Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knockers
by user52165. 09/21/18 03:41 PM
Opinion needed....
by Duffyjr. 09/21/18 02:56 PM
2017 nissan sentra
by jahwarrior1423. 09/21/18 02:47 PM
I Need A Safe Space- lol
by Zee09. 09/21/18 02:29 PM
Liqui Moly
by dawgn86. 09/21/18 02:10 PM
Valve issues
by kawie_guy. 09/21/18 01:54 PM
2018 Elantra SE
by wolf_06. 09/21/18 01:36 PM
Nasty looking oil filter
by atikovi. 09/21/18 12:43 PM
Laughing hard.
by StevieC. 09/21/18 12:26 PM
Apologies
by Drew99GT. 09/21/18 12:15 PM
Would Like the Manual Transmission to Make a Comeback?
by Speak2Mountain. 09/21/18 11:39 AM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
116 registered members (ABomb369, 2010Civic, 4WD, 77GrandPrix, Ag76, 55hambone, 13 invisible), 1,630 guests, and 46 spiders.
Topics290,792
Posts4,850,471
Members66,036
Most Online3,590
Jan 24th, 2017
Controlling Temp in 4Runner Interior #4540301
10/11/17 02:29 PM
10/11/17 02:29 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
I have a 2002 4Runner. I have noticed that when I turn the temp know all the way to the coolest position, the fresh air blowing in is no where near as cool as the outside air. I've noticed I can get heated air by just barely moving the know towards the "red" heat zone. Is there some way to make sure when I turn the knob to the coolest setting, I can be assured I am getting the coolest air coming into the interior? Is there some wire or not I could tighten or loosen?
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 58K
Re: Controlling Temp in 4Runner Interior [Re: Gebo] #4540318
10/11/17 02:46 PM
10/11/17 02:46 PM
USA
Reddy45 Offline
Reddy45  Offline
USA
Unless you run the AC, the air coming out of the vents is first picking up heat from the engine/firewall/cowl. This is why it's not as cool as if you just open the window.
Re: Controlling Temp in 4Runner Interior [Re: Gebo] #4540400
10/11/17 04:18 PM
10/11/17 04:18 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
It might need a new heater control valve. Easily diagnosed and cheap to replace on some vehicles, but not all.
Me: 13' VW GTI 3 door 6 speed manual
Re: Controlling Temp in 4Runner Interior [Re: Gebo] #4540430
10/11/17 05:10 PM
10/11/17 05:10 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
Some toyotas have a cable operated heater control valve under the hood that controls the flow of coolant to the heater core. Over the years the cable can stretch and not fully close (or open) You adjust the cable by adjusting both ends or if you're lazy like me you can adjust just one side and get it to 100% closed (cool) and 95% open (heat).
This happened on my Honda, a simple adjustment under the hood made the ac much colder.
Re: Controlling Temp in 4Runner Interior [Re: Gebo] #4540470
10/11/17 06:01 PM
10/11/17 06:01 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
What is with you and the word know ? grin2
Re: Controlling Temp in 4Runner Interior [Re: Gebo] #4540489
10/11/17 06:25 PM
10/11/17 06:25 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
The "b" and the "w" are so close on the keyboard. You knob what I mean?
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 58K
Re: Controlling Temp in 4Runner Interior [Re: Gebo] #4540496
10/11/17 06:30 PM
10/11/17 06:30 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
The B and the W are no where near each other! What the heck ? crackmeup
Re: Controlling Temp in 4Runner Interior [Re: Gebo] #4540517
10/11/17 06:49 PM
10/11/17 06:49 PM
WI
HoosierJeeper Offline
WI
Is the AC on? If it is, sounds like an AC issue. Would want to check the pressures.
If the AC isn't on, sounds normal.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
