'15 6.7 Powerstroke UOA
by roadrunner1. 01/18/19 10:18 AM
Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
110 registered members (anndel, 69GTX, Astro14, atikovi, AndyB, 9 invisible), 2,087 guests, and 51 spiders.
Topics296,780
Posts4,958,731
Members66,969
Most Online2,577
Jan 14th, 2019
1998 k3500 7.4l wont start #4541232
10/12/17 12:58 PM
10/12/17 12:58 PM
Florida,Ocala
jubinjr Offline OP
jubinjr  Offline OP
Florida,Ocala
I am having trouble starting my 1998 k3500 7.4l dually. One day it just shut down. Wound up being the coil. I replaced it and drover her for about 2 weeks. She shut off again. Thought maybe it was fuel pump. I replaced the fuel pump nothing. Replaced the coil again. Nothing. I replaced the camshaft postion sensor. I also replaced the crankshaft position sensor. I replaced the rotor and distribitor cap. I also replaced the ignition control module. Also the fuel filter. I am getting beautiful spark and plenty of fuel pressure. I am at my wits end with this truck and i cant think of anything else. Also i replaced all 8 spark plugs. I checked the timing by putting her at tdc. I also checked the maf sensor and map sensor. Please if anybody has any info please help...
Re: 1998 k3500 7.4l wont start [Re: jubinjr] #4541238
10/12/17 01:02 PM
10/12/17 01:02 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Spark to all cylinders?
Injectors pulsing?
Squirt some fuel down the throttle body and see if it tries to start.
2015 Hyundai Sonata 2.4L 89k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: 1998 k3500 7.4l wont start [Re: jubinjr] #4541254
10/12/17 01:19 PM
10/12/17 01:19 PM
Florida,Ocala
jubinjr Offline OP
jubinjr  Offline OP
Florida,Ocala
Spark to all cylinders yes. And i tried carb cleaner and it doesnt start. How do i tell if they are pulsing
Re: 1998 k3500 7.4l wont start [Re: jubinjr] #4541260
10/12/17 01:29 PM
10/12/17 01:29 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I know on TBI engines there’s a bulb you can plug in to see if the injectors are getting power, not sure on the Vortec engines. Someone on here will probably know, might be able to just use a test light while cranking.
Re: 1998 k3500 7.4l wont start [Re: jubinjr] #4541265
10/12/17 01:40 PM
10/12/17 01:40 PM
Florida,Ocala
jubinjr Offline OP
jubinjr  Offline OP
Florida,Ocala
I forgot to mention the only code showing in the systmem is p1351 which is high voltage to icm but its a brand new oem icm i put on and nothing but the code keeps popping up everytime i clear it
Re: 1998 k3500 7.4l wont start [Re: jubinjr] #4541284
10/12/17 02:20 PM
10/12/17 02:20 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
sounds like a possible wiring issue.
What fuel pressure do you have? does it hold fuel pressure for at least a few mins?
Sounds like maybe its time for it to go to someone with better tools and troubleshooting guide.
Re: 1998 k3500 7.4l wont start [Re: jubinjr] #4541291
10/12/17 02:25 PM
10/12/17 02:25 PM
Florida,Ocala
jubinjr Offline OP
jubinjr  Offline OP
Florida,Ocala
I took it to a mechanic shop and they are the ones who told me to replace the icm and spark plugs.
Re: 1998 k3500 7.4l wont start [Re: jubinjr] #4541298
10/12/17 02:33 PM
10/12/17 02:33 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Well I hope you get your money back then because it didnt fix it.
Re: 1998 k3500 7.4l wont start [Re: Rand] #4541307
10/12/17 02:43 PM
10/12/17 02:43 PM
Florida,Ocala
jubinjr Offline OP
jubinjr  Offline OP
Florida,Ocala
Well i did the work myself. All they did was kind of diagnos it. Im just trying what else could be causing this issue. She sounds like she wants to fire but wont
Re: 1998 k3500 7.4l wont start [Re: jubinjr] #4541354
10/12/17 03:30 PM
10/12/17 03:30 PM
USA
mk378 Online content
mk378  Online Content
USA
My friend has the same engine. The problem he had turned out to be a hole in the main spark wire from the coil to the distributor leaking sparks out. A test plug would fire outside the engine, but it was not enough spark to start it. If you can't get it to fire at all on starting fluid you should take a close look at the ignition parts, which as you know are very hard to see where they are way at the back of the engine.
Throwing codes related to the interface between the PCM and ICM could be a problem with the low voltage wiring, or even a bad PCM.
Re: 1998 k3500 7.4l wont start [Re: jubinjr] #4541422
10/12/17 05:04 PM
10/12/17 05:04 PM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
a bad coil wire can cause an insulation failure in the coil.
gets a gap burned in it that has to be jumped which causes overshoot.
you can get a spark with the plug out that is too weak under compression.
spark too weak or worse jumped timing.
have also seen rotor button arc through.
Re: 1998 k3500 7.4l wont start [Re: jubinjr] #4541886
10/13/17 06:20 AM
10/13/17 06:20 AM
Florida,Ocala
jubinjr Offline OP
jubinjr  Offline OP
Florida,Ocala
How will i know if it isnt sparking inside the cylinder? And i have checked timing. Timing is correct
