Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
Rotella T5 10w30 Ford 6.7L anyone?
by sw99. 12/14/18 07:49 AM
Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
captobvious, pgrkcs, 4Doors4Life, 780Ari, kayumb
66677 Registered Users
86 registered members (andyd, 1foxracing, 2004tdigls, Anthony, AndyB, AandPDan, 11 invisible), 1,126 guests, and 42 spiders.
Topics295,048
Posts4,926,853
Members66,677
Most Online2,553
Oct 27th, 2018
4.6 oil pan gasket #4540457
10/11/17 04:44 PM
10/11/17 04:44 PM
MB - Manitoba
FastLane Offline OP
FastLane  Offline OP
MB - Manitoba
Anyone changed an oil pan gasket in a Ford 4.6? My Mustang is leaking and should be changed out. There sure isn't much room between the oil pan and the K member. I'm not sure if I can drop the pan enough to get the new gasket back in and under the oil pump. Doesn't look like much fun.
2010 Silverado 4.8 4x4 Mobil 1 5W30 ACDelco PF48E
2002 Mustang GT 4.6 Mobil 1 5W30 MC FL-820S
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Mystic 25W40
Re: 4.6 oil pan gasket [Re: FastLane] #4540463
10/11/17 04:50 PM
10/11/17 04:50 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
For normal people it's not. You gotta be a nut to enjoy stuff like that. smile
Re: 4.6 oil pan gasket [Re: FastLane] #4540475
10/11/17 05:09 PM
10/11/17 05:09 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Generally you can do it one of two ways. You either pull the engine or drop the K-member, the choice is yours and yours alone.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 4.6 oil pan gasket [Re: FastLane] #4540495
10/11/17 05:29 PM
10/11/17 05:29 PM
MN
14Accent Offline
14Accent  Offline
MN
Best bet on a mustang is to drop the k-member and raise up the engine a bit. It's still a really tight fit.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: 4.6 oil pan gasket [Re: FastLane] #4540555
10/11/17 06:25 PM
10/11/17 06:25 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Drop the K-Member, The hardest part is compressing the coil springs.
Some mechanics just lower the K-Member....I don't, I completely remove it & pressure wash it real good. (cap the rack & pinion oil ports!)
You will need a engine holding fixture to suspend the engine while the K-Member is out....I built one that works on SN95 Mustangs & 4th gen F-Bodies.
-New teflon seals for the power steering hoses.
-Check the lower control arm bushings & rack & pinion bushings.
-I recommend changing the Oil Filter/Oil Cooler gasket while the K-Member is out.
-Need an alignment any time the K-Member is removed.
2001 Chevy Camaro L92/4L80E
Re: 4.6 oil pan gasket [Re: FastLane] #4540592
10/11/17 07:04 PM
10/11/17 07:04 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
It may or may not be high on your list of things to worry about, but there are very nice aftkermarket K-members available. I prefer the Maximum Motorsports one, but I have dealt with the employees there a few times in person and they are great people. Griggs is very nice as well. The only downside is you have to convert to coilovers if you don't already have them. There is one company that makes a K-Member that you can use the stock location coils, the name escapes me but when I think of it at 3AM I will post it.
Re: 4.6 oil pan gasket [Re: FastLane] #4540609
10/11/17 07:14 PM
10/11/17 07:14 PM
MB - Manitoba
FastLane Offline OP
FastLane  Offline OP
MB - Manitoba
I want to keep it stock. I have lots of toys and only want to put so much money into the Mustang. I just parked it yesterday for winter. I was going to order to front struts, lower control arms with ball joints, and figure out a plan with the leaking oil pan.
Re: 4.6 oil pan gasket [Re: FastLane] #4540630
10/11/17 07:26 PM
10/11/17 07:26 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
I prefer to pull the engine. That way you can flip it over and put it together without fighting the gasket that keeps falling out of place.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 4.6 oil pan gasket [Re: FastLane] #4540676
10/11/17 08:00 PM
10/11/17 08:00 PM
MB - Manitoba
FastLane Offline OP
FastLane  Offline OP
MB - Manitoba
I was going to ask Ford dealer for a quote. Iím sure they have done a few before.
Re: 4.6 oil pan gasket [Re: Chris142] #4540740
10/11/17 09:07 PM
10/11/17 09:07 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Have you ever changed the oil pan gasket on a Modular Ford? It's one piece & flat.
I don't want to [censored] on someones practices because like I stated....I pull the K-Member instead of lowering it like the service manual states. Removing the engine on this car is ridiculous for just a pan gasket.
Re: 4.6 oil pan gasket [Re: FastLane] #4540775
10/11/17 10:02 PM
10/11/17 10:02 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Fel-Pro makes those snazzy studs that hold a gasket in place while you slide the pan up and get some bolts started. The pan gasket for my 95 5.0 came with them so I am sure there are metric ones also.
Re: 4.6 oil pan gasket [Re: bdcardinal] #4540832
10/12/17 02:47 AM
10/12/17 02:47 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Or clean it up and trade it in.
The "thinking" man's friend.
Re: 4.6 oil pan gasket [Re: Lubener] #4540979
10/12/17 07:34 AM
10/12/17 07:34 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
A 2002 New Edge isn't worth much. To me, it's one of the best cars ever because they go pretty fast and are very reliable. Sort of like a little version of the Crown Vic.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: 4.6 oil pan gasket [Re: FastLane] #4541046
10/12/17 08:45 AM
10/12/17 08:45 AM
MB - Manitoba
FastLane Offline OP
FastLane  Offline OP
MB - Manitoba
I love my Mustang. In this day in age it isn't fast but its cool. I skipped high school in 1994 to see the new SN95 being launched at the local Ford dealer. I even told my teacher I won't be in your class tomorrow!
