There it is!
Blows the dipstick out of its hole if you rev it, I assume broken ring or hole in the piston. Had been consuming a ton of oil due to manifold mounted converter failing and getting sucked in. Purchased a low mileage used engine from a wrecking yard, so that will be my fun this weekend.
