Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
18 registered members (Cpcz9382, Harleydav91, 1345, Char Baby, D0nat, 1 invisible), 834 guests, and 46 spiders.
Topics295,172
Posts4,929,118
Members66,700
Most Online2,553
Oct 27th, 2018
Amsoil dot 3 & 4 = AutoZone brake fluid? #4542712
10/13/17 09:38 PM
10/13/17 09:38 PM
Iowa
Iowegian Offline OP
Iowegian  Offline OP
Iowa
https://www.amsoil.com/shop/by-product/o...fullDescription
http://m.autozone.com/brake-and-power-st...1_0_0?location=
Same bottle
Same viscosity
Same wet boiling point
1 degree difference in dry boiling point.
....same stuff but much cheaper?
Correct me if I'm wrong?
2011 Equinox, 2.4l
2009 Sienna, 3.5l
Re: Amsoil dot 3 & 4 = AutoZone brake fluid? [Re: Iowegian] #4542719
10/13/17 09:45 PM
10/13/17 09:45 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
We'll never know! crzy
That being said, brake fluid is pretty much brake fluid.. not much room for creativity given what it's supposed to do.
Re: Amsoil dot 3 & 4 = AutoZone brake fluid? [Re: Iowegian] #4542751
10/13/17 10:47 PM
10/13/17 10:47 PM
New Jersey
THafeez Offline
THafeez  Offline
New Jersey
I have a feeling that more expensive brake fluids such as severe duty and maybe full synthetic have a higher boiling point compared to the regular dot 3/4 fluids that just barely pass DOT standards and go for cheap.
Links you posted might as well be the same stuff if bottled by one company. Sometimes they'll put the same stuff that one retailer calls for (amsoil) if the specs are the same or lower for another brand (autozone). It's cheaper that way since they can order in bulk. This is all speculation though.. Just my 2 cents.
2004 Toyota Solara SE 2.4 2AZFE
182,000 miles
Castrol Magnatec Semi-Syn 5W30
Royal Purple 20-400 oversize 2nd run
Re: Amsoil dot 3 & 4 = AutoZone brake fluid? [Re: THafeez] #4542764
10/13/17 11:10 PM
10/13/17 11:10 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
All brake fluids have 100% synthetic components today.
https://bobistheoilguy.com/forums/ubbthr...ids#Post3076040
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: Amsoil dot 3 & 4 = AutoZone brake fluid? [Re: Iowegian] #4542768
10/13/17 11:14 PM
10/13/17 11:14 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
I use the cheapest stuff I can find that meets the rating required. I change it every couple of years when I replace the pads because most of the fluid is in the lines and out of the master cylinder at that point.
I start out by taking out as much as possible of the remaining fluid in the master cylinder, then top off with fresh fluid (over full) and then slightly crack open the bleeders and let the stuff drip out while I do other work on the vehicle. Keep topping off and then close up the bleeders and check the system for air.
It's really easy and it has served me well for decades.
'18 Dodge Grand Caravan GT - AMSOIL SS 5w20
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF
Re: Amsoil dot 3 & 4 = AutoZone brake fluid? [Re: Iowegian] #4542786
10/13/17 11:47 PM
10/13/17 11:47 PM
Iowa
Iowegian Offline OP
Iowegian  Offline OP
Iowa
But wet boiling point is 368 for both of these. That far exceeds required dot 4 requirements.
2011 Equinox, 2.4l
2009 Sienna, 3.5l
Re: Amsoil dot 3 & 4 = AutoZone brake fluid? [Re: MolaKule] #4542801
10/14/17 12:20 AM
10/14/17 12:20 AM
New Jersey
THafeez Offline
THafeez  Offline
New Jersey
I don't doubt you MolaKule. Lucas DOT 3 says 100% Full Synthetic on the shelf next to all the other brake fluids. Made me think the rest weren't synthetic and Lucas was superior. Thanks for the clarification. Not a fan of Lucas or their advertising.
