Best Oil For Late Model Toyota V6 Engines ?
by ChrisD46
06/21/18 06:58 AM
Ford 4.6L Durability?
by Auae85
06/20/18 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
06/20/18 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
06/20/18 10:01 PM
Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
06/20/18 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
06/20/18 08:49 PM
My FIL in hospice
by fdcg27
06/20/18 08:41 PM
Spraying Polyurethane
by Texican
06/20/18 08:37 PM
Dehumidifier icing
by Kestas
06/20/18 08:37 PM
Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
yamahaboy125, Turboholic, TrpNY, bcj, Ilia
65282 Registered Users
75 registered (2003f7, Amenhotep, AndyB, aquariuscsm, advocate, AZjeff, 8 invisible), 1194 Guests and 29 Spiders online.
65282 Members
67 Forums
285686 Topics
#4540801 - 10/11/17 11:52 PM New tires improperly balanced. How often ?
tomcat27 Offline
Loc: Chicago, IL
I just replaced some Continentals with General Gmax as05's. I was very disappointed to have vibration at highway speeds. Returned to the installer. They said all 4 were out of balance. Claimed the machine must have been out of calibration. Is this common?
2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1984 F150, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
#4540803 - 10/12/17 12:09 AM Re: New tires improperly balanced. How often ? [Re: tomcat27]
Reddy45 Offline
Loc: USA
It can happen. Most of the busy shops around here just do a static balance with lasers, so roadforce/dynamic balance is not standard.
But any shop that sells tires should dynamic balance for free.
#4540806 - 10/12/17 12:22 AM Re: New tires improperly balanced. How often ? [Re: tomcat27]
ecotourist Offline
Loc: British Columbia, Canada
Bought a set of tires and alloy wheels from a major internet supplier. They were not properly balanced. Had a lot of weights on them, and far fewer when properly balanced.
The internet supplier recommended and paid for the re-balance. No harm, no foul.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
#4540898 - 10/12/17 06:56 AM Re: New tires improperly balanced. How often ? [Re: tomcat27]
Alex_V Offline
Loc: Campbellsville, KY
Bought a set of Uniroyals from the local Chevy dealership, which installed them - pretty bad vibration. And the paint marks weren't mounted anywhere near the valve stems. Went back, told them about the imbalance/paint marks, and after the service advisor (the guy that receives the car, whatever he is) tried to tell me he'd never heard of paint-mark-at-valve-stem and that it didn't matter, they remounted and balanced them and they're fine after 50K.
I don't do tires at my shop, but when I discuss new tires with customers I always tell them if there's any imbalance go back to the installer ASAP and tell them to make it right. No excuse for anything but buttery smoothness from a new tire.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 112K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 167K
'67 Suburban, 350, 331K
#4540988 - 10/12/17 08:42 AM Re: New tires improperly balanced. How often ? [Re: tomcat27]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Mount tire with paint mark 180 op the heavy side of wheel ( if marked) to minimize balance weights. If you cant spin the wheel, if you require excessive balance correction, deflate tire and rotate 120-200 deg opposite where it was and HOPE it will balance better. The valve stem has nothing to do with the heavy side off the wheel in my experience. But that was in the 1970's smile
If wheels are unmarked heavy side, spin them bare and find heavy side, then mount tire dot 180 opposite.
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
#4541075 - 10/12/17 10:31 AM Re: New tires improperly balanced. How often ? [Re: tomcat27]
LeakySeals Offline
Loc: Hudson, NH
Seems like the lifetime rotate and balance can cause an issue after some miles.
06 Escalade 6.0L AWD 160k. M1 5w30 Fram TG
03 Maxima 3.5L 149k ST HM 10w30
#4541076 - 10/12/17 10:32 AM Re: New tires improperly balanced. How often ? [Re: tomcat27]
sasilverbullet Offline
Loc: San Antonio, Texas
I always have new tires Hunter Road Force Balanced. Many a bad tire was recognized at installation. Maybe you need to do that also!
