Rust repair cost
by supton. 03/25/19 01:41 PM
MANNOL ATF Multivehicle
by Ether. 03/25/19 01:17 PM
Welcome to Dusseldorf... err... Edinburgh.
by Quattro Pete. 03/25/19 01:07 PM
1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
131 registered members (4WD, 928, 97prizm, 69Torino, 2012AccentSE, 97K15004WD, 14 invisible), 2,250 guests, and 69 spiders.
Topics286,402
Posts4,907,677
Members67,614
Most Online2,967
Mar 10th, 2019
Weak A/C after multi freon charging #4541335
10/12/17 04:05 PM
10/12/17 04:05 PM
Egypt
Omar_Eltahan Offline OP
Egypt
I have a chery A5 car, its model has only fresh air filter, no filter for circulation a/c.
I was running a/c with low and fan speed at 2 or 3 Max. I'm in Egypt so temp. Reaches 40+ easily in summer.
A few months ago a/c went weak in air flow not cooling temp. Means that front seats passengers will feel ok with fan on 4+ while back seat passengers feel hot even with the back air vents located in middle console.
freon Ratio is fixed and I've changed freon machines many times by changing places, also I've cleaned the evaporator and external fresh air filter, even changing it also I've cleaned the blower, all of that without positive results.
Do I have to change the blower or you may recommed another solution?
2012 Chery A5 1.6L
Engine:Castrol Magnatec 10w40
Transmission:Mobil 80w90
Brake:Castrol DOT4
Power Steering:Unknown
Radiator Coolant:Mobil HOAT 33% EG
Re: Weak A/C after multi freon charging [Re: Omar_Eltahan] #4541343
10/12/17 04:15 PM
10/12/17 04:15 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Maybe a blend door problem in the duct work?
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Weak A/C after multi freon charging [Re: Omar_Eltahan] #4541352
10/12/17 04:25 PM
10/12/17 04:25 PM
California
nthach Online content
nthach  Online Content
California
How are the system pressures between the low and high side? Are the blend doors properly switching over between the heater core and evaporator? Did you blindly add refrigerant without checking for leaks and the system high/low side pressures?
Re: Weak A/C after multi freon charging [Re: Omar_Eltahan] #4541448
10/12/17 06:46 PM
10/12/17 06:46 PM
Egypt
Egypt
I've tested pressure and leak on vacuum pressure machine and everything is ok.
What're blend doors?
2012 Chery A5 1.6L
Brake:Castrol DOT4
Re: Weak A/C after multi freon charging [Re: Omar_Eltahan] #4541452
10/12/17 06:50 PM
10/12/17 06:50 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Blend door is under the dash after the blower and before the evap and heater core. Usually a motor goes bad on it.
Re: Weak A/C after multi freon charging [Re: Omar_Eltahan] #4541511
10/12/17 07:28 PM
10/12/17 07:28 PM
Egypt
Egypt
It works fine, have tested it too.
2012 Chery A5 1.6L
Brake:Castrol DOT4
Re: Weak A/C after multi freon charging [Re: Omar_Eltahan] #4541912
10/13/17 07:47 AM
10/13/17 07:47 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Maybe the fan blade/cage on the blower is slipping? I would take the blower out and apply 12v directly too it and see what it does.
Re: Weak A/C after multi freon charging [Re: Omar_Eltahan] #4541921
10/13/17 07:58 AM
10/13/17 07:58 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Some newer cars use solid state controllers for the fan speed output. When these go bad the fan becomes unresponsive to input commands.
Is there a way to do a self test on the Climate Control system? Maybe something in your manual says how to do this.
Re: Weak A/C after multi freon charging [Re: Omar_Eltahan] #4541932
10/13/17 08:08 AM
10/13/17 08:08 AM
Egypt
Egypt
I'll check.
2012 Chery A5 1.6L
Brake:Castrol DOT4
