'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
27 registered members (dlundblad, ChrisD46, aba4430, Bailes1992, earlyre, 3 invisible), 332 guests, and 47 spiders.
Topics286,049
Posts4,901,477
Members67,551
Most Online2,967
Mar 10th, 2019
AC Delco oil filter bypass pressure #4543452
10/14/17 06:42 PM
10/14/17 06:42 PM
Texas
TexHawk Offline OP
TexHawk  Offline OP
Texas
Does anyone know where specs are for the bypass valve opening pressures for various oil filters?
Especially, AC Delco PF64?
I have seen some information that the PF64 bypass pressure has been increased to 22 PSI, while the WIX equivalent (57060) still has a bypass pressure of 12 PSI. The increase in pressure is supposed to be because GM engines now have a variable volume oil pump and the higher pressure is to keep more unfiltered oil from being dumped in the engine...
Re: AC Delco oil filter bypass pressure [Re: TexHawk] #4543817
10/15/17 08:53 AM
10/15/17 08:53 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Re: AC Delco oil filter bypass pressure [Re: TexHawk] #4544077
10/15/17 01:20 PM
10/15/17 01:20 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Maybe AC Delco filters are pretty restrictive so they bumped up the bypass setting for that application. The less flow restrictive a filter is, the lower the bypass valve setting can be.
