Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
73 registered members (4WD, andrewp1998, Artem, amblerman, 13 invisible), 2,113 guests, and 42 spiders.
Topics295,106
Posts4,927,910
Members66,688
Most Online2,553
Oct 27th, 2018
Opinion About OCI and Mobil 1: Mechanics / Techs? #4543421
10/14/17 05:00 PM
10/14/17 05:00 PM
Bucks County, PA
Hot_Ajax Offline OP
Hot_Ajax  Offline OP
Bucks County, PA
I drive an 09 Tacoma with a V-6. One third city, two thirds rural driving. Have 250,000 miles, no oil loss or smoke. Have been using Mobil 1 5W-30 for last 220,000 miles with an 8000 mile OCI and Hastings filter (if I remember to look at the little sticker). Now that this engine has reached old fahrt status, is there any need to shorten up on the OCI? Thank you.
Re: Opinion About OCI and Mobil 1: Mechanics / Techs? [Re: Hot_Ajax] #4543431
10/14/17 05:18 PM
10/14/17 05:18 PM
PimTac Offline
PimTac  Offline
Nope, just stay on course with what you are doing now. That Toyota engine is bulletproof.
Cannot see signatures any longer so it doesn’t matter.
Re: Opinion About OCI and Mobil 1: Mechanics / Techs? [Re: Hot_Ajax] #4543432
10/14/17 05:19 PM
10/14/17 05:19 PM
oklahoma
hyperscion Offline
hyperscion  Offline
oklahoma
I think your doing everything right, maybe mobil hm,,,, but why rock the boat, good job on your maintenance.
Re: Opinion About OCI and Mobil 1: Mechanics / Techs? [Re: Hot_Ajax] #4543436
10/14/17 05:22 PM
10/14/17 05:22 PM
Florida
Brett776 Offline
Brett776  Offline
Florida
Im far from an expert, sounds like your current oci is working fine. Im assuming youre using synthetic mobil 1. You are probably fine with that OCI. Dont be like me, I made it to 4800 miles and changed mine today with 50% on my OLM..I just get anxiety that my oil is going bad. Then again I short trip a lot. Try an UOA from Blackstone.
Re: Opinion About OCI and Mobil 1: Mechanics / Techs? [Re: hyperscion] #4543438
10/14/17 05:24 PM
10/14/17 05:24 PM
Texas & Global
4WD Online confused
4WD  Online Confused
Texas & Global
Perhaps M1 HM to give the seals a bit more TLC OCI could stay the same
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: Opinion About OCI and Mobil 1: Mechanics / Techs? [Re: Hot_Ajax] #4543445
10/14/17 05:34 PM
10/14/17 05:34 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Not even sure I'd worry about moving to HM unless it becomes prudent from leaks or an increase in consumption. If your engine has that many miles and the your current oil+interval is keeping it clean inside, no reason to change.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Opinion About OCI and Mobil 1: Mechanics / Techs? [Re: Hot_Ajax] #4543457
10/14/17 05:45 PM
10/14/17 05:45 PM
Florida
Dumc87 Offline
Dumc87  Offline
Florida
This thread has more info, and I'm with the other guys; just keep doing what you're doing! Don't worry about the flush or any cleaning unless you see sludge, which you probably have little to none of anyway.
'90 Z32 - PP HM 10w30
'98 ZJ - PYB HM 10w40
'02 G20 - QS UD 5w30
'09 Matrix - QS UD 0w20
Re: Opinion About OCI and Mobil 1: Mechanics / Techs? [Re: Hot_Ajax] #4543477
10/14/17 05:56 PM
10/14/17 05:56 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Unless you have leaks or consumption, no real reason to change oils or intervals. I run 8k oci in my fusion with Mobil oils and don't think much about it
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Opinion About OCI and Mobil 1: Mechanics / Techs? [Re: Hot_Ajax] #4543509
10/14/17 06:35 PM
10/14/17 06:35 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
What does you UOA tell you?
2004 Corolla 126813
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Opinion About OCI and Mobil 1: Mechanics / Techs? [Re: Hot_Ajax] #4543524
10/14/17 06:55 PM
10/14/17 06:55 PM
Texas
GMBoy Offline
GMBoy  Offline
Texas
I see the point of continuing with your current methods because they have proven - over the LONG haul - to work! With that being said, and I am a Mobil 1 user, I would go to the Hi-mileage Mobil 1 for not just the seal conditioners but that it's on the thich side of a 30wt oil which may be beneficial to your engine at those miles.
Re: Opinion About OCI and Mobil 1: Mechanics / Techs? [Re: Hot_Ajax] #4543529
10/14/17 06:59 PM
10/14/17 06:59 PM
oklahoma
hyperscion Offline
hyperscion  Offline
oklahoma
oil seals will fail at sometime,, a cheap change to hm oil wont hurt,, and maybe prolong those seals. but what do I know. oci keep the same.
Re: Opinion About OCI and Mobil 1: Mechanics / Techs? [Re: GMBoy] #4543531
10/14/17 07:01 PM
10/14/17 07:01 PM
oklahoma
hyperscion Offline
hyperscion  Offline
oklahoma
+1
Re: Opinion About OCI and Mobil 1: Mechanics / Techs? [Re: Hot_Ajax] #4543615
10/14/17 08:59 PM
10/14/17 08:59 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Keep on doing what u do!
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Opinion About OCI and Mobil 1: Mechanics / Techs? [Re: Hot_Ajax] #4543664
10/14/17 11:10 PM
10/14/17 11:10 PM
socal
barkingspider Offline
socal
No need to change, unless u really want to
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Opinion About OCI and Mobil 1: Mechanics / Techs? [Re: Hot_Ajax] #4544187
10/15/17 02:58 PM
10/15/17 02:58 PM
Pennsylvania
K23Turbo Offline
K23Turbo  Offline
Pennsylvania
Your oci has been trouble free so far. Id dare and venture to say you can extend your oci by 2K. With a uoa first if ya like.