182,000 miles
Re: Amsoil dot 3 & 4 = AutoZone brake fluid? [Re: Iowegian] #4542814
10/14/17 01:36 AM
10/14/17 01:36 AM
MA
Wolf359 Online content
Wolf359  Online Content
MA
Those are pretty good specs for a fluid that's supposed to be Dot 3. It basically exceeds Dot 4 specs. Makes me wonder if it's legit or not. Have to check the actual bottle. If you look at the MSDS sheet, it only mentions 446F for Dot 4, but that sheet was revised 20 years ago.
Re: Amsoil dot 3 & 4 = AutoZone brake fluid? [Re: THafeez] #4542824
10/14/17 02:08 AM
10/14/17 02:08 AM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Don't quote me but I don't think Lucas started the "Synthetic" brake fluid labeling. I would say who I think started it but will refrain because Im too lazy right now to research it.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: Amsoil dot 3 & 4 = AutoZone brake fluid? [Re: Iowegian] #4542830
10/14/17 03:10 AM
10/14/17 03:10 AM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Brake fluid is more or less brake fluid for daily driving.
The Bosch can is the performance secret on the parts store shelves.
"Zed's dead baby, Zed's dead."
Re: Amsoil dot 3 & 4 = AutoZone brake fluid? [Re: Iowegian] #4542855
10/14/17 04:52 AM
10/14/17 04:52 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Sometimes you're paying more for a name. In this case I'd go with the cheaper product, and save the extra cash for something else from Amsoil where you're actually getting value for the added cost.
God Bless Our Troops
Re: Amsoil dot 3 & 4 = AutoZone brake fluid? [Re: Iowegian] #4542869
10/14/17 05:40 AM
10/14/17 05:40 AM
Indiana, USA
Smoqueed Offline
Smoqueed  Offline
Indiana, USA
The bottles don't look entirely the same, and I doubt the Autozone "DOT3" actually has those specs. I would need to go there and double check the bottle itself, sometimes they mix up stuff on the website. Regardless, unless you're tracking the car, using super high boiling point brake fluids is kinda pointless. Most standard DOT3 will work just fine for 99% of people. For a little added protection during spirited driving, I use Valvoline DOT3/4. It's like $6 or $7 for a 32 oz bottle at Meijer. Claims 480F dry and 311F wet boiling points for only a little more than a 32oz bottle of standard DOT3.
Looking back at the autozone website, their 32oz of Autozone fluid has the same specs as the 12oz bottle. Maybe it's not a fluke. If not, that's a terrific price for that level of boiling protection. Also took a look at that Bosch brake fluid. Looks like some super stout stuff. Plus I really like metal cans for brake fluid. However, I wont spend $15 a quart for brake fluid when I've never had problems with the $7 a quart stuff
Re: Amsoil dot 3 & 4 = AutoZone brake fluid? [Re: Iowegian] #4542892
10/14/17 06:23 AM
10/14/17 06:23 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
I just buy ST brake fluid and call it a day.
No need to buy anything else.
03 Jeep WJ 4.0 202k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Amsoil dot 3 & 4 = AutoZone brake fluid? [Re: Iowegian] #4542921
10/14/17 07:06 AM
10/14/17 07:06 AM
NY
2dogs Offline
2dogs  Offline
NY
Walmart ST brand for me too. For decades.
Re: Amsoil dot 3 & 4 = AutoZone brake fluid? [Re: Iowegian] #4542936
10/14/17 07:20 AM
10/14/17 07:20 AM
Iowa
Iowegian Offline OP
Iowegian  Offline OP
Iowa
I will probably just get dot 3 stuff too.
From what I have read, dot 4 absorbs moisture more quickly than dot 3 and must be changed out sooner.
I am looking for the best quality/reliability/durability.
I don't want to have to change brake fluid in 3 years.
Anyway, I brought this up because of the curiosity/news component.
Just ran into this wbile researching.
If others like the Amsoil dot 3 & 4, you might want to look into this.
If someone can educate me? But I would assume that this stuff will probably absorb moisture more quickly?
I am looking to not have to change fluid again for a while but to also have good corrosion resistance.
Thanks!
2011 Equinox, 2.4l
2009 Sienna, 3.5l
