Trying to fix chainsaw
by turtlevette
2 minutes 46 seconds ago
tire rotation
by marine65
Reese hitch $30 Walmart YMMV
by pda1122
36 minutes 46 seconds ago
Managing Anger During Unexpected Tire Change
by TheLawnRanger
37 minutes 32 seconds ago
2016 Honda Pilot appears to be consuming oil
by pilot1226
50 minutes 44 seconds ago
New belt squeal cause damage to belt?
by pda1122
Today at 05:33 PM
Food Safety - If You Have Children
by Zee09
Today at 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
Today at 05:02 PM
Chain cleaning and lube
by dadinfo
Today at 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
Today at 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
Today at 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
Today at 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
Today at 04:30 PM
mobil 1 rebate check
by Fitter30
Today at 03:52 PM
Cab mount failure
by ram_man
Today at 03:31 PM
02 Saab aero oil?
by Newuser
Today at 03:00 PM
Extend wifi range
by clarkflower
Today at 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
Today at 01:57 PM
Lease Buyout by Dealer
by Throt
Today at 01:52 PM
13 Ford Escape
by RedOak
Today at 01:10 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
78 registered (2015_PSD, 2004tdigls, Balrog006, asiancivicmaniac, AndyB, 10 invisible), 1468 Guests and 50 Spiders online.
65303 Members
67 Forums
285870 Topics
Page 1 of 2 1 2 >
#4539624 - 10/10/17 09:19 PM Supertech ST6607, Honda VT1100, 520 miles
blupupher Offline
Loc: Katy, Republic of Texas
This is a Supertech 6607 with just over 500 miles on it from my 1994 Honda VT1100 motorcycle.
This was just a quick flush oil change using this filter and some Supertech 15w-40 since I just got the bike.
Filter:
Baseplate:
Coilspring:
Magnets I put on the end caught some stuff:
Filter media and combo valve:
Combo valve is pliable (as it should be with 500 miles):
Close up of media and seam:
Center tube with holes:
ST filter next to the Honda filter I took off when I got the bike. Big size difference.
The fitler worked, but is way small, and the combo valve design makes the filter area even smaller than other similar size cans.
This media was the same as the last ST I cut apart, easy to tear with my fingers with minimal pressure. Pushing 2-3x harder on the Honda Filter media resulted in no tearing. I was hoping the last ST media tearing was an isolated thing, but apparently not. No it did not fail, and probably would not in a <5000 mile use, but still.
The filter was replaced with a Fram Toughguard 3593a and I used some of the clearance Peak 15w-40 oil. Not bad for a $5 oil change.
1994 Honda VT1100C: Peak 15w-40/TG/2500 mile OCI
2002 Ford F150: GTX HM 5w-20/EcoGard Syn/1yr OCI
2012 Scion xB: QSUD 0w-20/CQ Blue/5k OCI
#4539641 - 10/10/17 09:41 PM Re: Supertech ST6607, Honda VT1100, 520 miles [Re: blupupher]
bubbatime Offline
Loc: South Florida
Even being smaller, that unit has way more filtering capacity than that engine needs.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
#4539785 - 10/11/17 05:10 AM Re: Supertech ST6607, Honda VT1100, 520 miles [Re: bubbatime]
skyactiv Offline
Loc: The Midwest
Ditto. Even though it has a shared sump. That filter is used on 2.5L Nissans.
Me: 13' VW GTI 3 door 6 speed manual
#4540001 - 10/11/17 09:56 AM Re: Supertech ST6607, Honda VT1100, 520 miles [Re: blupupher]
CT8 Offline
Loc: Idaho
Does it come with the hard drive magnets sick
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4540293 - 10/11/17 02:23 PM Re: Supertech ST6607, Honda VT1100, 520 miles [Re: blupupher]
rrounds Offline
Loc: SACRAMENTO, CA
I have three Hondas and I put the largest filter that will fit the bike. On my '98 VT-1100-T I run the B161-S, '04 VTX-1300 runs a B1431 and my '03 Valkyrie runs the B168 Baldwin filter. Check out the size of these filters and see what will fit your VT100
ROD
'06 S2000
'00 SSEi sold at 252k miles
'08 Ford F53 V10
'13 Jeep Sahara 2 door
#4540352 - 10/11/17 03:27 PM Re: Supertech ST6607, Honda VT1100, 520 miles [Re: CT8]
blupupher Offline
Probably.
