Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
06/17/18 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
06/17/18 06:27 PM
Why buy low mileage tires?
by HowAboutThis
06/17/18 05:49 PM
Mercury 35-8M0065104 cut open w/ oil change pics
by dlundblad
06/17/18 05:37 PM
2019 Honda’s miniMOTOs (125cc)
by DuckRyder
06/17/18 05:18 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
26 registered (bubbatime, bbhero, AVB, clinebarger, bdcardinal, Bryanccfshr, 3 invisible), 1013 Guests and 36 Spiders online.
65258 Members
67 Forums
285502 Topics
#4540284 - 10/11/17 02:18 PM Schumacher BT-100 Battery Tester
ssamaroo01 Offline
Loc: Mt. Vernon, NY
I bought the Schumacher BT-100 battery tester earlier this year. I used it recently to test a 6 year old Motorcraft battery. The CCA on the label stated 590CCA. I measured 800CCA. I did the test a couple of times to make sure that I was reading it correctly. Is this normal?
2015 Fusion Titanium AWD 2.0L Ecoboost 93k
2012 Escape Limited 2.5L Duratec 42k
2000 E-250 4.2L 90k
MC FS W/ MC Filters
#4540316 - 10/11/17 02:44 PM Re: Schumacher BT-100 Battery Tester [Re: ssamaroo01]
Quattro Pete Offline
Loc: Great Lakes
AFAIK, battery CCA is tested at 0F. At higher ambient temperatures, the CCA reading will be higher.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (FF)
#4540330 - 10/11/17 03:02 PM Re: Schumacher BT-100 Battery Tester [Re: ssamaroo01]
Rand Offline
Loc: NE,Ohio
you didnt test for CCA. because it wasnt 0f out(and the battery 0f)
and yes its makes a large difference.
Quote:
Cranking amps are the numbers of amperes a lead-acid battery at 32 degrees F (0 degrees C) can deliver for 30 seconds and maintain at least 1.2 volts per cell (7.2 volts for a 12 volt battery).
In other words, CA/cranking amps determine how much power you have to start your car in most climates. The basic job of a battery is to start an engine; it must crank, or rotate the crankshaft while at the same time maintain sufficient voltage to activate the ignition system until the engine fires and maintains rotation. This requirement involves a high discharge rate in amperes for a short period of time.
Since it is more difficult for a battery to deliver power when it is cold, and since the engine requires more power to turn over when it is cold, the Cold Cranking rating is defined as: The number of amperes a lead-acid battery at 0 degrees F (-17.8 degrees C) can deliver for 30 seconds and maintain at least 1.2 volts per cell (7.2 volts for a 12-volt battery).
In other words, CCA/cold cranking amps determine how much power you have to start your car on cold winter mornings.
2017 Jeep Cherokee Trailhawk V6
#4540412 - 10/11/17 04:43 PM Re: Schumacher BT-100 Battery Tester [Re: ssamaroo01]
JHZR2 Offline
Loc: New Jersey
Usually there is a user interaction. You enter nameplate CCA and it reads out a value based upon that.
Are you saying you enter nothing and it just runs a test? I don't buy it.
#4540445 - 10/11/17 05:36 PM Re: Schumacher BT-100 Battery Tester [Re: ssamaroo01]
doitmyself Offline
Loc: MI
User error.....we guys never read the directions,LOL spank. The BT-100 is a load tester that only indicates a good/bad condition.
The OP didn't measure 800 CCA. The indicator needle stayed in the green section during the test. The Green section simply denotes good for batteries with a range of CCA rating from 200 to 1000 CCA .
Operators Manual: http://www.batterychargers.com/content/pdf/0099001450-R0.pdf
#4540628 - 10/11/17 08:25 PM Re: Schumacher BT-100 Battery Tester [Re: ssamaroo01]
CT8 Offline
Loc: Idaho
Those are low end testers and I have been using the likes at work for the past 30 years they work fine for what they are and plenty good to check the battery.
"Don't let your preconceived notions get in the way of facts."Geoff Metcalf"
#4540859 - 10/12/17 05:40 AM Re: Schumacher BT-100 Battery Tester [Re: doitmyself]
ssamaroo01 Offline
Loc: Mt. Vernon, NY
You were right. I read the directions and they are now clear. WOW what a difference!
Thank you everyone for your inputs. It was user error. What kind of battery testers are available to actually measure CCA? Before this tester, I used a regular DVM and measured voltages before and during starts. I'm used to testing telecom batteries, where we measure voltages before and after discharge, intercell resistances, and electrolyte levels.
2000 E-250 4.2L 90k
MC FS W/ MC Filters
#4540862 - 10/12/17 06:02 AM Re: Schumacher BT-100 Battery Tester [Re: ssamaroo01]
JHZR2 Offline
Loc: New Jersey
None actually test it. Some correlate an impedance measurement to a user input CCA value, but they are sensitive to temperature and state of charge.
