I have sinned
by 901Memphis. 12/15/18 01:57 PM
Milwaukee m12 in vanhaus ratchet
by pda1122. 12/15/18 01:19 PM
Klein dikes
by Donald. 12/15/18 01:03 PM
Help Soldering 3.5mm mono microphone plug
by Brybo86. 12/15/18 01:02 PM
Small Trolling Motors
by wings&wheels. 12/15/18 12:49 PM
Toyota Corolla, good and bad?
by jongies3. 12/15/18 12:35 PM
Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
73 registered members (901Memphis, AandPDan, ammowaster, 4WD, Aero540T, 10 invisible), 1,973 guests, and 40 spiders.
Topics295,112
Posts4,927,975
Members66,688
Most Online2,553
Oct 27th, 2018
xx6607 or xx7317 or xx9688 #4542285
10/13/17 02:19 PM
10/13/17 02:19 PM
Planet Earth
2015_PSD Offline OP
2015_PSD  Offline OP
Planet Earth
Vehicle in question is a Nissan Juke (out of warranty). The OEM calls for a 6607 which is a very small filter and a larger filter may allow me to use the full 5QT jug instead of 4.5QTs. I grabbed a couple of cheap SuperTech filters to dissect, though I would use another brand (most likely). The 7317 (not shown) is somewhere between the 6607 and 9688, but is closer to the 9688 size.
Realizing that an intangible may be gained by using a larger filter--but they all cost the same, which would you use?
Re: xx6607 or xx7317 or xx9688 [Re: 2015_PSD] #4542291
10/13/17 02:25 PM
10/13/17 02:25 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Go for the gusto bigger is better whether it makes a difference or not.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: xx6607 or xx7317 or xx9688 [Re: 2015_PSD] #4542310
10/13/17 02:46 PM
10/13/17 02:46 PM
North Carolina
6starprez Offline
6starprez  Offline
North Carolina
I didn't know ST and Fram use the same numbers. If that's the case and you have room, is there a 3593A? That's the largest volumn of the M20x1.5 thread filters that are close to 3" Outer Diameter (OD) with going too wide. I made a Fram chart a few years back but I'll rewrite it below. My Subaru and Honda are the same thread size.
3593A - OD 3.02" - Height 3.39"
9688 - OD 3.02" - Height 3.08"
7317 - OD 2.69" - Height 3.47"
6607 - OD 2.69" - Height 2.63"
3985 - OD 3.66" - Height 3.69"
3950- OD 3.66" - Height 3.09"
'12 Impreza Sport Limited 164K - Magnatec 0W20
Re: xx6607 or xx7317 or xx9688 [Re: CT8] #4542319
10/13/17 03:01 PM
10/13/17 03:01 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
+1
Re: xx6607 or xx7317 or xx9688 [Re: 2015_PSD] #4542323
10/13/17 03:02 PM
10/13/17 03:02 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
To be fair, the actual Fram xx9688 is larger than the ST9688.
03 Jeep WJ 4.0 202k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: xx6607 or xx7317 or xx9688 [Re: 2015_PSD] #4542333
10/13/17 03:09 PM
10/13/17 03:09 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
In the ST filters, the ST9688 is the 7317 equivalent. They consolidate the 9688 and 7317 applications into one. I'd use the ST9688, haven't seen a Nissan yet where the longer (7317) one wouldn't work. And in the ST the 9688 uses a separate dome bypass as opposed to a combo valve in the 6607.
Re: xx6607 or xx7317 or xx9688 [Re: 2015_PSD] #4542348
10/13/17 03:22 PM
10/13/17 03:22 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Bigger should be no problem in my mind. But why don't you go to a 99% plus filter rather than a 95% filter when it would appear to me you are trying to get cleaner oil by using a larger size filter? Extend OCI's is your goal correct?
2004 Corolla 126813
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: xx6607 or xx7317 or xx9688 [Re: 2015_PSD] #4542365
10/13/17 03:34 PM
10/13/17 03:34 PM
Virginia
mattwithcats Offline
Virginia
Car in my signature specs a 6607, I use a 7317 oversized.
