently more prone to wear. I may be wrong but I suspect the only oil the seal outer edges get oiled is by oil 'leaking' (and getting distributed) through the gap in the split ring (?). I'm assuming that the exhaust side of the turbo runs significantly hotter than the inlet side. It could be that the diameter of the shaft on the exhaust side is slightly bigger (due to thermal expansion) which causes the seal ring to press harder against its bore surface. This would also exacerbated wear.
If outer surface wear in the root cause then IMO you need, first off, an oil that is high in ZDDP & Moly and a thicker oil second. This might be why people have gravitated to using HDDOs because these oils allow you to use more ZDDP. Also, given the speed of turbo shafts, you really need an oil that has very good High Temperature High Shear (HTHS) performance. For this you need a full synthetic (Group III or preferably PAO). Also you need a narrow cross-grade to minimise the amount of VII polymer to have in the oil. This means don't think in terms of 5W40s when a full synthetic 10W30 might be better.
2. The other possible failure mode is if oil related deposits build up in the groove that seats the exhaust side split ring. The top and second piston rings/grooves on a normal piston are self-cleaning. The seal and groove on a turbo shaft will not be as there is no reciprocating action. Deposit build up behind the seal will increase the force on the seal face and increase the rate of wear (same as above) but I might be more concerned about the deposits causing the seal to 'stick' flush in its groove, much the same way a piston's oil control ring can stick (and cause excessive oil consumption).
If this were true, then again it might explain why people have looked to HDDOs as a fix. HDDO will always contain a lot more Ashless Dispersant than PCMO and traditionally, Ashless is what to look to to reduce groove deposits.
I'll stop here and you can tell me if I'm on the right track or not. Like I said, I'm not the world's greatest mechanic so I might be way off the beam with my analysis of the problem.
Re: The great Oil problem that plagues turbo disi [Re: Haxir] #4543762
10/15/17 06:35 AM
10/15/17 06:35 AM
Midwest USA
LoneRanger Offline
LoneRanger  Offline
Midwest USA
No, if you have a difficult turbo application like that I would run a 5W40 ester based oil like Motul Sport.
..."specially designed for high performance tuned turbo-charged..."
https://www.motul.com/us/en-US/products/sport-5w40
'09 Subaru Forester ...................(QS HM 5W30)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
Page 1 of 3 1 2 3
