Crown Victoria HVAC repair
by emmett442. 09/24/18 08:44 AM
2007 Toyota Camry LE Alternator
by maverickfhs. 09/24/18 08:28 AM
AutoSense drying not drying
by Ifixyawata. 09/24/18 08:23 AM
Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
TCam, OzFrog, Kursk, DMB, bcrossen
66060 Registered Users
80 registered members (A310, 69GTX, 92saturnsl2, 4WD, 1JCB, 65convertible, 13 invisible), 1,579 guests, and 29 spiders.
Topics290,932
Posts4,852,664
Members66,060
Most Online3,590
Jan 24th, 2017
Late 90s Ford 4.6 timing issue #4541360
10/12/17 04:37 PM
10/12/17 04:37 PM
El Oeste
HawkeyeScott Offline OP
El Oeste
Kicking tires on a 1998 Town Car with the 4.6. It, supposedly, only has 73k miles on it but the older lady selling it says it needs a timing chain. I know the 4.6 is known as a tremendous motor. So I wonder why, with such low mileage, this car may need this work. Any thoughts? I once had a '97 Crown Vic and it was a really good car. The price is right on this one *IF* it's only a timing issue.
Re: Late 90s Ford 4.6 timing issue [Re: HawkeyeScott] #4541362
10/12/17 04:40 PM
10/12/17 04:40 PM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
Ask yourself do you really want (need) that 20 year old car ?
Re: Late 90s Ford 4.6 timing issue [Re: HawkeyeScott] #4541363
10/12/17 04:42 PM
10/12/17 04:42 PM
El Oeste
El Oeste
Honey, is that you posting on BITOG?! grin
Re: Late 90s Ford 4.6 timing issue [Re: HawkeyeScott] #4541372
10/12/17 04:56 PM
10/12/17 04:56 PM
West Michigan
buck91 Offline
buck91  Offline
West Michigan
That would be unusual. I've had a couple of 4.6L with far more miles on OE chains. Possible that its developed some timing chain rattle from worn tensioner guides, though.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Late 90s Ford 4.6 timing issue [Re: HawkeyeScott] #4541407
10/12/17 05:41 PM
10/12/17 05:41 PM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
Failure to change the oil at prescribed intervals, or allowing it to run low, causing the chains to wear prematurely?
Re: Late 90s Ford 4.6 timing issue [Re: HawkeyeScott] #4541413
10/12/17 05:50 PM
10/12/17 05:50 PM
MN
14Accent Offline
14Accent  Offline
MN
Highly unlikely... But not unheard of. Go take a peek and try to get more info. Sounds like there's missing information here.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Late 90s Ford 4.6 timing issue [Re: HawkeyeScott] #4541453
10/12/17 06:50 PM
10/12/17 06:50 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
The plastic chain guides probably broke. A known failure item. Causes a death-rattle type sound. Especially on cold startup.
Sometimes they get to this point....
[img]http://www.explorerforum.com/forums/index.php?attachments/000_0180web-jpg.44802/[/img]
Re: Late 90s Ford 4.6 timing issue [Re: HawkeyeScott] #4541539
10/12/17 08:09 PM
10/12/17 08:09 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Yeah, what Cujet said. It happens. Most of them last and last but you get the odd one that breaks for some reason.
And I'd take a '98 town car with under 100k over anything '18.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: Late 90s Ford 4.6 timing issue [Re: Colt45ws] #4541557
10/12/17 08:25 PM
10/12/17 08:25 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
+1 to all that is stated here.
A very good 20 yr old car is something to buy and keep rolling. A poor 20 yr old car should be salvaged for scrap.
Nissan Altima 3.5 Coupe
Quaker State High Mileage 5w30 Purolator Boss 14610
"Treat your family like your friends and treat your friends like your family."
Re: Late 90s Ford 4.6 timing issue [Re: HawkeyeScott] #4541643
10/12/17 09:24 PM
10/12/17 09:24 PM
Connecticut
69GTX Online content
69GTX  Online Content
Connecticut
I'd be all over that car if $2K or less and clean overall. Though a timing chain repair could be fairly expensive ($1,000+) though at least it would be done...along with belt, idler, idler tensioner, water pump, and probably vcg's and plugs/coils if needed. If you can do all the work yourself, not such a big deal. And the lady and/or her mechanic could be mistaken and not be a timing chain issue. This is pretty early for one of those to go...unless she's a lead foot driver (not likely). Just using the wrong oil filter can give startup ticking than sound like timing chain "problems."
The 1998 TC was specced for 5w-30. Then back specced by Ford for 5w-20 in 2001. Using that oil for the past 16 yrs could possibly contribute to more timing chain/chain guide wear...especially if OCI's were on the long side. My 1997 Lincoln 4.6 liter went 232K miles on the original timing chain, guide, and tensioner...all the way on 5w-30 conventional oil with 3K OCI's. That was a superb running 4.6l until the water pump failed.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Late 90s Ford 4.6 timing issue [Re: HawkeyeScott] #4541745
10/12/17 11:39 PM
10/12/17 11:39 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
The thing that needs to be remembered is that not all miles are equal. A car with that few miles after this long was likely driven many short trips, very little highway miles, so comparisons to what seems like an average # of miles for them 10+ years ago, don't apply.
Inspect the vehicle. Make sure they didn't put extra thick oil in trying to quiet it down. Insist it has not been started recently before you get there, start it up cold and listen for chain rattle which will be worst right after it starts and decrease as it gets warmer. If the rattle is quite loud or still unreasonable as it warms up, expect to need to replace it soon. If it is only a minor cold rattle then it may go another 20K+ mi before work "must" be done or it implodes.
Re: Late 90s Ford 4.6 timing issue [Re: Mr Nice] #4541804
10/13/17 04:07 AM
10/13/17 04:07 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Why not? If he can do the work himself and get a deal on it. If you have to pay someone, forget it.I doubt the timing chain/components are bad after 73k miles anyway.
The "thinking" man's friend.
Re: Late 90s Ford 4.6 timing issue [Re: HawkeyeScott] #4541849
10/13/17 06:45 AM
10/13/17 06:45 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Another thought, low mile, replacement 4.6L engines are $800 around here. You could even find a later model PI (power improved) 4.6L for that.
Re: Late 90s Ford 4.6 timing issue [Re: HawkeyeScott] #4541870
10/13/17 07:02 AM
10/13/17 07:02 AM
snowblind in TX
punisher Offline
punisher  Offline
snowblind in TX
This job is not really tough to do. Granted my judgement is clouded by a decade at Ford, but tensioner/timing chain replacement on a 4.6 in a CV/GM/Town Car is easily doable for a DIYer of even moderate talent.
Re: Late 90s Ford 4.6 timing issue [Re: HawkeyeScott] #4542141
10/13/17 12:54 PM
10/13/17 12:54 PM
Connecticut
Connecticut
My 2002 Lincoln 4.6L is 17 yrs old with 78K miles. Despite mostly shorter 6-8 mile trips since I bought it with 22K miles, it's quiet and runs clean on the lubricating fluids. Buying a 20 yr old/low mileage 4.6L that has been taken care of is not a big risk imo. I'd be willing to bet this particular car has no timing chain/guide wear issue. Probably just a shop trying to scare the owner into a costly repair job that isn't even needed.
I know the Crown Vics and Grand Marquis in the late 1990's to early 2000's have plastic coolant "hoses" and parts that fail around this mileage and age. Not sure if the Lincoln Town Cars got something different. The 1996-2002 Lincoln Continental 4.6L didn't use plastic coolant parts.
1969 Ply GTX/RRs
