Stick with WSS-M2C946-A?
by BlueFog. 12/14/18 01:42 PM
How engine capacity affects fuel consumption?
by NICAT. 12/14/18 01:12 PM
Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
EFB and AGM batteries charge faster?
by slybunda. 12/14/18 11:20 AM
97.5 Regal GS climate control illumination
by 71Chevyguy. 12/14/18 11:04 AM
Cool train site for Canadians
by Papa Bear. 12/14/18 10:09 AM
Putting together a groups 3/4/5 synthetic list
by MrWideTires. 12/14/18 10:02 AM
VW Atlas V6 Oil
by motech. 12/14/18 09:32 AM
Great shakes, it's Yahtzee... or a Taurus
by redhat. 12/14/18 09:03 AM
MWI Micro Wave Ignition
by Danno. 12/14/18 08:52 AM
8k Miles on M1 EP 2017 Subaru 3.6
by BISCUT. 12/14/18 08:47 AM
Wrong ATF Fluid in my 07 Chevy Impala
by CM613. 12/14/18 08:39 AM
Hyundai motor oil
by pbm. 12/14/18 08:16 AM
Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
Rotella T5 10w30 Ford 6.7L anyone?
by sw99. 12/14/18 07:49 AM
Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
wsalopek, jcr1293, maxwellk, BlueFog, Frank_G35
66682 Registered Users
89 registered members (bdcardinal, 53' Stude, AZjeff, bbhero, Anduril, 11 invisible), 1,854 guests, and 38 spiders.
Topics295,064
Posts4,927,140
Members66,681
Most Online2,553
Oct 27th, 2018
Briggs 4.5hp - hard to start when hot #4543360
10/14/17 03:35 PM
10/14/17 03:35 PM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
Read a post on here weeks ago (about generators?.) and the poster had the same symptoms and someone mentioned the cause but I'll be darned if I can find it again
Have a Yard Machine lawn vacuum with a 4.5hp briggs engine
Starts on 1st - 3rd pull when I roll it out of the shed.
Once hot, however, it refuses to catch ( like right now) so I have to take a break and wait for it to cool down.
Now there IS an interlock on the bag which can get finicky but I'm aware of this and it's not the cause for the inability to start.
Choke on... choke off... partial throttle... full throttle... has no impact
One issue that could be relevant: the gas cap allows gas to weep out of the Neck of the filler. Just replaced the cap and it still weeps.... pretty sure I picked up the proper replacement. Actually 95% sure I ordered the right replacement although not an OEM
Anyone have any thoughts as to why this happens...?
Thank you
--bob
God Bless America
Re: Briggs 4.5hp - hard to start when hot [Re: Finz] #4543371
10/14/17 03:52 PM
10/14/17 03:52 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Did you check a spark when hot? Maybe its worn out CDI unit or condenser...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Briggs 4.5hp - hard to start when hot [Re: Finz] #4543373
10/14/17 03:54 PM
10/14/17 03:54 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Thank you
--bob
It is always great on a hot summer day to have a good reason for that next cold beer while you wait for it to cool off.
2004 Corolla 126813
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Briggs 4.5hp - hard to start when hot [Re: Finz] #4543390
10/14/17 04:23 PM
10/14/17 04:23 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
I wonder if the gas in the final stages of mixing in a hot intake evaporates and now you don't have the stuff (vacuum) to start the process. Just for grins check the carb/manifold/block screws
Thick oil is better grin2
Re: Briggs 4.5hp - hard to start when hot [Re: Finz] #4543399
10/14/17 04:32 PM
10/14/17 04:32 PM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
I'll check for spark... hadn't thought of that
I KNEW I was setting myself up for the "taking a break" comment smile
I'll take the carb off and reassemble... maybe just look into replacement as it's 15 years old. Be surprised if more than $20
Thanks all
God Bless America
Re: Briggs 4.5hp - hard to start when hot [Re: Finz] #4543423
10/14/17 05:01 PM
10/14/17 05:01 PM
oklahoma
hyperscion Offline
hyperscion  Offline
oklahoma
ok. dad same problem with a a new mower and i have had this with honda and B&S. We mow ALOT... leave about 1 inch of air space in gas tank when filling up to mow. lube spray all throttle linkinge from handle to engine. I use schaeffer's NEUTRA in all our gas cans.... it cleans carbs,stabilizes gas, and is a fuel lubricator,,,GREAT STUFF. We also only use redline oil or amsoil oil,,0w30. It made a huge diff in our seven push mowers and 2 drivers.
