Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
48 registered members (alarmguy, Bandito440, 2015_PSD, Bailes1992, Ablebody, bcossa2001, 2 invisible), 858 guests, and 44 spiders.
Topics290,699
Posts4,848,496
Members66,021
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
TRYING TO PASS SMOG #4540346
10/11/17 03:21 PM
10/11/17 03:21 PM
SOUTHERN CALIFORNIA
VSTAR650 Offline OP
VSTAR650  Offline OP
SOUTHERN CALIFORNIA
Hi gang, has anybody here heard of and or has experience with a product called CRC-Guaranteed-to-Pass-Emissions Test?
Reason I ask is I have inherited a 1985 GMC Sierra Classic 1500 that had failed smog test, It is completely stock and original, has a 305 backed by an automatic(I'm guessing it is a TH350). It is a California truck with a cat converter. The cat and Flowmaster muffler are supposed to be fairly new.
Thank you in advance for any responses,
THUMPER>>>>>>>>>>>>>>>>>>>>.
Re: TRYING TO PASS SMOG [Re: VSTAR650] #4540357
10/11/17 03:30 PM
10/11/17 03:30 PM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Well, CRC's only guarantee is your money back if it doesn't work. However I believe that the Guarantee to Pass is only an injector/intake valve/combustion chamber cleaner. Your issues may infact be the FlowMaster Cat as these are not always California certified...or meet California emissions.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX(17K)
Re: TRYING TO PASS SMOG [Re: VSTAR650] #4540365
10/11/17 03:37 PM
10/11/17 03:37 PM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
We have similar emissions standards in Ontario as CARB and the CRC stuff is peddled here and never works. If you can provide me the numbers from your test to indicate what is the problem Eg: High NOX or High Hydro Carbons I can better advise you what to try to get it to pass.
Eg: Retarding the timing etc.
Also is this Throttly Body injection or Carb?
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: TRYING TO PASS SMOG [Re: VSTAR650] #4540376
10/11/17 03:47 PM
10/11/17 03:47 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
Something else to consider - When you bring this vehicle in for testing, are you going for a decent drive first in order to get your Cat properly heated up? I had to do this with my last car - Drive it around for about 15-20 minutes, and as I sat in line, keep the engine at about 1500-2000 RPM to keep the Cat hot. Worked fine.
Beyond that, I'd say that if it still doesn't do the trick, then rather than spending your money on the CRC product, put it into proper diagnosis and repair. Might even be something as simple as new plugs.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 261,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 56,000mi
Re: TRYING TO PASS SMOG [Re: Char Baby] #4540377
10/11/17 03:47 PM
10/11/17 03:47 PM
SOUTHERN CALIFORNIA
VSTAR650 Offline OP
VSTAR650  Offline OP
SOUTHERN CALIFORNIA
Hi Char, thanks for the quick reply.
Re: TRYING TO PASS SMOG [Re: StevieC] #4540382
10/11/17 03:52 PM
10/11/17 03:52 PM
SOUTHERN CALIFORNIA
VSTAR650 Offline OP
VSTAR650  Offline OP
SOUTHERN CALIFORNIA
Hi Stevie, thanks for the quick reply, I don't know why the truck failed on the previous test and my nephew did not hang onto the paperwork from the test center, this truck has a 4bbl carb and HEI ignition( I had to replace the module, also the p/u is new).
Re: TRYING TO PASS SMOG [Re: VSTAR650] #4540384
10/11/17 03:56 PM
10/11/17 03:56 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
At $8 a bottle I might be tempted to try this stuff right before an oil change to keep things nice and clean. Maybe a one two punch btwn this and a bottle of Techron back to back.
Re: TRYING TO PASS SMOG [Re: SirTanon] #4540385
10/11/17 03:57 PM
10/11/17 03:57 PM
SOUTHERN CALIFORNIA
VSTAR650 Offline OP
VSTAR650  Offline OP
SOUTHERN CALIFORNIA
Thank you SirTanon, when I take it for the test I will follow your advice, I also put new plugs in it when I changed the distributor parts (cap, rotor, module and pickup). The plug wires were replaced by my nephew and were still like new.
Re: TRYING TO PASS SMOG [Re: SatinSilver] #4540389
10/11/17 03:59 PM
10/11/17 03:59 PM
SOUTHERN CALIFORNIA
VSTAR650 Offline OP
VSTAR650  Offline OP
SOUTHERN CALIFORNIA
Hi Satin, I just might give it a try, the reason I posted the question is because it was recommended by one of my nephews friends and I have never heard of it before.
Re: TRYING TO PASS SMOG [Re: VSTAR650] #4540391
10/11/17 04:01 PM
10/11/17 04:01 PM
California
Kool1 Offline
Kool1  Offline
California
You may want to find a smog station that advertises "pay if you pass". This way, when you most likely fail, you will know the reason without shelling out more money.
Re: TRYING TO PASS SMOG [Re: VSTAR650] #4540393
10/11/17 04:02 PM
10/11/17 04:02 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Good luck. California has been tightning the max alowable emissions in an attempt to get older cars off the road. That truck was originally built to pass with say 400ppm of hc. Now they want it to pass 100ppm. Something it was never designed to do.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: TRYING TO PASS SMOG [Re: VSTAR650] #4540410
10/11/17 04:40 PM
10/11/17 04:40 PM
USA
mk378 Offline
mk378  Offline
USA
When you change distributor you have to set the timing.
Right now you don't even know if it failed the visual check or the tailpipe meter, and if the latter which of the pollutants. If some part is not CARB compliant, pouring stuff into the gas tank isn't going to fix that.
Re: TRYING TO PASS SMOG [Re: SirTanon] #4540423
10/11/17 05:00 PM
10/11/17 05:00 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Yep my Duramax won't pass if its cold. Take it out for a 30 minute cruise on the freeway and it passed with flying colors.
2004 Corolla 124705
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: TRYING TO PASS SMOG [Re: VSTAR650] #4540433
10/11/17 05:14 PM
10/11/17 05:14 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Carburetor or fuel injection ? That's about the year when they were switching over.
Re: TRYING TO PASS SMOG [Re: VSTAR650] #4540450
10/11/17 05:39 PM
10/11/17 05:39 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Do Cali stuff all the time, not that I like it ... But, the air is cleaner (except for smoke right now ...). The SMOG checks helped a lot with that. You can usually see across the So Cal basins on most days smile
So this is GM's last carburetor year for that truck. W/o the paperwork, we don't know what the "fail" was ... Most likely, if it made it past the visual, could have a leaky gas cap (fumes/won't hold pressure), or that the engine needs a serious tune-up.
All the carburetor functions must be there. Choke stove is a biggie. If the choke is not operating absolutely correctly, it won't pass.
You swapped a module in the HEI. OK, there are bunch of things to check in the HEI as we now have to have "rolling road" tests. That means the advance curve needs to be good. No hick-ups in how the advance comes in, no flat spots in the fuel mixture, etc.
PM me with a real email address, and I'll send you what I have on HEI rebuilds and timing info ... smile
The next thing to look at is cold start. After sitting over night, does it smoke? That would be valve seals. Does it smoke on decel or going down a grade? That would be rings or leaky intake manifold.
Have you changed the PCV valve and ALL the vacuum hoses? Any vacuum leak will throw things off ...
New clean oil and a filter (hopefully HDEO 15W-40 Delo 400 LE). Best oil I have found to get old SBC's pass SMOG ... smile
Tranny could be either, but many trucks got TH400, even with 305 smile
Page 1 of 3 1 2 3
