Ford 4.6L Durability?
by Auae85
06/20/18 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
06/20/18 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
06/20/18 10:01 PM
Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
06/20/18 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
06/20/18 08:49 PM
My FIL in hospice
by fdcg27
06/20/18 08:41 PM
Spraying Polyurethane
by Texican
06/20/18 08:37 PM
Dehumidifier icing
by Kestas
06/20/18 08:37 PM
Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
06/20/18 04:54 PM
yamahaboy125, Turboholic, TrpNY, bcj, Ilia
65282 Registered Users
27 registered (billt460, ctechbob, dishdude, AnthemBassMan, crazy_raccoon, earlyre, 2 invisible), 814 Guests and 44 Spiders online.
65282 Members
67 Forums
285683 Topics
Page 1 of 3 1 2 3 >
#4543041 - 10/14/17 10:24 AM Amsoil & Redline ATF is 1 better than the other?
BobsArmory Offline
Loc: Michigan
I am getting stuff around to do an ATF drain and fill on my wife's Malibu. I'll be doing my Equinox this spring. I will be using either Amsoil or Redline Dex6 for both vehicles. To get the majority of old fluid out I will be doing an initial drain and fill, drive it for a few days then a second drain and fill.
My question is, is there any real difference in quality or durability between the two products? Which would you choose?
BTW, just for giggles I will do a UOA on the factory fluids.
Keeping the forces of evil at bay
2016 Chevy Malibu LT 1.5 Liter Turbo
2017 Chevy Equinox LT 2.4 Liter
#4543044 - 10/14/17 10:27 AM Re: Amsoil & Redline ATF is 1 better than the other? [Re: BobsArmory]
MolaKule Offline
Loc: Iowegia - USA
UOA's on FF's usually don't allow for a starting baseline of any value, other than general interest.
#4543047 - 10/14/17 10:34 AM Re: Amsoil & Redline ATF is 1 better than the other? [Re: BobsArmory]
StevieC Offline
Loc: Ontario, Canada
I have used the Amsoil Multi-Vehicle ATF in my Santa Fe and it went 300K Miles (535,000km) on the original transmission. I have also used it in my dad's 2012 Caravan which has 187K Miles (300K KM's) and it's original and I currently have it in my Dodge Journey with 50K Miles (80K Km's)
I'm super happy with the shift quality and the longevity of the fluid.
Edited by StevieC (10/14/17 10:34 AM)
'15 Dodge Journey - 90,000 KM's - SSO 5w20
'06 Hyundai Santa Fe - 535,000km - SSO 0w30 (R.I.P)
#4543116 - 10/14/17 11:38 AM Re: Amsoil & Redline ATF is 1 better than the other? [Re: BobsArmory]
panthermike Offline
Loc: Phoenix, AZ
Honestly, you can't go wrong with either.
'15 Lexus RX350; PP 0w20, 33K
'10 Impala; Frankenbrew, MG 114K
'70 F100; Valvoline 15w40/Biotech, Motorcraft
#4543121 - 10/14/17 11:46 AM Re: Amsoil & Redline ATF is 1 better than the other? [Re: MolaKule]
BobsArmory Offline
Loc: Michigan
Agreed,
#4543951 - 10/15/17 11:13 AM Re: Amsoil & Redline ATF is 1 better than the other? [Re: BobsArmory]
BobsArmory Offline
Loc: Michigan
I think I will go with Amsoil for both vehicles.
#4544029 - 10/15/17 12:33 PM Re: Amsoil & Redline ATF is 1 better than the other? [Re: BobsArmory]
StevieC Offline
Has never failed me. Good Luck! thumbsup
#4547654 - 10/18/17 08:52 PM Re: Amsoil & Redline ATF is 1 better than the other? [Re: BobsArmory]
Gebo Offline
Loc: VA
I'd go Amsoil. It's easier for me to get. It's in all my AT's.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
#4547765 - 10/18/17 11:41 PM Re: Amsoil & Redline ATF is 1 better than the other? [Re: StevieC]
bowlofturtle Offline
Loc: Chicago
Who is the say that had you just used normal ATF or never changed it, that it couldn't go 300k. I'm not bashing Amsoil at all, i've been using Redline D4 and would have used Amsoil if i it was the cheapest fluid. There are more sides to everything.
The OP will be happy with either, just go with the cheaper one.
My toys
-05 Infiniti G35x 121k
-03 Suzuki SV650N 8.5k
Maintaining
-16 Jetta 1.4T 7k
-98 Nissan Maxima 145k
-09 Toyota Camry V6 86k
#4547836 - 10/19/17 03:50 AM Re: Amsoil & Redline ATF is 1 better than the other? [Re: BobsArmory]
StevieC Offline
There is nothing saying that any other fluid wouldn't do the same. Just stating first hand experience to show that the Amsoil fluid did its job when I used it and that I was happy with the shift quality. The OP's thread is about whether he should choose Amsoil or Redline.
Not sure how what I said wasn't relevant. shrug
Edited by StevieC (10/19/17 03:54 AM)
#4548930 - 10/20/17 06:51 AM Re: Amsoil & Redline ATF is 1 better than the other? [Re: BobsArmory]
MaximaGuy Offline
Loc: Austin, TX
Both don't seem to have a licesnee, other than meeting the DexVi specs.
I would stay with OEM speced fluid, you have so many choices that are licensed unlike non-American vehicles where one is stuck.
Meeting specs is different from speced fluid and why are you thinking about fluids on nrad new vehicles, give it 60K and ping the forum
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
#4548931 - 10/20/17 06:52 AM Re: Amsoil & Redline ATF is 1 better than the other? [Re: BobsArmory]
StevieC Offline
Amsoil has a line of licensed products along with their non licensed products. One of which is the XL line of Motor Oils and OE line of ATF's.
Second they will guarantee their products will not cause failure and will warranty them if they do.
(Haven't heard of anyone ever needing this.)
Third the burden of proof is on the Manufacturer to prove it was a failure of the lubricant.
On top of that because they aren't sold through retail channels and it primarily depends on jobbers to sell it through the MLM model don't you think they would have failed by now if their products weren't high quality?
Edited by StevieC (10/20/17 06:58 AM)
#4549023 - 10/20/17 08:54 AM Re: Amsoil & Redline ATF is 1 better than the other? [Re: BobsArmory]
Click Offline
Loc: minnesota
StevieC Im not sure about up in Canada but Amsoil is sold in retail stores all over the U.S. just not in big box stores. Almost every auto parts store around here has Amsoil on the shelf, same with many hardware stores, small engine shops etc. Its allowed under Amsoil's marketing plan but regulated to protect their dealer network. smile
#4549031 - 10/20/17 09:07 AM Re: Amsoil & Redline ATF is 1 better than the other? [Re: Click]
StevieC Offline
Here it's in very few shops and no retailers. It's mainly sold directly by jobbers.
But what you are describing means that it's even more widely adopted in the U.S. then so it just further supports my point I was making about their quality and it not grenading units it's used in.
#4549736 - 10/20/17 10:37 PM Re: Amsoil & Redline ATF is 1 better than the other? [Re: BobsArmory]
TheKracken Offline
Loc: Fort Worth TX
I flushed my truck and replaced it all with amsoil atf. So far I love it.
Also switched my prius to amsoil atf and haven't noticed much of a difference...but I expect that it will last a very long time. I used signature series for both the truck and prius.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Page 1 of 3 1 2 3 >