LOL, nope, that is extra. smile
ROD
B161-S = PH2849A - thought it might be too long, but if you have it on yours, it should fit mine.
B1431 = PH 7317 or PH3593a (using a TG3593a, a little larger diameter than the 7317).
B168 = Same crossover on the Fram site as the B1431.
#4540570 - 10/11/17 07:43 PM Re: Supertech ST6607, Honda VT1100, 520 miles [Re: blupupher]
slacktide_bitog Offline
Loc: USA
Will the ST9688 fit? smile
#4541089 - 10/12/17 10:55 AM Re: Supertech ST6607, Honda VT1100, 520 miles [Re: blupupher]
blupupher Offline
Yes, the 9688 is just a little shorter (3.08) than the 3593a (3.39), diameter is same, gasket size is same.
Not sure if the ST9688 has a combo valve or not.
Also, I will be sticking with filters that have a silicone ADV to use on the bike.
Bikes have higher oil temps (even though water cooled) than most cars, and heat kills nitrile ADV.
I have several of the TG 3593a in my stash. I will use the current on for 2,500 miles and cut it open.
After that, I will probably change it every other oil change (so 5,000 miles, which with a Toughguard should be fine.
#4541189 - 10/12/17 01:26 PM Re: Supertech ST6607, Honda VT1100, 520 miles [Re: blupupher]
rrounds Offline
Loc: SACRAMENTO, CA
B1431 2 21/32" X 4"
B161-S 3 1/32" X 4 1/16"
B168 3" X 5 3/32"
You will not find a short filter in a large can with Baldwin filters, the filter fills up the can.
Here is a pic of three filters that came off of a S2000 Baldwin, Honda and Wix. The Wix has the same size can as the Honda but is much smaller.
http://photobucket.com/gallery/user/rrounds/media/bWVkaWFJZDozNDY1MDE1Nw==/?ref=1
ROD
'06 S2000
'08 Ford F53 V10
#4541267 - 10/12/17 02:45 PM Re: Supertech ST6607, Honda VT1100, 520 miles [Re: blupupher]
ZeeOSix Offline
Loc: PNW
^^^ Photobucket links don't work anymore since they went into ransom mode.
#4541551 - 10/12/17 08:18 PM Re: Supertech ST6607, Honda VT1100, 520 miles [Re: blupupher]
rrounds Offline
Loc: SACRAMENTO, CA
Heck, I thought the link would still work just not let you post the pic.
ROD
'06 S2000
'08 Ford F53 V10
#4541571 - 10/12/17 08:36 PM Re: Supertech ST6607, Honda VT1100, 520 miles [Re: rrounds]
ZeeOSix Offline
Loc: PNW
ROD
Seems to be working now, wasn't earlier.
#4541583 - 10/12/17 08:45 PM Re: Supertech ST6607, Honda VT1100, 520 miles [Re: blupupher]
goodtimes Offline
Loc: california
If they made the center tube any wider, it would have been more media saved. Just make it all center tube and forget the media why don't they. Huge difference compared to the Toyota filters displayed on another thread. They have media probably twice as deep.
#4541963 - 10/13/17 08:34 AM Re: Supertech ST6607, Honda VT1100, 520 miles [Re: blupupher]
KCJeep Offline
Loc: Mahzurrah!
Never seen a filter that small with Wix's combo valve. Interesting.
09 Lincoln MKZ AWD 91k - M1 AFE 0w30
12 KIA Sedona 86k - Edge 0w40
09 Ford Focus 129k - GTX UltraClean 5w30
00 Chevy Lumina 195k - Supertech FS HM 5w30
04 Jeep Grand Cherokee gone but not forgotten...
#4542148 - 10/13/17 01:01 PM Re: Supertech ST6607, Honda VT1100, 520 miles [Re: KCJeep]
ZeeOSix Offline
Loc: PNW
Thats why the center tube is so big, to accommodate the combo valve.
Page 1 of 2 1 2 >
