Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
23 registered members (Bailes1992, BlakeB, Billbert, Bman90, 2015Corolla, bmod305, 1 invisible), 727 guests, and 37 spiders.
Topics290,745
Posts4,849,458
Members66,033
Most Online3,590
Jan 24th, 2017
Anyone else with a 2nd gen Sienna? Shift quality? #4542370
10/13/17 04:37 PM
10/13/17 04:37 PM
Minnesota
Huie83 Offline OP
Huie83  Offline OP
Minnesota
How does your transmission shift? Are the shifts soft and laggy when warm? IE, it goes to change gears and it doesn't flare but kinds hangs for a few seconds before it goes into the next gear?
We purchased our 06 sienna (2nd gen is 03-08, 07-08 use the 3.5 and diff trans) last year with 83 K miles on it. It's always shifted great when cold, crisp quick shifts. After ~15-20 miles or 30 minutes of driving it starts to get sloppy-laggy-lazy shifts.
Right when I got it I did a few drain and fills with Toyota T-IV fluid as the fluid was a little dark. Nothing abnormal on the drain plug magnet, just a little fuzz. Measured the exact amount I drained and refilled with the same. Checked the level after with engine running, hot and in park. It's exactly at the top of the hot marker so the level is spot on.
A few weeks ago (I'm at 93K miles now) I was reading through the Sienna forums seeing if this was normal. Most posts said they had improved shift feel with Valvoline Maxlife ATF. I did 3 consecutive drain and fills in the same day with a short drive in between. The fluid is nice and pink, again correct level when hot.
The shift quality has improved a little. It's not quite so laggy, but it's still not up to my liking.
Thoughts?
Re: Anyone else with a 2nd gen Sienna? Shift quality? [Re: Huie83] #4542375
10/13/17 04:42 PM
10/13/17 04:42 PM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
See if the transmission has a temperature sensor and try replacing it. I know there are some transmissions out there equipped with these that change the transmission shifts as it warms up and oil pressure inside the transmission changes to try and keep it feeling the same all throughout but if the sensor is bunged up it can affect the shift quality because it's not properly reading the fluid temperature.
Not sure on this generation of Sienna but I would look there first.
Also check to see if the cooler is thermostatically controlled. It could be when the thermostat opens to allow the fluid to go to the cooler that it's not circulating properly and as a result is affecting the oil pressures. These can get bunged up with crud over time.
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: Anyone else with a 2nd gen Sienna? Shift quality? [Re: Huie83] #4542395
10/13/17 04:59 PM
10/13/17 04:59 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
What you describe is very normal for that transmission and the way it is programmed. There are a few ways to minimize it. OTOH, the U151E is an extraordinarily reliable transmission and if you change the fluid periodically, it will outlast the engine or vehicle in most cases.
1st is to use a T-IV spec fluid. This is thicker than Maxlife and the DexVI/Toyota WS fluids. So stick with that as the thinner fluids exacerbate it. If people reported it was better after adding MaxLife or similar, I would check if a) they were replacing worn fluid vs. fresh T-IV, and b) if they corrected a previous underfill. You don't have to use T-IV, but use a fluid of that viscosity (e.g., [email protected])
Another issue is that it is just not possible to get an accurate reading when warm. The splash effect will get in the tube and always make it look full. First thing in the morning, start it, shift slowly down through all gears and back up. Then go pull the stick and just make sure it's above the Cold mark.
Besides getting the right amount of the correct fluid in the transmission, there really isn't much you can do because the behavior is generated by in the PCU, not the transmission. Driving style makes a difference too, because the programming is adaptive. If you are harsh with the gas, this tends to exacerbate it based on a lot of owner experiences I've read on TN and a ClubLexus. If shifts start to feel harsh, check your engine mounts and the torque strut on top; these wear out.
Re: Anyone else with a 2nd gen Sienna? Shift quality? [Re: Huie83] #4542423
10/13/17 05:33 PM
10/13/17 05:33 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
When was the last time the trans filter was replaced?
Re: Anyone else with a 2nd gen Sienna? Shift quality? [Re: Huie83] #4542428
10/13/17 05:43 PM
10/13/17 05:43 PM
CA
The Critic Offline
The Critic  Offline
CA
Some of the 5-spd autos had a TCM update available for shift quality improvements- the update is announced via a TSB. I just did a 2005 RX330 last week for this concern. Get a $15 subscription to TIS and see if there's an applicable TSB for shift quality, and if there is, I would try that first.
Also, make sure the fluid level is not too high. It's easy to overfill these. Drive the car until it is very warm, then check the fluid level. At that time, it should not be higher than hot max.
