Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Joey Logano and the 2019 Mustang
by Malo83. 12/13/18 02:40 PM
Ericbrooks, Japanese, lordcheeto, WondrousBread, slickoo9
66672 Registered Users
76 registered members (askani79705, Astro14, 69Torino, BigMoneyGrip, Berny, ArrestMeRedZ, 10 invisible), 1,541 guests, and 39 spiders.
Topics295,045
Posts4,926,669
Members66,672
Most Online2,553
Oct 27th, 2018
H2O in gas additives? #4541315
10/12/17 02:51 PM
10/12/17 02:51 PM
MA.
Camprunner Offline OP
MA.
Here in Western Massachusetts it can get pretty cold in winter -20F for several days on end not as cold as some of you ice state dvellers though. My truck is kept outside and we don't have the best gas here many fuel stations seem to get water in there gas and many cars get frozen gas lines. I have used that stuff called "Heat" before with good results I believe it is just isopropyl alcohol but I often wonder if I should be useing something like Seafoam that says it helps with water in the fuel? Any other opinions or continue on with the "Heat" product?
Re: H2O in gas additives? [Re: Camprunner] #4541322
10/12/17 02:56 PM
10/12/17 02:56 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
Just use the Heet stuff.. it's made specifically to help combat water in fuel. Alcohol is a natural absorber of water.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 266,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 60,000mi
Re: H2O in gas additives? [Re: Camprunner] #4541344
10/12/17 03:16 PM
10/12/17 03:16 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
You can also purchase "Methyl Hydrate" in larger quantities. Its the primary ingredient in gas line antifreeze. You can also reduce frozen gas lines by keeping your tank as full as possible during extreme cold.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: H2O in gas additives? [Re: Camprunner] #4541355
10/12/17 03:30 PM
10/12/17 03:30 PM
Lakeville, MN
MNgopher Offline
MNgopher  Offline
Lakeville, MN
If your gasoline is actually E10 (10% ethanol), you really should not need any gas line antifreeze. Once upon a time, we used to use a lot of HEET here to prevent fuel line icing. Since E10 became the norm, the need has been dramatically reduced. Draw your own conclusions if it gets cold here smile
Re: H2O in gas additives? [Re: Rolla07] #4541445
10/12/17 05:36 PM
10/12/17 05:36 PM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
And avoid fueling up when you see gas being delivered. That's sure to get any water stirred up.
I agree that gas-line freezing has been less of a problem in recent years. But I still carry a small container of gas-line antifreeze in the winter.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: H2O in gas additives? [Re: Camprunner] #4541458
10/12/17 05:53 PM
10/12/17 05:53 PM
ME
eljefino Offline
eljefino  Offline
ME
If you run heet get the Iso-stuff in the red bottle that's more expensive than the corrosive methanol.
Re: H2O in gas additives? [Re: Camprunner] #4541492
10/12/17 06:17 PM
10/12/17 06:17 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Just my thoughts but -20F is rather cold... Less than 0F is quite cold here in southeast Va. Never forget seeing thermometer at 0F in January 1985 at 500 pm right before the Super Bowl between the 49ers and Dolphins. That was a unique experience during daytime hrs around here.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: H2O in gas additives? [Re: bbhero] #4541514
10/12/17 06:29 PM
10/12/17 06:29 PM
Texas & Global
4WD Offline
4WD  Offline
Texas & Global
I remember football
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: H2O in gas additives? [Re: MNgopher] #4541613
10/12/17 08:02 PM
10/12/17 08:02 PM
wi
dave123 Offline
dave123  Offline
wi
+1 One positive to running E10 in winter and all you should need. I always laugh and shke my head when I see people pouring bottles of iso heet in and fill up with E10 guess it makes them feel good most likely they don't understand.
Re: H2O in gas additives? [Re: Camprunner] #4541793
10/13/17 01:42 AM
10/13/17 01:42 AM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
I live about an hour south of you we have junk gas too. 10% ethanol is mandated, there is no top tier fuel available and all of the major brands of gasoline are filled up by the same generic marked fuel truck that goes from station to station filling up their tanks.
K100 is a good fuel additive for removing water from fuel and preventing freeze ups. It is also a good fuel cleaner, stabilizer, rust preventer and upper cylinder lubricant. Biobor EB is another good all in one marine gas additive that will remove water and prevent freeze ups. K100 is available locally at Napa, Biobor EB comes from West Marine. Of course, both products are available online as well.
18 Honda CR-V - Mobil-1 AFE 0w-20
17 Ram 1500 SLT - Napa Synthetic 5w-20
14 Yamaha Super Tenere - Mobil Delvac 15w-40
Re: H2O in gas additives? [Re: ecotourist] #4542419
10/13/17 04:28 PM
10/13/17 04:28 PM
SF Bay Area
y_p_w Offline
y_p_w  Offline
SF Bay Area
Your pumps don't have water filters?
Re: H2O in gas additives? [Re: SirTanon] #4542424
10/13/17 04:35 PM
10/13/17 04:35 PM
SF Bay Area
y_p_w Offline
y_p_w  Offline
SF Bay Area
HEET uses methanol and Iso-HEET uses isopropanol. Both absorb water pretty darn well.
Re: H2O in gas additives? [Re: y_p_w] #4544306
10/15/17 05:14 PM
10/15/17 05:14 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
You still have to watch. Some places even have alarms. Some dodgy independents may not service their filters, and simply not care. Personally, I just try to watch where I fill as much as I can.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: H2O in gas additives? [Re: Garak] #4545229
10/16/17 02:07 PM
10/16/17 02:07 PM
SF Bay Area
y_p_w Offline
y_p_w  Offline
SF Bay Area
Doesn't the pumping rate just slow down when filters need replacement?
I remember with my backpacking water filter (which filters stuff from the water rather than water from fuel), the manufacturer guaranteed that it still operated within specified efficiency even past the rated life, but might be harder to pump. Mine also had a relief valve where too high pressure would send water out the side rather than through the outlet hose.
Re: H2O in gas additives? [Re: Camprunner] #4545286
10/16/17 03:25 PM
10/16/17 03:25 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
If you have E10 and water in the gas your problems are just beginning because once the water phases out there is no way to get it out short of dumping the tank.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
