ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
104 registered members (2whlgeezer, 2015_PSD, 53' Stude, 2012AccentSE, 15 invisible), 2,183 guests, and 62 spiders.
Topics286,159
Posts4,903,310
Members67,569
Most Online2,967
Mar 10th, 2019
Ford Antifreeze Change Interval #4539913
10/11/17 08:32 AM
10/11/17 08:32 AM
Mt. Vernon, NY
ssamaroo01 Offline OP
Mt. Vernon, NY
Why does Ford recommend the first antifreeze change at 100k and then 50k after that? Is there something special about the factory fill? Perhaps an additional additive that makes it last longer? I'm at 73k now and I'm wondering if I should just go ahead and do a drain and fill at my next oci @75k or wait until about 90k. My car uses VC-3 orange.
Also, is it a good practice to replace the thermostat when doing a drain and fill of the cooling system or is it one of those "if it ain't broke, don't fix it" type of parts.
2018 Explorer Platinum 3.5L Ecoboost 4k
2015 Fusion Titanium AWD 2.0L Ecoboost 118k
2012 Escape Limited 2.5L Duratec 44k
2000 E-250 4.2L 91k
MC FS W/ MC Filters
Re: Ford Antifreeze Change Interval [Re: ssamaroo01] #4539940
10/11/17 08:59 AM
10/11/17 08:59 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
The only things that I can think of for the 100K change is the fact that it was an all brand new cooling system, engine, water pump, radiator etc. And too, that no air has yet entered the system. Now at 100k miles they must feel that enough of the coolant has broken down to warrant a replacement. Other will chime in with more info.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Ford Antifreeze Change Interval [Re: ssamaroo01] #4539944
10/11/17 09:04 AM
10/11/17 09:04 AM
Houston, TX
2015_PSD Online content
2015_PSD  Online Content
Houston, TX
I had gold in my 2010 and did not change it for 5 years/150K and it was "ok", but I probably should have changed it at 125K. I believe that you are fine to go the full 100K miles.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
Re: Ford Antifreeze Change Interval [Re: ssamaroo01] #4539950
10/11/17 09:09 AM
10/11/17 09:09 AM
Melbourne, Florida
RichardS Offline
RichardS  Offline
Melbourne, Florida
I'm with Char, unless you find a way to completely drain, flush, and refill the system, they're anticipating some of the old coolant will linger, and affect the chemistry of the replacement coolant that you've added.
Or they've picked 100k to limit the necessary services for the first/second owner, thereby reducing cost-of-ownership, but set 50k from there to extend serviceable life of aging parts.
2011 Prius II
2012 GLK350
Re: Ford Antifreeze Change Interval [Re: RichardS] #4539957
10/11/17 09:16 AM
10/11/17 09:16 AM
VA
Gebo Offline
Gebo  Offline
VA
I'm with RichardS. Sorta like lifetime transmission fluid. I'd change at 50.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: Ford Antifreeze Change Interval [Re: ssamaroo01] #4539996
10/11/17 09:51 AM
10/11/17 09:51 AM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
It's because they don't trust whoever is doing the coolant change to perfectly bleed the system and not allow contaminants in.
It's the same reason that OEMs use snap-head bolts on certain critical applications where techs just aren't likely to use a torque wrench.
Re: Ford Antifreeze Change Interval [Re: ssamaroo01] #4540132
10/11/17 12:01 PM
10/11/17 12:01 PM
Mt. Vernon, NY
Mt. Vernon, NY
Thanks for the advice. I guess I'll wait until 90k when I perform major service to drain and fill the cooling system.
2000 E-250 4.2L 91k
MC FS W/ MC Filters
Re: Ford Antifreeze Change Interval [Re: ssamaroo01] #4540195
10/11/17 01:04 PM
10/11/17 01:04 PM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
How much have you added over the time you have had it?
Re: Ford Antifreeze Change Interval [Re: bigj_16] #4540233
10/11/17 01:30 PM
10/11/17 01:30 PM
Mt. Vernon, NY
Mt. Vernon, NY
I've never added any coolant. It has always been at the right level.
2000 E-250 4.2L 91k
MC FS W/ MC Filters
Re: Ford Antifreeze Change Interval [Re: ssamaroo01] #4540236
10/11/17 01:32 PM
10/11/17 01:32 PM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
To be honest I usually change my antifreeze 5 years regardless of miles. A simple drain and fill with 50/50 will refresh the lubricants etc. in the cooling system and gives me a peace of mind
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: Ford Antifreeze Change Interval [Re: Bgallagher] #4540238
10/11/17 01:35 PM
10/11/17 01:35 PM
Mt. Vernon, NY
Mt. Vernon, NY
I do that with my wife's Escape since she only drives about 8k per year. I drive a lot - about 30k per year. I bought my Fusion new in April of 2015 and I am currently at 73k.
2000 E-250 4.2L 91k
MC FS W/ MC Filters
Re: Ford Antifreeze Change Interval [Re: Bgallagher] #4540374
10/11/17 03:44 PM
10/11/17 03:44 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
I'd say the 5-years thing would work for a lot of people, but not for everyone, especially when dealing with G-05/Motorcraft Premium Gold, which is rated at 5-years and 100,000 miles. For me, 5 years of driving amounts to roughly 150,000 miles, which would be too long for a standard HOAT like G-05.
Add to that the fact that if you're already at the 5-year/100,000 mile limit for said HOAT, and you only drain-and-fill to replace with fresh stuff, you're not going to get all the old stuff out.. probably leaving about 40-50% of the old stuff.. then the "refreshed" coolant will really only be good for about 2.5-3 years and 50k-60k miles, at most.
If you really want to get another full 5 years and 100,000 miles out of the new fill, then I'd say at least ONE flush will be in order.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 271,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 62,000mi
Re: Ford Antifreeze Change Interval [Re: ssamaroo01] #4540473
10/11/17 06:06 PM
10/11/17 06:06 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Forget what they recommend and change it every year.
Re: Ford Antifreeze Change Interval [Re: Merkava_4] #4540678
10/11/17 09:00 PM
10/11/17 09:00 PM
Houston, TX
Houston, TX
Complete waste of time and money.
Re: Ford Antifreeze Change Interval [Re: 2015_PSD] #4541282
10/12/17 03:18 PM
10/12/17 03:18 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
What about acid build up that can eat away at your engine's gaskets ? Also, if I see junk sticking to the walls of the overflow bottle, that's another indication the coolant needs changed out.