14 Honda Civic 4dr EX-L-M1 0W-20 & WIX XP
14 Honda Accord 4dr EX-L 4cyl-M1 0W-20 & WIX XP
02 Chevy 5.7L van-GTX HM 10W-40 & WIX filter
#4541104 - 10/12/17 11:30 AM Re: New tires improperly balanced. How often ? [Re: tomcat27]
Wolf359 Offline
Loc: MA
I just had a couple of rims bent back. Low profile tires and those 17 or 18 inch rims tend to bend easily from potholes. It's not always a balance problem.
#4541889 - 10/13/17 07:25 AM Re: New tires improperly balanced. How often ? [Re: ARCOgraphite]
CapriRacer Offline
Loc: Somewhere in the US
Once again, the idea behind matching the marks is about runout (actually uniformity, but it's a little complicated.), not balance. The idea is to get a *rounder* assembly - BUT - There is no standardization about the marks - color, meaning, etc. Same with wheels. So matching the marks MIGHT get you a rounder assembly - and it might not. The good news is that is doesn't cause any harm.
If one wants to rotate a tire on a wheel to get smaller balance weights - Great! Just be aware that it doesn't get you a better balance - just less weights - AND - you might be screwing up the runout!
CapriRacer
Visit my web site: www.BarrysTireTech.com
#4542380 - 10/13/17 04:47 PM Re: New tires improperly balanced. How often ? [Re: tomcat27]
Traction Offline
Loc: iowa
Just watching tires spin on my road force I visually see many tires that have run out, with a smooth turning wheel. It might have a little effect sometimes with the tread being further away from center, which will take more weight to counter. If a tire calls for over 2 ounces per plane, I will index it 180, and sometimes it cut it by 75%, and sometimes makes it worse.
Tire Industry Association Certified Tire Service Instructor since 2009
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
12 Camry
81 Camaro
55 Chevy C4
#4542397 - 10/13/17 05:01 PM Re: New tires improperly balanced. How often ? [Re: tomcat27]
eljefino Offline
Loc: ME
I've seen a bunch of bent wheels, too. Having worked at a tire shop there's a learned helplessness in (not) informing the customer and just putting the most bent wheel on the right rear.
That gets them out of the shop on their new rubber, and if they complain it'll be in 6000 miles after the rotation when the dud rim comes forward.
95% of customers do NOT want to hear that there's something else wrong with their car when buying several hundred dollars worth of rubber. The competition across the street can sell tires and keep quiet. Many drivers don't care, and many more think it's upsale hi-jinks, even if it's just sourcing another rim from the boneyard. Get the tires sold and out the door-- any problems can and will be taken care of afterwards via warranty.
#4542403 - 10/13/17 05:08 PM Re: New tires improperly balanced. How often ? [Re: tomcat27]
Oro_O Offline
Loc: Seattle-ish, WA
The last two sets of tires I had mounted at Les Shwab (reputable NW chain), had to be rebalanced a week later (4/4 on one install and 3/4 on the other).
One was a brand new set of Cooper, the other my Toyo Open Country just moving rims. I don't know whether they tend to settle after initial use somehow, or it was a sloppy person each time, but I've not had good success with reliable balance on the first pass.
Another time, a tire change revealed a ball joint wearing. It was not apparent in the steering previously, but rapidly became apparent with new tires.
#4545653 - 10/16/17 09:54 PM Re: New tires improperly balanced. How often ? [Re: tomcat27]
dblshock Offline
Loc: WI.
noticed my tire shop balancer spins real slow, always dead on even with all the weights inside.
16 Civic Coupe Touring
640:1 TCW-3 E091
Edge 0/40/XG7317
Firehawk Indy 500
06 4Runner SR5 135k
640:1 TCW-3
M1 0/40 XG3614
Falken Wildpeak AT3W
#4557764 - 10/28/17 09:05 PM Re: New tires improperly balanced. How often ? [Re: tomcat27]
kr_bitog Offline
Loc: South East Asia
Yes it is comnon, many tire shop will not do calibration until someone come back complaining. So if it is reputable tire and vibrate, the balancing machine typically is the culprit. Even more interesting, one batch of my tire is silen at 110 kmh bit vibrate badly at 130kmh. I thought a drive shaft issue but after rebalance at one of the shop that i complained before, the problem solves