Same base, same bypass pressure, just longer...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: xx6607 or xx7317 or xx9688 [Re: 6starprez] #4543359
10/14/17 03:35 PM
10/14/17 03:35 PM
Planet Earth
2015_PSD Offline OP
2015_PSD  Offline OP
Planet Earth
Many thanks for this. I will have to see what will fit.
Re: xx6607 or xx7317 or xx9688 [Re: 2015_PSD] #4544303
10/15/17 05:11 PM
10/15/17 05:11 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I'm in the same boat with the G37. The oversize options up here are cheaper than the specified size, generally. So, I'll often just grab whatever's cheaper and/or convenient. I would say that over half my oil changes used an oversized filter. I wasn't looking for any benefit beyond price. Sometimes one or the other is out of stock, too, so I grab what's handy. I'm running an oversized Wix right now, 57356, as a matter of fact, and the last Baldwins were oversized, too. The specified filter seems to always be $2 more, no matter what brand. The only exception was if I compare the old Wix 51365 versus the old oversize 51356, where they were a bit closer.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: xx6607 or xx7317 or xx9688 [Re: 2015_PSD] #4544606
10/16/17 02:58 AM
10/16/17 02:58 AM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
The small oem filter, p/n 15208-65F0E, has media surface area similar to that shown of the ST9688. The anti-drainback valve incorporated in these cheap filters consumes far too much space in the canister to make this a practical design.
Spend the money ($5.50 mail-order) on the OEM Gonher filters and get the correct capacity and proper design. Those Wal-Mart offerings are overpriced at $1.00.
Re: xx6607 or xx7317 or xx9688 [Re: 2015_PSD] #4544992
10/16/17 09:31 AM
10/16/17 09:31 AM
MA
PE400 Offline
PE400  Offline
MA
I have a 04 Subaru RS 2.5 just rebuilt. not a fan of the tiny st6607 I've used for the break-in and just put on for the first 100 or so miles. Any Subaru owners on here using the 3953A? This RS doesn't have the ring of fire exhaust design..
2000 Jeep Cherokee Sport 121,895 mi (rebuilt @ 114000)
Fram Ultra XG8A
Rotella T5 15-40
Re: xx6607 or xx7317 or xx9688 [Re: FowVay] #4544999
10/16/17 09:34 AM
10/16/17 09:34 AM
Planet Earth
2015_PSD Offline OP
2015_PSD  Offline OP
Planet Earth
Originally Posted By: FowVay
The small oem filter, p/n 15208-65F0E, has media surface area similar to that shown of the ST9688. The anti-drainback valve incorporated in these cheap filters consumes far too much space in the canister to make this a practical design. Spend the money ($5.50 mail-order) on the OEM Gonher filters and get the correct capacity and proper design. Those Wal-Mart offerings are overpriced at $1.00.
I only bought the ST filters to dissect and examine. I plan to use a FRAM Ultra filter, I just need to see what will physically fit on it.
Re: xx6607 or xx7317 or xx9688 [Re: 2015_PSD] #4545009
10/16/17 09:42 AM
10/16/17 09:42 AM
MA
PE400 Offline
PE400  Offline
MA
can you post pics of their combo valves as well.
Fram Ultra XG8A
Rotella T5 15-40
Re: xx6607 or xx7317 or xx9688 [Re: 2015_PSD] #4545621
10/16/17 08:26 PM
10/16/17 08:26 PM
MT
jongies3 Online content
jongies3  Online Content
MT
Go bigger, I use a bigger filter just to be able to dump an even 6 quarts in my truck. Hate having a opened half leftover laying around.
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM TG-3600 filter
1969 Mustang Mach 1 5.8 V8: PYB 10W-30 Napa Gold 1515 filter
1997 Ford F-250 HD 7.3 Powerstroke V8: T6 5W-40 FRAM PH-3786 filter
