Stick with WSS-M2C946-A?
by BlueFog. 12/14/18 01:42 PM
How engine capacity affects fuel consumption?
by NICAT. 12/14/18 01:12 PM
Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
EFB and AGM batteries charge faster?
by slybunda. 12/14/18 11:20 AM
97.5 Regal GS climate control illumination
by 71Chevyguy. 12/14/18 11:04 AM
Cool train site for Canadians
by Papa Bear. 12/14/18 10:09 AM
Putting together a groups 3/4/5 synthetic list
by MrWideTires. 12/14/18 10:02 AM
VW Atlas V6 Oil
by motech. 12/14/18 09:32 AM
Great shakes, it's Yahtzee... or a Taurus
by redhat. 12/14/18 09:03 AM
MWI Micro Wave Ignition
by Danno. 12/14/18 08:52 AM
8k Miles on M1 EP 2017 Subaru 3.6
by BISCUT. 12/14/18 08:47 AM
Wrong ATF Fluid in my 07 Chevy Impala
by CM613. 12/14/18 08:39 AM
Hyundai motor oil
by pbm. 12/14/18 08:16 AM
Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
Rotella T5 10w30 Ford 6.7L anyone?
by sw99. 12/14/18 07:49 AM
Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
wsalopek, jcr1293, maxwellk, BlueFog, Frank_G35
66682 Registered Users
90 registered members (bdcardinal, 53' Stude, AZjeff, bbhero, Anduril, 11 invisible), 1,859 guests, and 39 spiders.
Topics295,064
Posts4,927,140
Members66,681
Most Online2,553
Oct 27th, 2018
Front brake rotor shudder #4543131
10/14/17 10:55 AM
10/14/17 10:55 AM
In the shop
53' Stude Online content OP
53' Stude  Online Content OP
In the shop
Good afternoon BITOG faithful. So, last weekend I put carquest top of the line rotors and semi metallic pads on the 09' Camry. I get a brake shudder if hit brakes that you can feel a bit thru brake pedal. Explained situation to older co workers/mechanics I work with. They both agreed it's probably my rear rotors and pads as I looked at them last weekend and the rear pads are 6/32 and rotors didn't look bad. Maybe I'll do the rear rotors and pads tomorrow and see if that remedies the problem
09' Camry LE, 141,020 miles
PP 5w30 and TG 4967
Re: Front brake rotor shudder [Re: 53' Stude] #4543139
10/14/17 11:06 AM
10/14/17 11:06 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Did you check run-out with a dial indicator? Just something else to consider.
God Bless Our Troops
Re: Front brake rotor shudder [Re: 53' Stude] #4543142
10/14/17 11:08 AM
10/14/17 11:08 AM
Iowa
Aichiguy Offline
Aichiguy  Offline
Iowa
I would bet that the grease in the slider pins cylinders is dried or baked. You should pull them out each brake job and clean, regrease for the best brake performance or else you will tend to wear one pad more than other and get shudder from the caliper binding. Had this issue after we took 11 Camry to mountains.
2017 Toyota Camry 2.5
2011 Toyota Camry 2.5 75k
2003 Toyota Camry 2.4 201 k
1999 Ford F150 4.6 70k
Re: Front brake rotor shudder [Re: Aichiguy] #4543162
10/14/17 11:40 AM
10/14/17 11:40 AM
In the shop
In the shop
I re did the calipers or put new boots, bolts and slides in and on. Shudder isn't that bad just bit annoying is all.
PP 5w30 and TG 4967
Re: Front brake rotor shudder [Re: 53' Stude] #4543178
10/14/17 12:06 PM
10/14/17 12:06 PM
Missouri
cb_13 Offline
cb_13  Offline
Missouri
If you feel it mostly in the seat or floor it's the rear brakes. You'll feel a front brake vibration through the steering wheel.
Re: Front brake rotor shudder [Re: 53' Stude] #4543197
10/14/17 12:28 PM
10/14/17 12:28 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
I had the same issue after I replaced mine. Shudder eventually went away on its own. If its not gone with the backs replaced I wouldnt be too concerned. I was thinking the rotor might of been bad.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Front brake rotor shudder [Re: cb_13] #4543200
10/14/17 12:29 PM
10/14/17 12:29 PM
In the shop
In the shop
Yeah, I'm gonna do rear brakes soon along with the wheel bearings smile
PP 5w30 and TG 4967
Re: Front brake rotor shudder [Re: 53' Stude] #4543208
10/14/17 12:36 PM
10/14/17 12:36 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I'm guessing its a slick spot on the rotor (what many refer to as "warping" grin ). Pull the rotor off, spray it down real good with brake cleaner. put it back on, test. Bet its gone.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Front brake rotor shudder [Re: 53' Stude] #4543210
10/14/17 12:36 PM
10/14/17 12:36 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
You already did the rear brakes a few weeks ago:
Good evening BITOG faithful smile
So, I ordered rear rotors and pads for the camry of mine. Question I have and pardon my ignorance here but should I clean that grayish paint off the rotor or does it aid in bedding in the pads and rotors?
Thank for advice and info in advance smile
Happy Friday also
Re: Front brake rotor shudder [Re: SatinSilver] #4543217
10/14/17 12:46 PM
10/14/17 12:46 PM
In the shop
In the shop
Happy Friday also
Totally incorrect. Ordered and have rear rotors and pads. Rear rotors and pads are NOT NEW!
I will be doing rear rotors AND pads very soon smile
PP 5w30 and TG 4967
Re: Front brake rotor shudder [Re: 53' Stude] #4543218
10/14/17 12:47 PM
10/14/17 12:47 PM
In the shop
In the shop
I replaced front rotors and pads, not rear rotors and pads YET
PP 5w30 and TG 4967
Re: Front brake rotor shudder [Re: 53' Stude] #4543221
10/14/17 12:48 PM
10/14/17 12:48 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Re: Front brake rotor shudder [Re: 53' Stude] #4543228
10/14/17 12:55 PM
10/14/17 12:55 PM
In the shop
In the shop
I ordered front rotors is what I meant to type in that thread; already had Advance/Carquest rotors
PP 5w30 and TG 4967
Re: Front brake rotor shudder [Re: 53' Stude] #4543229
10/14/17 12:55 PM
10/14/17 12:55 PM
In the shop
In the shop
I ordered front rotors is what I meant to type in that thread; already had Advance/Carquest rotors. I installed new Advance rotors and pads for front of my Camry. Have NOT replaced rear rotors and pads YET
PP 5w30 and TG 4967
Re: Front brake rotor shudder [Re: 53' Stude] #4543231
10/14/17 12:57 PM
10/14/17 12:57 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Ahh gotcha. It might be the brakes breaking in since they have protective paint on them. Esp if you feel the vibration in the steering wheel. smile
