Pennzoil - SN Plus and 0W-16 Q&A
Click here to participate in the Pennzoil Q&A
Oil Filter That Hasn't Been Changed In 3 Years
by BlueOvalFitter
19 minutes 23 seconds ago
by dishdude
35 minutes 8 seconds ago
Control Arm Bushings Bad?
by RoGuE
Today at 01:36 AM
Free Pizza, April 2, 2018....
by mattwithcats
Today at 12:15 AM
Low mileage seven year old tires
by Corollaman
Yesterday at 11:31 PM
Mobil 1 UOAs showing more wear?
by mbacfp
Yesterday at 10:35 PM
2011 Silverado work truck 6000 miles
by Corollaman
Yesterday at 10:25 PM
PP Practically Free at O'Reilly
by John_K
Yesterday at 10:22 PM
Toyota oil filter cartridge assembly
by pda1122
Yesterday at 10:14 PM
Carrying IWB 1911 vs Glock 19
by lukejo
Yesterday at 09:01 PM
Broken stuff this weekend - great service 'though.
by Shannow
Yesterday at 08:57 PM
Denso Air and Cabin Filters?
by maverickfhs
Yesterday at 08:41 PM
Sticky door latch 2nd generation Golf
by vavavroom
Yesterday at 08:35 PM
7$ for a quart of Conventional Oil
by Emanuel
Yesterday at 08:03 PM
Walmart Auto Service - Rant
by Warstud
Yesterday at 07:47 PM
Who has a GOOD particle counter?
by Linctex
Yesterday at 07:41 PM
Pretty impressed non ethanol fuel yard equipment
by ARB1977
Yesterday at 06:28 PM
Did the Admin Really Just Offer an Opinion as Fact
by e55amgbenz007
Yesterday at 06:27 PM
Dead F150
by ridgerunner
Yesterday at 05:58 PM
Car salesmen......Talk to me!!!
by renegade_987
Yesterday at 05:31 PM
glitch666, A76, 3one7, Lubrizol, bdunigan
64486 Registered Users
19 registered (4ever4d, c502cid, Char Baby, 4WD, Boczech, BlueOvalFitter, 1 invisible), 751 Guests and 100 Spiders online.
64486 Members
68 Forums
279985 Topics
#4540652 - 10/11/17 08:39 PM Confused-Aerosol Silicone/Rubber Safety
doitmyself Offline
Loc: MI
Didn't know where to post this.
Some pure silicone products imply that "petroleum based" versions might be detrimental to "some" elastomers. You read the label of many automotive care products to see that they contain petroleum distillates: Armorall, most sealants/waxes, etc.. Most (not all) silicone sprays with petroleum distillates say safe for rubber,plastic, vinyl, and painted surfaces.
Is aerosol silicone safe for automotive rubber?? Where did I get the idea they were not?
I remember reading a debate about the newer formulation of Armorall at the Meguires forum and a Meguires tech. stated that the petroleum distillates in these products were mild, flashed off, etc., and were safe to use.
I find it hard to believe that these aerosol products can state rubber,plastic,vinyl safe and then cause damage. Someone set me straight!
#4540706 - 10/11/17 09:33 PM Re: Confused-Aerosol Silicone/Rubber Safety [Re: doitmyself]
Loc: St. Louis
I used Silicone on my Saturn seals but those doors did not seal that well when I got it.
I have the same question. Someone just recommended a product specifically for seals I am going to try on my new car.
GPS Rubber Care Stick
Truth alone triumphs, not untruth.
2017 Elantra SE
#4540755 - 10/11/17 10:32 PM Re: Confused-Aerosol Silicone/Rubber Safety [Re: doitmyself]
AVB Offline
Loc: Georgia
I know that in the past some brands had a solvent in them that would damage some plastics. I have used some before that turned the trailer lamps that I was installing milky.
#4540896 - 10/12/17 06:53 AM Re: Confused-Aerosol Silicone/Rubber Safety [Re: doitmyself]
Boomer Offline
Loc: Pennsylvania
I worked in a lab for years. I got tubes of silicone based stopcock grease which is very high molecular weight stugg with no solvents, similar to silicone dielectric grease. Still have a couple of tubes. This stuff is great on rubber of all kinds and causes NO SWELL, just slowly absorbs and keeps the material pliable and resistant to oxidation.
2013 VW Passat TDI SE, 54,300 miles Castrol Professional VW507 5W-30
2017 VW Golf All Track 11,750 miles Castrol Professional VW505 10W-40
#4541064 - 10/12/17 10:14 AM Re: Confused-Aerosol Silicone/Rubber Safety [Re: doitmyself]
Kestas Offline
Loc: The Motor City
As AVB said, it's likely the solvent carrier in silicone spray, and not the silicone itself that can damage an elastomer.
#4541083 - 10/12/17 10:44 AM Re: Confused-Aerosol Silicone/Rubber Safety [Re: Kestas]
doitmyself Offline
Loc: MI
Is "petroleum distillates" on most labels a safe solvent carrier?? Fluid Film (FF) says it contains no solvents, but the SDS shows 3 petroleum components: My confusion is: does petroleum ingredients = harmful solvent? FF does have some CYA warnings about "some" elastomers and paint.
I've read over a dozen product labels and one or two did warn about use on plastic or painted surfaces. Most say that they contain petroleum distillates AND state that they are safe for rubber, plastic, vinyl, and painted surfaces. I bought a food safe "water based" LPS brand that claims all surface safety, but even its label contains "liquified petroleum gas".
Then, there are the very old ArmourAll discussions that set up these ideas about use no petroleum containing products on elastomers. Yet, we pump petroleum grease into vehicle bushings, etc..
I'm looking for an safe aerosol product to spray on some squeaky suspension bushings to see if that helps.
#4541099 - 10/12/17 11:19 AM Re: Confused-Aerosol Silicone/Rubber Safety [Re: doitmyself]
doitmyself Offline
Loc: MI
Edit timed out....this is not much different than the brake grease discussions. All brake greases claim rubber safe, yet we have people come here and say that brand XYZ brake grease caused their brake bushings to swell.
