1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
43 registered members (billt460, c502cid, anndel, billpace1956, Brad_C, 5 invisible), 1,021 guests, and 31 spiders.
Topics296,903
Posts4,961,302
Members66,997
Most Online2,688
Jan 19th, 2019
Motor Flush Compounds and Additives- Safe to Use? #4543446
10/14/17 05:37 PM
10/14/17 05:37 PM
Bucks County, PA
Hot_Ajax Offline OP
Hot_Ajax  Offline OP
Bucks County, PA
My oil coming out pretty disgusting. And after I put the new oil in, it is still kind of dark. Am I due for a flush or leave it alone? How do these flushes work? Add the stuff right before an oil change? Been using Mobil 1 for over 200,000 miles with 8000 mile OCI. Thanks.
Re: Motor Flush Compounds and Additives- Safe to Use? [Re: Hot_Ajax] #4543449
10/14/17 05:40 PM
10/14/17 05:40 PM
Florida
Dumc87 Offline
Dumc87  Offline
Florida
My favorite flush has been Heartland Xtreme Clean Motor Flush.
Completely removed a lifter tick in my 300ZX that they are notorious for. Car mostly sits, and the tick is minimal years later.
Drain oil, remove oil filter, install new filter (use a cheap one)
Add the gallon of flush, run the engine a few minutes
Drain flush, remove oil filter, install new filter (good one, like Fram Ultra)
Add oil
laugh
Edit: If it's just cleaning, I'd limit the 8K OCI's to about 2-3K and replace a quart of the Mobil with some MMO.
Edit again (LOL) - Perhaps the oil is doing just fine, and the engine is just turning the oil black due to something else, that of which I wouldn't know off the top of my head. Maybe a dirty air filter or a tune up is in order?
'90 Z32 - PP HM 10w30
'98 ZJ - PYB HM 10w40
'02 G20 - QS UD 5w30
'09 Matrix - QS UD 0w20
Re: Motor Flush Compounds and Additives- Safe to Use? [Re: Dumc87] #4543466
10/14/17 05:50 PM
10/14/17 05:50 PM
SouthernCaliforniaDesert,USA
PalmSpringsSCal Offline
Maybe you should drive it a few miles and change oil again and repeat until its gone?? Could get costly,but might want to clean it up as fr as you can visualize. I dunno...Im about to face the same situation
I would worry about clogging the oil pump and screwing the engine with the strong flushes.I dont want to have to drop my oil pan to check the oil pickup screen for clogging. Ive decided to add something not as agressive as flushes Ive recently seen. My hmo adds detergents and I may try some mild flush,but first I have to learn which one that might be. That parts going to be a toughie.
Re: Motor Flush Compounds and Additives- Safe to Use? [Re: Hot_Ajax] #4543469
10/14/17 05:53 PM
10/14/17 05:53 PM
Canada
i_hate_autofraud Offline
Canada
First Iíd look at why you think the oil is such bad condition and turns dark so fast.
Is the crankcase ventilation working? Any vacuum leaks that cause rough running?
Any system malfunctions that prevent clean running could be your root cause, vintage engines
run dirtier then late model.
I use straight kerosene, but only when I Ďneedí to and not often, any flush additive has an
astringent quality that can dry and shrink seals causing leaks later.
When I do use a flush I let the engine idle for 20 minutes for best results and let it drain
out for 15 minutes at least to be sure itís mostly gone, then a new filter and oil. I run the
flush in the old oil, no point wasting new oil!
ENGINE OIL FLUSHES - DO THEY WORK?
https://app.box.com/s/5s5bcjdbs2e5xu9x1rqo
I use FilterMags now on my late model car, but I wish I could have used them on all
my older cars to back in the day!
It's been 4 yrs since my last flush, FilterMags and extra mags on the spin-on filter housing
likely means I'll never have to again!
FILTERMAG vs HOMEBREW
https://app.box.com/s/uxvu8dmscf5wcgftutdm0ejqwgn86tw7
Re: Motor Flush Compounds and Additives- Safe to Use? [Re: PalmSpringsSCal] #4543472
10/14/17 05:53 PM
10/14/17 05:53 PM
Florida
Dumc87 Offline
Dumc87  Offline
Florida
I'm not a fan of flushes myself, but the reason I went with the Heartland Xtreme clean is it is basically a super cleaning oil change.
Otherwise I'm with you in that I'd add "soft" cleaning agents or find a high-detergent oil (I think most are nowadays??)
Re: Motor Flush Compounds and Additives- Safe to Use? [Re: Hot_Ajax] #4543489
10/14/17 06:09 PM
10/14/17 06:09 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
They're mostly safe unless you have an extreme sludge condition. None of them will directly hurt the engine but if they clean too aggressively there is potential for big chunks to come loose and clog the oil pickup. That's a bad thing.
