Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
jefe_de_estado, CM613, Geardaddies, 01ws666, ariefnrst
66660 Registered Users
104 registered members (19VWJettaS6speed, 53' Stude, askani79705, aquariuscsm, AMC, 14 invisible), 1,938 guests, and 34 spiders.
Topics294,986
Posts4,925,456
Members66,660
Most Online2,553
Oct 27th, 2018
If oil pressure were low(er) in a warm engine #4542316
10/13/17 02:55 PM
10/13/17 02:55 PM
Mississippi
Speak2Mountain Offline OP
Mississippi
would a lower or higher viscosity motor oil successfully address it?
Re: If oil pressure were low(er) in a warm engine [Re: Speak2Mountain] #4542328
10/13/17 03:05 PM
10/13/17 03:05 PM
PENNSYLVANIA
JeepWJ19 Offline
JeepWJ19  Offline
PENNSYLVANIA
higher viscosity
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Re: If oil pressure were low(er) in a warm engine [Re: Speak2Mountain] #4542353
10/13/17 03:25 PM
10/13/17 03:25 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
The oil pressure on the gauge of my Santa Fe was always higher when cold and then would drop as it warmed up. It would also be higher with thicker weight oils as I experimented.
It was rated for 5w20 but I had put in some old 15w30 I had one summer just to get rid of it. I thought the needle was going to break off the gauge. LOL
'18 Dodge Grand Caravan GT - AMSOIL SS 5w20
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF
Re: If oil pressure were low(er) in a warm engine [Re: Speak2Mountain] #4542539
10/13/17 06:33 PM
10/13/17 06:33 PM
Canada
i_hate_autofraud Offline
Canada
Yup, higher viscosity is handy:
As a teen I had a dodge slant 6, that groaned at idle - the main bearings had bottomed out
due to excessive wear/clearance and on-spec oil! Oil light was on even with a full crankcase!
Switched to 20W50, upped the idle a bit and drove it for 3 more yrs!
Re: If oil pressure were low(er) in a warm engine [Re: Speak2Mountain] #4542554
10/13/17 06:58 PM
10/13/17 06:58 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Castrol 10W-60 is the ticket for loose engines laugh
Re: If oil pressure were low(er) in a warm engine [Re: Speak2Mountain] #4542583
10/13/17 07:23 PM
10/13/17 07:23 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
SAE60 is where it is at. I had a friend in high school ran that in his truck that called for 5w20. Blew his engine up 2 weeks later.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 Maxlife Syn 5W30
06 GMC Sierra Nextgen 10W30
Re: If oil pressure were low(er) in a warm engine [Re: Speak2Mountain] #4542796
10/14/17 12:04 AM
10/14/17 12:04 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Very High Viscosity, but remember ... you may not be helping your motor that way. As long as there is an oil film on mating parts whether those parts should be under pressure or not, the oil is doing it's job. Higher viscosity oils may not be able to flow everywhere they're needed, when they are needed.
Personally, I have never been bothered by low oil pressure, as long as I knew the sump was full of oil and I had a reasonable reading. As engines wear, tolerances increase, and that is normal. Wide tolerance motors generally start easier than tight tolerance motors. In cold weather, they start much easier. This means less wear and tear on things like starters and batteries.
By "reasonable reading, as long as I have at least 10 PSI at idle, I am good to go. There is no real reason to need more, "just because".
Bends in oil lines or oil filter / cooler fittings (especially sharp bends of 90degrees or more) and various machined passages will raise oil pressure without benefitting the lubrication of the motor, in fact they are a detriment to it.
It's OK if you know the engine and it's tendencies and at that point find your oil pressure is unusually low or high, but if you are just panicking for no reason it's time to take a step back and find out what numbers you should be getting. Where you place your gauge or sender can affect the reading as well; if the numbers seem out of range, take the necessary steps to rule out unintended consequences that may be giving you an improper idea of what the pressure is at the critical areas (typically main bearings).
It's not difficult to drop the pan on many motors and have a look, do a measure, and even replace worn bearings before buttoning it up again.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Im getting a warm engine rattle when I restart [Re: Johnny2Bad] #4542871
10/14/17 05:43 AM
10/14/17 05:43 AM
Mississippi
Mississippi
Google search say:might be oil pressure
Re: Im getting a warm engine rattle when I restart [Re: Speak2Mountain] #4544129
10/15/17 01:24 PM
10/15/17 01:24 PM
Canada
Canada
Old vintage engines tolerate thicker oil better then new engines with much tighter clearances
and higher piston speeds where on-spec oil is needed to lube the pistons 'just right'.
While I slapped in 20W50 in a Slant 6, (that being the heaviest oil I could get in town)
I would not want to try it on a late model engine!!
Re: Im getting a warm engine rattle when I restart [Re: i_hate_autofraud] #4544183
10/15/17 02:48 PM
10/15/17 02:48 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
BMW until very recently spec'd 10w-60 for their "M" engines and Ford spec'd 5w-50 for the Coyote when in "Track Pack" form, despite spec'ing 5w-20 in plain-jane GT form.
Also, temperature is a far bigger driver of viscosity than what you see on the bottle. At -30C 0w-20 is going to be much, MUCH heavier than 20w-50 in Arizona.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
