- Joined
- Sep 26, 2010
- Messages
- 9,807
Vehicle in question is a Nissan Juke (out of warranty). The OEM calls for a 6607 which is a very small filter and a larger filter may allow me to use the full 5QT jug instead of 4.5QTs. I grabbed a couple of cheap SuperTech filters to dissect, though I would use another brand (most likely). The 7317 (not shown) is somewhere between the 6607 and 9688, but is closer to the 9688 size.
Realizing that an intangible may be gained by using a larger filter--but they all cost the same, which would you use?