I haven't personally seen a flush kill an engine. I've heard stories.
Tune up the engine. New filters, spark plugs, wires, PCV valve. Look for vacuum leaks. Clean the MAF and the throttle body. Run some Techron in a couple tanks of fuel.
Photos would be helpful here. Also how many miles to turn dark? The oil may be cleaning up the motor gradually. Short OCI 1-2k miles with a good oil is considered the "safe" method of cleaning.
Some also advocate a thicker grade.
If you go with frequent oil changes make use of the sales and rebates offered by the various oil blenders. Often you can get a full synthetic oil for the same price as conventional. Supertech filters are made by Wix and are an excellent cost effective option. $2.85 out the door at my Walmart
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Motor Flush Compounds and Additives- Safe to Use? [Re: Hot_Ajax] #4543490
10/14/17 06:10 PM
10/14/17 06:10 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
The Mobil 1 is doing a good job of keeping it clean. I'd leave it alone. Maybe a shorter OCI.
Re: Motor Flush Compounds and Additives- Safe to Use? [Re: Warstud] #4543532
10/14/17 07:01 PM
10/14/17 07:01 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
The only way to tell if the motor has sludge is to open the front valve cover and see what is underneath.
If you are using Mobil 1 chances are its very clean inside.
My wife's 1997 mainly used mobil 1 for most of its life and the internals are spotless after 194,xxx km. She does a lot of short tripping.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Motor Flush Compounds and Additives- Safe to Use? [Re: Hot_Ajax] #4543550
10/14/17 07:22 PM
10/14/17 07:22 PM
New England
gathermewool Offline
New England
If you're saying you've got milkiness, chunks or signs of other issues, then that's something completely different and we need to figure out why you're having this problem, because a flush won't help.
8k intervals isn't anything special, so long as you maintained the oil level on the dipstick. Did you maintain the oil level or has it ever gone low or do you simply change it every 8k and never check between changes? What's your oil consumption.
Finally, what do you mean by disgusting? If you're saying that your oil is coming out dark, then just keep doing what you're doing - no more answers needed, nothing's wrong, and what you've been doing will work well from now until the car falls apart. End of thread.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Motor Flush Compounds and Additives- Safe to Use? [Re: Hot_Ajax] #4543560
10/14/17 07:39 PM
10/14/17 07:39 PM
USA
slacktide_bitog Offline
USA
They are usually useless and sometimes worse. The only thing they flush is your money.
But if you insist on using one, get the Liqui Moly brand. Napa sells it at a good price.
But really, you'd be better off with a few short OCI's with synthetic, like the M1 on sale at AAP for two more weeks.
Pull the valve covers if the job isn't difficult on your car, so you can get a better idea of how clean or dirty the engine is smile
Re: Motor Flush Compounds and Additives- Safe to Use? [Re: Hot_Ajax] #4543587
10/14/17 08:07 PM
10/14/17 08:07 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Start doing 1700 mile OCI's with Valvoline Maxlife. Do that about 3 times. Your engine will be spotless.
Re: Motor Flush Compounds and Additives- Safe to Use? [Re: Hot_Ajax] #4543637
10/14/17 09:31 PM
10/14/17 09:31 PM
socal
barkingspider Offline
socal
I have used motor medic flush w zero issues in multiple vehicles. Itíll only set you back like $4. But if u been using M1, then Iím sure the inside of your engine is clean
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Motor Flush Compounds and Additives- Safe to Use? [Re: Hot_Ajax] #4543640
10/14/17 09:38 PM
10/14/17 09:38 PM
San Diego
FlyPenFly Online content
FlyPenFly  Online Content
San Diego
I mean it's a bunch of solvents going through your oil passages. Maybe it'll take some varnish and smaller buildup out. Does it really change the system? Not really but it's interesting peace of mind.
2014 Mercedes GLK350 3.5L DFI
2014 Mercedes E350 Coupe 3.5L DFI
2010 Audi A4 2.0T
Re: Motor Flush Compounds and Additives- Safe to Use? [Re: Hot_Ajax] #4543776
10/15/17 06:12 AM
10/15/17 06:12 AM
USA
ArcticDriver Offline
USA
Originally Posted By: Hot_Ajax
My oil coming out pretty disgusting. ... Been using Mobil 1 for over 200,000 miles with 8000 mile OCI. Thanks.
Disgusting? Yuk...is it all like dirty and stuff?
Lol.
Multiple Diesel and Gasoline vehicles
Re: Motor Flush Compounds and Additives- Safe to Use? [Re: Hot_Ajax] #4543838
10/15/17 08:23 AM
10/15/17 08:23 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I wouldn't waste the money on synthetics for a car with well over 200,000 miles on it.
I'd use a cheap conventional (Harvest King oil is only $6 for 5 quarts!) and change it every 4,000-5,000