When shut down hot, I think some of the mowers got a little flooded. but not anymore.
goodluck
Re: Briggs 4.5hp - hard to start when hot [Re: Finz] #4543428
10/14/17 05:12 PM
10/14/17 05:12 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
What are the engine numbers Finz ?
Re: Briggs 4.5hp - hard to start when hot [Re: Finz] #4543435
10/14/17 05:21 PM
10/14/17 05:21 PM
USA
mk378 Offline
mk378  Offline
USA
If you haven't been keeping the cooling system clean, it could be overheating. Pull the air shroud and clean the cylinder fins etc.
This does sound a lot like a coil that stops working due to heat soak. Spark test would tell. You can disconnect any kill switches, oil sensors, etc from the coil kill wire to test only the coil.
Re: Briggs 4.5hp - hard to start when hot [Re: Merkava_4] #4543455
10/14/17 05:42 PM
10/14/17 05:42 PM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
12H802-1777-D1 02092557
God Bless America
Re: Briggs 4.5hp - hard to start when hot [Re: mk378] #4543459
10/14/17 05:46 PM
10/14/17 05:46 PM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
I hear what you're saying but I don't have the first clue as to how check that. Cleaning out fins... sure. Check for spark,...? Pull plug and pull cord with plug grounded against engine....?
But the rest? I'll try to find a YouTube or something
Thank you
God Bless America
Re: Briggs 4.5hp - hard to start when hot [Re: hyperscion] #4543470
10/14/17 05:53 PM
10/14/17 05:53 PM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
goodluck
Thank you... all gas is already treated with Stabil and a splash of MMO and" because of the stupid leaky gas caps, I fill the tank halfway or so
I'll check out Neutra.... never heard of it
After reading that Generator post - which was really a discussion about oil - I replaced the oil with Rotella T6. 5w-40
God Bless America
Re: Briggs 4.5hp - hard to start when hot [Re: Finz] #4543564
10/14/17 07:42 PM
10/14/17 07:42 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
Re torque the head bolts and check for loose bolts at the intake manifold.
Re: Briggs 4.5hp - hard to start when hot [Re: Finz] #4543621
10/14/17 09:06 PM
10/14/17 09:06 PM
Canada
boraticus Offline
boraticus  Offline
Canada
I'd guess it's electrics as mentioned in some of the above posts. Failing that, it could possibly be tight valves. When the engine heats to the point of metal expansion, the valves may not be closing sufficiently to create necessary compression. Thus reluctance to start.
Re: Briggs 4.5hp - hard to start when hot [Re: Finz] #4543662
10/14/17 10:57 PM
10/14/17 10:57 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Drop the spark plug gap from 0.030 to 0.020. If that works your coil is going out.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 Maxlife Syn 5W30
06 GMC Sierra Nextgen 10W30
Re: Briggs 4.5hp - hard to start when hot [Re: Finz] #4543674
10/15/17 12:00 AM
10/15/17 12:00 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Those last set of numbers, the code number, tells me you have a carburetor with an automatic choke. The thermostat is probably not pulling the choke off. With the choke still on and the engine hot, it's not going to start. Replace thermostat 790830 and exhaust gasket 691881.
You can verify by pulling the air cleaner off. If the choke plate is still closed when the engine is hot, that's your problem. That engine came with 3 different carburetors depending on the date code: Primer Carb, Manual Choke Carb, and Auto Choke Carb. The automatic choke carb was for date codes before 05091900.
Personally, I'd convert it over to a primer carb system.