2011 Toyota Prius - 173k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 131K - Mobil 1 EP HM 5W-30
Re: Anyone else with a 2nd gen Sienna? Shift quality? [Re: Huie83] #4542474
10/13/17 06:23 PM
10/13/17 06:23 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
My Gf's dad has a 2010 AWD w/97k. I was in it last week, and noted the perfect shifts. Has some other crunching issue in the front end, but the transmission is prefect. And he beats it bad. Regarding Maxlife, look carefully at the dates of the posts. Its changed in the past year or 2. Its become thin. Very thin. A post on here said thinner than T-IV. I had an 02 Camry that died with a perfect shifting transmission at 345k. I never switched away from T-IV. I'm running Maxlife in my SUV, contemplating exchanging back to Dex-Vi. Seems to shudder when its hot out. Never did that prior, but the miles are getting up there so I wont know till I do the exchange. One last suggestion is Lubegard Red. Add 10oz, or 1 qt bottle depending on if you can make some room. Its one additive that can make a shifting difference.
06 Escalade 6.0L LQ9 AWD 165k M1 5w30
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Anyone else with a 2nd gen Sienna? Shift quality? [Re: The Critic] #4542479
10/13/17 06:31 PM
10/13/17 06:31 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
AFAIK, this is available for all the early U151E - HOWEVER, most who had it done reported a 10% or more reduction in MPG and an only partially satisfactory result. And it's not reversible, once it is flashed, there's not kit or code to re-flash it. A lot of owners were really dissatisfied with this update and as word spread, people quit getting it done as the mileage penalty was stiff (~29 down to 24 mpgs hwy on the ES and Camry models).
Re: Anyone else with a 2nd gen Sienna? Shift quality? [Re: Huie83] #4542529
10/13/17 07:25 PM
10/13/17 07:25 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
Same engine/trans combo in my '06 Camry
Identical complaint
I'm gonna start checking mounts, and doing one last service with straight up T-IV/3309
I used Castrol Transmax IMV, didn't like it at all
I also put LGP in 3309, not happy with that shifting either
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: Anyone else with a 2nd gen Sienna? Shift quality? [Re: michaelluscher] #4542541
10/13/17 07:36 PM
10/13/17 07:36 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
Have someone shift it while on the brake while you watch from in front with the hood up. Loose mounts should be obvious as it should sit perfectly still through this procedure.
The top "dog-bone" strut breaks often. Of the lower ones, the two side mounts (behind each wheel) are the most likely; the front one is less breakage-prone, unless the dog-bone was broken a long time on top, and then it is over-stressed.
I have heard that complaint re: IMV, though no experience with it myself.
Re: Anyone else with a 2nd gen Sienna? Shift quality? [Re: Oro_O] #4542549
10/13/17 07:50 PM
10/13/17 07:50 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Re: Anyone else with a 2nd gen Sienna? Shift quality? [Re: Huie83] #4542821
10/14/17 02:57 AM
10/14/17 02:57 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Manuals shift exactly how you want, exactly when you want.
Cable ties should hold it
Re: Anyone else with a 2nd gen Sienna? Shift quality? [Re: LeakySeals] #4542873
10/14/17 06:45 AM
10/14/17 06:45 AM
Texas
wag123 Offline
wag123  Offline
Texas
+1
You definitely want to use T-IV transmission fluid.
Lubegard Red does help but the improvement is subtle.
Re: Anyone else with a 2nd gen Sienna? Shift quality? [Re: Oro_O] #4543036
10/14/17 10:13 AM
10/14/17 10:13 AM
Staten Island, NY
Staten Island, NY
I've already put a Toyota top dogbone mount on it
Old one wasn't bad by any means, but I thought I'd start with the cheapest
Side one felt OK when I did the trans pan last service, Guess I should check again
Re: Anyone else with a 2nd gen Sienna? Shift quality? [Re: Huie83] #4543304
10/14/17 03:31 PM
10/14/17 03:31 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
I have an 04 Sienna and the wife and I love this thing. I have noticed the shifting isn't the best but at over 280k miles I am just thankful it still runs! Planning to keep it for another 7 or so years and 350k miles before buying another! It's a top of the line model with awd.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: Anyone else with a 2nd gen Sienna? Shift quality? [Re: Huie83] #4543312
10/14/17 03:41 PM
10/14/17 03:41 PM
Minnesota
Huie83 Offline OP
Huie83  Offline OP
Minnesota
Thanks guys, I verified the fluid level today both cold and hot, it's spot on for both.
I ordered a case of Toyota T-IV from amazon and will swap it out next week. I have a fluid extractor so I think this time I'll just suck it through the dipstick tube, measure and refill with the same amount 3 or 4 times with small drives in between to mix the fluid.
I'll report back next week.
